Question about Miele KFN8762SDED Bottom Freezer Refrigerator
Display says "F2" where it should state the temp
  • drhstt Jul 11, 2010
    my miel frdige feezer not workin. freezer is fine. fridge not, shows F2 wherre it should say the temp.
  • 532 Answers
F2 would indicate a failure of the refrigerator evaperator sensor.
This is a replaceable item, it appears to be sited on the rear wall of the fridge.
Thanks for contacting Fixya
Posted on Jul 11, 2010
    Genius:
  • 1,417 Answers
please you will have to send me the serial number of your system and also the made .
however, what this code indicate is an error code meaning that there is a loose of wire or over flow of liquid........ depending on the made of your product .
please send me the serial number and the name of your product as a comment then i will be able to give a proper direction to solution .
thank you and thanks for using fixya.
  • 3 more comments
    thank you very much
    i will look for the model name and number, both are very very hard to find.
    i am able to turn thr fridge off. when i turn it on again i hear a hum for a sec then it stops and i fet the f2 sign again
    k 9252 i is the model numbre
    i'm a first time user so dont know the rules here, but i still need help thank you1
    are you still with me?
  • Oloyede Monsuru Jul 11, 2010
    hello,
    The F2 is an error code indicates a problem with the wire connection sensor sensing error meaning that there is a loose of wire from the wire connection.
    what you will have to do to fix up the problem is to go to the back of the fridge on the compressor connected to the capacitor the compressor is like a black pot while the capacitor is very close to it unscrew the capacitor with care and then you will see the loose wire from it position replace it back to it position then couple it back but if there is no loose wire disconnected on the capacitor then it then mean that the thermostat will need to be replace which you can get from your local technician store around you or you order for it on line at the below site
    priceinspector.co.uk
    thedesignermagazine.com
    appliance-world.co.uk
    xiongdudu.com
    All these site give a competitive price among them self so you can go shopping.
    thank you.
Ge jsp 40 code f2 apears on display when trying to turn off oven
f2 means excessive oven temperature.
check the temperature sensor
Dec 15, 2014 | GE Kitchen Ranges
My kitchen aid stove keeps displaying F2:E2 - Why? and what does that mean?
That code means that the oven is over heating.
Replacing the temp. sensor should do the trick. The sensor
is the rod that protrudes from the inside back wall of oven.Usually in the top left corner.
Feb 05, 2013 | KitchenAid KESC307 Electric Kitchen Range
I have an error code of E6 and F2 on my whirlpool accu-bake oven display panel. What do they mean.
Hi
F2-E6 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 08, 2011 | Ovens
My whirlpool oven quit yesterday, started beeping, and displayed F3 code. I got it going again for a few minutes, and it did the same thing. A few more tries, and it displayed F2. Actually started...
Hi
F2/F3 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Jul 31, 2011 | Whirlpool Electric Range
I have an Amana oven with Model # ACF3325AS. A month ago I had a code F3, which a repair man resolved. Now I've got a F2 code stating that the oven is overheating. Can you help with what part I'm...
Hi
Daniel
Jul 25, 2011 | Amana ACF3325AS Dual Fuel (Electric and...
Kenmore Elite speedcook oven Model 63799. F2
f2 error means : -------
1. The oven temp has risen above 665F and the door is not locked or
2. The temp has risen above 965F with the door locked
------------- if this happens you should check: -----------
1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
2. Check and replace oven temperature sensor if necessary
keep updated,please do accept and rate the solution.thanks.
Sep 30, 2009 | Kenmore 63792 Microwave Oven
F2 on the display!
F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor
Apr 03, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
I get a E0 -F2- error code on my whirlpool Accubake GR450LXH2 ran
That mean that the key pad is shorted,needs replaced
E0-F2 Shorted keypad Replace Electronic Range Control/Clock (ERC)
Or
E0-F2 Oven temp too high
1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor
Jan 13, 2009 | Whirlpool GR450 Electric Kitchen Range
Neff electric oven
I also have this problem. Replaced control board, but didn't help.
Display worked fine until control board was replaced. Now display is very hard to operate. It's no sensitive enough to touch. Displays F2:ES (or F2:E5) when cancel is pressed.
Jan 24, 2008 | KitchenAid KESC307 Electric Kitchen Range
Hot point beeper wont stop
This is a code for an over temp condition.
If the oven is cool then there is a problem in the sensor circuit, usually a failed temp sensor.
Post back if you have any questions.
Nov 18, 2007 | Hotpoint SY21 Style Line Gas Single Oven
Miele KFN8762SDED Bottom Freezer Refrigerator Logo
167 people viewed this question
Top Miele Refrigerators Experts
Starnley Johnwells
Starnley Johnwells
Oloyede Monsuru
Are you a Miele Refrigerator Expert? Answer questions, earn points and help others
