I am trying to hook up Linksys Wireless-G PCI Adapter with speedbooster. I insert the setup CD, it goes through the setup and prompts me to turn off my computer and install the adapter. I do this, but when I turn my computer back on it does not open up the installation CD to finish the process.
1. Try setting your PC to boot from CD first
2. Try copying the CD files onto disk and run from there
3. The CD that came with my Linksys didn't work. I had to download the latest software from Linksys
Posted on Apr 19, 2008
Error 211
When getting error 211, you will need to manually install the drivers for the adapter.
Exit from the error message, then remove the CD and restart your computer.
Plug linksys usb adapter, the computer will detect the adapter.
Right-click on My computer then click properties, go to Hardware > Device Manager.
Under Other Devices, you will see 802.11 g WLAN with an exclamation point. Right-click on it and select Update drivers.
Then insert the CD. (If the installation setup screen appears, just exit it.)
Then on the update driver screen, click browse and select your CD-ROM drive.
Then click finish.
If you are using Win 7, follow the steps from this link.
If you cannot open the link, just go to kb.linksys.com. In the search bar type 20873. Answer title: Error 211 - Installing Driver Manually for network adapters to work in Win7.
I hope this helps!
Apr 29, 2010 | Linksys WUSB54GSC Compact Wireless-G USB...
Unable to setup Linksys WUSB54GC wireless network adapter
The Linksys WUSB54GC isn't compatible with Windows Me, upgrade to XP or Vista. Minimum Requirements
  • 400 MHz or Faster PC
  • 128 MB of RAM Memory
  • CD-ROM Drive
  • Available USB Port
  • Compatible with Microsoft Windows XP, Vista, and Vista 64-bit edition
Apr 17, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
Installation is stuck at 30%
hi
may be the installation software is not working,what you need to do is take the cd out from the computer and just plugg the wireless adapter,when you plug in the wireless adapter it will tell you to insert the cd that came with the usb card so that the software can be installed,once you see this message insert the cd and then follow the setup screen(imp thing:incase you see the screen of the linkys installation donot follow that,follow the windows software setup screen) this will install the software and i am sure the software will get installed if the software has totally gone bad then here is a link you can donwnload the software from website and then try the installation
link for linksys wusb54gsc for :
http://www.linksys.com/servlet/Satellite?c=L_Download_C2&childpagename=US%2FLayout&cid=1115417109934&packedargs=sku%3D1154470123093&pagename=Linksys%2FCommon%2FVisitorWrapper
vedhick
Jan 26, 2009 | Linksys WUSB54GSC Compact Wireless-G USB...
My installation is stuck at 30%
  • Hey, Have to also make sure the wireless adapter is not plugged while installing (only when prompted to plug it in)
  • You can try downloading a NEW installer from the Linksys website. (maybe the cd is scratched?...) Here is a link to the Driver/installer, for your adapter. (This is a WindowsXP Driver)
  • Try installing the driver using that, and then plug in your wireless adapter when the setup program prompts for you to do so.
Report back if there are any more complications or issues that occur during the above process,
I'll be happy to assist you further.
I Hope This Helps.
I installed a linksys wmp110 wireless adapter into my gateway and it causes the computer to freeze up. i removed the card and the computer works fine. what can i do?
Reinstall Drivers
To re-install the wireless adapter’s drivers, you need to perform two steps:
  1. Uninstalling the Previous Drivers
  2. Reinstalling the Drivers
Step 1:
Click Start, All Programs or Programs, and look for the model number of the Linksys Wireless Adapter.
Step 2:
Look for Wireless Network Monitor and select Uninstall.
Step 3:
Wait for the Install Shield Wizard to complete before re-installing the drivers.
NOTE: Before re-installing the driver, unplug your LinksysWireless Adapter. If you’re using a wireless PCI adapter, shutdown thecomputer then remove the adapter.
The screenshots may vary depending on the model number of your wireless adapter. In this example, we’re using WUSB54GS v1.0
Step 1:
Insert the Linksys Setup CD into your CD-ROM drive.
Step 2:
Click Here to Start
to begin the installation process.
Step 3:
Accept the License Agreement by clicking Next.
Step 4:
Insert the wireless adapter into your computer and click Next.
NOTE: Ifyou’re using a wireless PCI card shutdown your desktop PC and open yourPC’s case. Locate an available PCI slot on the motherboard then poweron your PC.
Step 5:
When Linksys Wireless Network Monitor appears, select the name of your wireless network or SSID and click Connect. If you want to configure the adapter manually, click Manual Setup.
NOTE: To check if the drivers were properly installed, checkif the Linksys Wireless Network Monitor reports the Adapter is Active.For instructions, click here.
NOTE: If you were not able to install the Linksys adapter drivers, you need to update the drivers.
Update the Drivers
To update the wireless adapter’s drivers, you need to perform three steps:
  1. Downloading the Drivers.
  2. Uninstalling the Previous Drivers.
  3. Installing the Updated Drivers.
Step 1:
Before downloading the drivers, make sure your computer has an activeInternet connection. If your computer is plugged directly into therouter and cannot get online, disconnect your router and plug yourcomputer directly into your cable or DSL modem.
Step 2:
Once online, click here to go to the Linksys Downloads page..
Dec 16, 2008 | Computers & Internet
Vista won't install drivers?
go to the add remove software icon in control panel, and remove the existing linksys stuff, then download again, and install..should work..
Oct 22, 2008 | Linksys WUSB54GSC Compact Wireless-G USB...
Computers & Internet Logo
David Payne
David Payne
