Question about GE Heating & Cooling
GE SmartSense mal-functioning
My GE SmartSense split AC is malfunctioning... Soon after pressing the ON button on the Remote Controller, I get the usual ring tone... but it is almost immediately followed by the OFF tone... and then a yellow light blinks from the second LED of the indoor unit... then the system goes off... please help
SOURCE: samsung aircon cuts off. lights green/yellow flashing
lg air cond.multi split led lamp blink power 1 times,good sleep 2 times
Posted on Feb 13, 2009
  • 400 Answers
SOURCE: GE mini-Split Error code
Replace the indoor pc board and thermistor.
Posted on Mar 20, 2009
SOURCE: ac split unit indoor an ouydoor unit electrical wiring diagram
machine off
Posted on Apr 25, 2009
jmgldsmth
  • 1906 Answers
SOURCE: ice formation in the indoor unit
you need to have the unit checked for the amount of freon in the system this must be done with a gauge set the freon amount is obviously incorrect
also the a-frame evaporator must be sealed in the furnace cabinet
Posted on May 28, 2009
  • 81 Answers
SOURCE: LG split AC keeps displaying CO and wont't turn off with remote.
The "CO" indicates cleaning operation and can be switched of via remote button under flap, labelled AUTO CLEAN.
Mat
Posted on Jul 20, 2009
Mum pressed some buttons on amp now the amp wont respond to the original remote or the universal remote. buttons wont work, batteries good and lights up. is there a button that blocks ir signal?
Looking at the user guide it appears that the amp has a standby mode.
See not below on turning standby on. Question can you see the standby light flashing.
I would also suggest using function on the amp to remove any possible issues with the remote.
One would expect the system to return to normal operation by pressing the power button again. If not what do you see on the display.
Note:
Press 1 to turn on the receiver.You can also turn on the receiver using 1 on the remote control. When you turn off the receiver, press 1 again. "STANDBY" flashes on the display panel. Do not disconnect the AC power cord (mains lead) while "STANDBY" is flashing. This may cause a malfunction.
Jul 08, 2017 | Sony Audio Players & Recorders
How to remove filter light in Hitachi split AC
Ensure you replace the filter on the AC or
How to clean filter of split AC
When its turn off,not unplugged, press at the same time ''Function Button" and the ''AUTO Swing" button on your Remote Controller.
Apr 10, 2016 | Hitachi Heating & Cooling
My Panasonic split air conditioner has stopped cooling - model:CU-W18DKR. The internal unit and internal fan operate normally. The external unit fan does not run like normal and no compressor sounds f
Sounds like a faulty outdoor controller board. If you are in Australia, call Prime Electronics or Statewide Appliances for spares.
Part number: NPCWA743383
• To make a diagnosis
1. Timer LED start to blink and the unit automatically stops the operation.
2. Press the CHECK button on the remote controller continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote controller. The code "H00" (no abnormality) will be displayed and signal will be transmitted to the main unit.
5. Every press of the button (up or down) will increase abnormality numbers and transmit abnormality code signal to the main unit.
6. When the latest abnormality code on the main unit and code transmitted from the remote controller are matched, power LED will light up for 30 seconds and a beep sound (continuously for 4 seconds) will be heard. If no codes are matched, power LED will light up for 0.5 seconds and no sound will be heard.
7. The breakdown diagnosis mode will be canceled by pressing the CHECK button continuously for 5 seconds or without any operation the remote control for 30 seconds.
8. The LED will be off if the unit is turned off or the RESET button on the main unit is pressed.
Or better yet, get a tech to check first.
Feb 10, 2015 | Panasonic Single Split System - Wall...
Our york split Ac is not functioning, only the display showing F8 when pressing remote power button. Please help to recover .
please email me so i can further assist you with this....it could be a transformer or a bad fuse....the air handler ( the blower under/in your furnace) should come on either way.
my email is jefner775@yahoo.com y name is jennifer im a certified ac and refrigeration technician.
Oct 21, 2013 | Carrier 38CKC018 Air Conditioner
Help have onix split system air con and remote not working and it s the only way to turn it on have tried every where to get one model no is TEM-84CHSBE heat unbearable in summer nth qld aust.
Auto-restart Presetting:
The appliance is preset as no auto-restart function by manufacture. If Auto-restart function is needed, follow the
step below to activate this function:
1) Make sure the Air-con's power is off:
2) Press down and hold the Emergency button (ON/OFF )on the indoor unit then electrify.
3) Keep pressing the Emergency button for over 10 seconds until three short beeps are heard.
The Auto-restart function is then activated. To cancel the Auto-restart function, repeat above procedure until four
Remarks: When remote controller is out of work, open the panel and you can see emergency button there, see the
The emergency button for 50, 70, 90 series is at the top right, see " ON/OFF " button there.
Auto-restart set:
the appliance is preset as no auto-restart function by manufacturer. If Auto-restart function is needed, follow the
below step to activate this function:
1) Make sure the Air-con's power is off .
2) Press down and hold the Emergency button (ON/OFF )on the indoor unit then electrify .
3) Keep pressing the Emergency button for over 10 seconds until three short beeps are heard, then Auto-restart
function is activated. To cancel the Auto-restart function, repeat above procedure until four short beeps are heard.
Oct 31, 2011 | Heating & Cooling
Where is the reset filter button for mastermind chrome split ac
hi guys i found reset button in whirlpool chrome model split 1.5 ton just you lift the door of ac then you look carefully at the top of right there is a warnig door no need open that just above a button like thing in a hole just press it when ac is on
Jun 11, 2011 | Whirlpool ACC108PS Air Conditioner
My hitachi split ac is not starting, orange light is blinking........ no response on clicking all the buttons in remote
this problem arises when u disturbe the remote settings. to make it operate again use the following procedure
1.on the power from stablizer
2.press the button in remote with 'key' sign once
3.now adjust the number displayed in remote 9 99 to 3 25 by using 'down '(temp adjustment button) key.
4.press again the button with 'key' sign
5.now ur ac is reinstate
enjoy the breeeeeeeeezzzzzzzzzzzzzzzzeeeeeeeeeeeeee
thanks
atul sharma bikaner rajasthan india
May 05, 2011 | Hitachi Heating & Cooling
How do I set the sleep timer for GE universal remote RC24991
Usually you check for the sleep button on your remote controller. Press the button and the sleep function comes on. Pressing it again adds about 5 to 10 minutes to your time for the sleep function to come into effect.
After the time has gotten to its highest the cycle goes off and satrts again.
Hope this solution has been helpful?
Oct 25, 2010 | GE Televison & Video
I have lost the ge universal remote guide for the codes its a ge sku 24914 universal remote i need the codes to program the remote
These are the steps on how to program your GE Universal Remote Control without the list of codes.
1. Manually turn on the device to be
controlled.
2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
3. Press and quickly release the desired device button. The red indicator blinks off once.
4. Press the ON•OFF button repeatedly (up to 300 times) until the device to be controlled turns off. The red indicator blinks off with each button press.
Note: Code Search starts from the currently stored four digit number under that mode. Sometimes the
first code that “works” with your device may only
allow limited functionality (e.g. the MENU button
might not work). There may be a code that performs
more functions. Continue the code search process
until the best code is found.
5. Press and release ENTER to install the code.
Jun 13, 2010 | Universal Remote Control GE174Universal...
Don't have codes
ge codes for mad catz universal remote: 029, 031, 007, 040, 027
instructions
1) Press the "TV" mode button
2) Press and release the "SET" button (You may need to use a paperclip or small item to do this.) - The controller will light-up GREEN
3) Press the first number of the TV code - the controller will illuminate RED
4) Press the second number of the TV code - the controller will illuminate AMBER
5) Press the third number of the TV code - the controller will semi-illuminate
6) lf the first code you try does not work, try the others
hope this helps,
trin
Nov 17, 2007 | Televison & Video
Heating & Cooling Logo
428 people viewed this question
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
