Question about Apex Digital GT2015DV 20 in. TV/DVD Combo
DVD does not play when u insert disc it shows NO DISC on screen
Is this the TV itself or is there something that can be done.
  • Anonymous Sep 18, 2008
    The DVD Disc Clearner will not work. What should I do?
    Genius:
  • 1,139 Answers
Hello krisrohme,
It sounds like you pick-up laser might be dirty. Try using a DVD cleaner and a clearner disk. This should help with this problem.
Thank you,
Shuttle83
Posted on Apr 22, 2008
Why does my TV say No Disc when I have inserted disc
Try several discs. If it happens with all of them it confirms that you have a problem with the disc player. You'll probably need to get a technician to look at it.
May 07, 2014 | Initial IDM-1731 Portable DVD Player with...
When i put a disc in, the screen says NG Disc, and the tv says disc cannot play... What can I do?
You get it as disc cannot play this is because the disc which you have inserted is in format which your DVD player doesnt supports.
So please change the format and play in your DVD player.
Thanx
Jul 25, 2010 | Sony DVP-F21 DVD Player
Philips DVP Playing problem
try to clean or change the laser
Mar 11, 2010 | Philips DVP642 DVD Player
DVD will not play just get a blue plus sign coming down the display after th DVD sign graphic. TV screen shows digital and no disc. Any ideas lease?
is it a burned disk? if so your dvd player might not be able to play that type of dvd... i know sometimes also scratched ones won't play at all as well... of course also make sure everything is plugged in correctly and if it does this with more different dvds then there's something wrong with the player itself... which i hope is not the case as those are very difficult to fix yourself
Jan 13, 2010 | Samsung HT-X200 Theater System
DVP-NS30 shows "CANNOT PLAY" message when DVD inserted
Follow this procedure to troubleshoot if the DVD player cannot read or play the inserted disc.
  1. Ensure the inserted disc is compatible with the DVD player.IMPORTANT: Refer to the operating instructions supplied with the product for a list of compatible disc. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
  2. Use a soft cloth to clean the disc.
  3. Examine the disc for any cracks or scratches that might be interfering with playback.
  4. Attempt to play another disc.NOTES:
    • If another disc plays in the DVD player, then the previous disc is faulty.
    • Some recordable discs may not play correctly because of the quality of the recording, the physical condition of the disc, or the characteristics of the recording device or authoring software used.
  5. Remove the disc from the DVD player.
  6. Turn off the DVD player.
  7. Unplug the power cord of the DVD player from the AC outlet.
  8. Let the DVD player remain without power for 1 minute.
  9. Plug the power cord back into the AC outlet.
  10. Turn on the DVD player.
  11. Insert the disc into the DVD player.
  12. Attempt to play the disc.
If still persists, its time for your device to get serviced.
Aug 01, 2009 | Sony DVP-NS57P
Dvd player is hooked up to tv i insert the disc and push play and then on the screen of the player it reads ''no disc'' and there is a disc inserted in to the player
get a dvd cleaner try using it first, if this will not help then you can manually clean the lens by using a cotton buds but this must be done carefully because the lens is sensitive.
May 16, 2009 | Sony DVP-NS300 DVD Player
Dvd player wont play
I found this on the PROSCAN website under customer support manuals.The website is www.oncorpus.com.I hope this information helps you with your problem. IMPORTANT THE LABEL SIDE OF THE DVD MUST FACE THE BACK SIDE OF THE TELEVISION 1. Press the ‘INPUT’ button to select ‘DVD’ mode, if no disc is inserted yet, the display shows ‘No Disc’.
2.Insert a DVD with the printed side facing towards the rear of the TV/DVD Player (see below)
3.The TV will first display ‘Loading’, then change to ‘DVD-video’. Most DVDs will show some preliminary
information then stop at a main menu screen.
4. Press PLAY/PAUSE to play it directly. Or press the DVD-MENU button to access the disc menu during
playback.
5.Use the direction button on the remote control to select the desired option. Press ENTER to select the
option or press the ► button. Playback will now commence.
6.After playback, press the EJECT button on remote control or EJECT button on TV/DVD to remove the
disc.
Note: No function‘’ will sometimes appear on the screen after a button is pressed. This indicates that the
function is not supported at the current time.
Feb 14, 2009 | Proscan 32LA30Q Television
Recordes but dont play back
before you can watch a recorded DVD on another DVD player you must finalize the disc. to finalize the disc put the recorded disc into the DVD recorder, when the DVD loads it will show the titles that are recorded on the DVD on the screen
push the stop button it is the button with the square on it. the screen will go blank or it may let you watch whatever tv channel you are on if you have your tv ran through the recorder, push the setup buton a new screen will come up, with the arrow down button scroll down and highlight disc edit, press ok another screen will come up, with the arrow down button scroll down and highlight "finalize", press "ok" it is the button in the middle of the arrow keys
scroll up and highlight "yes" press "ok" the recorder will finalize the disc and it can be watched on any DVD player, just remember when you finalize a disc you cannot add anything else to the disc.
Mar 02, 2008 | Philips Magnavox MWR20V6 DVD Recorder/VCR
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
DVDs & CDs will not play
If you are playing STANDARD CD or regular DVD that you have purchase and you are having this problem,your dvd player is malfunction;however,if you are playing DVD burner disc or a different dvd region disc(we are region 1 in U.S.) that is no going to work.Same thing for your CD burner disc,it might not work.
If you are using a rental dvd disc,check and see if there is scratches?If so,try to get one without that many scratches!
Joe
Jan 07, 2007 | Philips DVD Micro Theater Shelf System...
Apex Digital GT2015DV 20 in. TV/DVD Combo Logo
89 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
