Question about Candy 9 cu. ft. / 255 liter Upright Freezer CVSA280K
I have a 10 year old Candy Freezer. It seems to work properly - however the compressor (GL90AN) has a very high noise level and seems to remain on for a considerable time between the silent periods.
Freezer just stopped working
Is this a frost free freezer? If it is, and the compressor and refrigerant is good, the problem probally lies with the defrost timer. What the defrost timer does, at regular intervals, typically every 12 hours, shuts down the compressor and powers up a defrost coil to melt any frost that has built up on the cooling coils inside the freezer. It probally the small square box that you mentioned. Some have a hole where you can turn the cam to the timer and that should switch the power from the defrost coil to the compressor.
Hope this helps.
Jun 27, 2010 | GE 25.1 cu. ft. / 711 liter Chest Freezer...
The freezer has not been used for over a year,
The humming noise is most likely from vibration, check to make sure the freezer is level.
If it is level look in the back lower area there is a compressor, black component about the size of a bowling ball, make sure nothing has fallen on it or touching it causing the noise.
Apr 23, 2010 | Whirlpool 19.6 cu. ft. Upright Freezer...
Loud buzzing noise doesnt stop freezer is still working everything still frozen, just loud noise coming from back bottom of freezer where the parts are, and compressor is very hot to the touch. freezer is...
Locate what is making the noise. There is a fan in the freezer behind the rear cover inside. There is a fan underneath accessed from the rear behind the cardboard backing. The compressor is also there with a starter/overload relay which could make the noise.
Aug 20, 2009 | Frigidaire 20.6 cu. ft. Upright Freezer...
Freezer stopped cooling.
I hope the compressor isn't trying to come on. Best bet is to call a tech. If it is much ollder than 10-12 years old, you may be seeing the beginning of the end.
Feb 17, 2009 | Freezers
Freezer compressor not able to start and noisy.
It sounds like the compressor is locked (seized). The current overload is doing it's job by opening the circuit. Take a current reading, on the common leg, while the compressor is trying to start. The locked rotor amps (LRA) for that compressor will be indicated on the compressor tag. If it's drawing LRA while trying to start, you need a new compressor. Which is the costliest part in that unit and requires specialty tools to replace.
Mar 30, 2017 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezer not working
I have a Kenmore Freezer model # 253.9251310 serial # s510347256
10\95 Makes all kinds of noises and now is defrosting. Sounds like fan is working but no noises besides fan. any ideas
Dec 12, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Maytag freezer
sure its on ly 3 years old. you rseled system should be covered for 5 years (compreessor, freon, evap, condesor). was it making a buzzing noise?? trying to start and clicking right off??? thaose are sounds a bad compressor makes,
Mar 19, 2008 | Maytag Freezer MQU2057
Noisey fridge freezer
Please check the fallowing:
-Loose flooring or floor not firm.
- Cabinet not level.
- Tubing in contact with cabinet, other tubing or other metal.
- Drip tray vibrating.
- Fan hitting another part or worn fan motor bearings. Unplug the unit and rotate fan manually by your finger.
- Compressor mounting grommets worn or missing; mounting hardware loose or missing.
- Free or loose parts causing or allowing noise during operation
- Check compressor it may contact with tubing or other parts.
- Check the body of your unit is not touching the wall or other object
Jan 25, 2008 | Freezers
Sides of freezer extremely hot
if there is air getting into the freezer because the door is not sealing properly the unit will run because it is sensing it is not cold enough inside. your unit releses the heat from the refrigerant through copper tubing that runs through the cabinet, and thats why it is hot. you need to level the unit make sure the door is sealing on the top bottom and both sides ansd then the freezer will work properly and be able to shut off after it has come down to the proper temp.
Aug 05, 2007 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Candy 9 cu. ft. / 255 liter Upright Freezer CVSA280K Logo
49 people viewed this question
Top Candy Freezers Experts
Dennis Boxerman
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Are you a Candy Freezer Expert? Answer questions, earn points and help others
