How do i find the settings menu?i don,t have a remote control for it for a VHS JMBD1020, if i need a remote where can i get one from.
  • Sandra Howley Jul 11, 2010
    thnx for your info,i have ordered a remote,once again thank u.
    Brigadier General:
  • 7,191 Answers
    but do i need one or is there a button i can press instead of using a remote.
  • AliTech110
    AliTech110 Jul 11, 2010
    Many thanks for the reply.
    You will require a remote control to access and use the settings menu.
    Thanks once again.
Need code for fox 400 to JVC HR-VP70U VHS
2879,2860,2899,2858. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
http://electro-medical.blogspot.com/
Feb 22, 2014 | Fox 400 ex universal tv/vcr/cbl/aux remote...
Want to record VHS to DVD on my Toshiba DVR620KU but do not want to connect to my TV set. Is this possible? My TV is older and does not have the input/output jacks. I just want to put in a VHS tape and a...
If the entire VHS is full then you can easily transfer the VHS contents to the DVD. The video will play while it is recording onto the DVD, but you don't have to have it hooked up to any TV for it to record. Now if you don't know how long the VHS content is that you want to record to DVD, then you will have to hook up the player to a TV so that you can press stop when you reach the end of the content you want recorded. At least this is true in the way that I use to transfer VHS to DVD:
1) Turn on the unit
2) Insert VHS tape
3) Insert DVD-+R or DVD-+ RW
4) Using remote, press VCR
5)Using remote, press play then pause the tape where you want to start recording.
6)Using remote, press DVD
7) Using the remote, press DUBBING. The VHS should start to play and the DVD should start recording
When using this method, don't hit the RECORD button!
I hope this helps!
Sep 05, 2011 | Toshiba DVR620 DVD Recorder/VCR
How do i unlock the panel lock on samsung portable combi tv vhs model no:TE-14N5
Hello
Unlocking your Samsung TV requires access to the Samsung TV service menu, which will allow you to reset or remove any previous lock in the settings. In order to unlock your Samsung TV you will need your remote control. All you have to do is simply follow the instructions provided below and you can use the service menu to guide you from there. Also note that upon entering the Service Menu, all User Menu settings will revert to factory default
Steps To Unlock A Samsung TV 1. Turn the power off.
2. On the remote, press Mute followed by 1, 8, 2, Power in sequence.
3. You should now see the service menu. To exit the Service Menu always select RESET.
You must have its orginal remote control with you to perform these functions. If you haven't it with you, contact Samsung Electronics at your country.
OK.
Jan 07, 2011 | Samsung CXJ1352 13 in. TV/VCR Combo
Can i setup my samsung bdc5500 without a remote control
Answer is NO.
most dvd needs to be set by remote control, because they don`t have a menu access botton on the set.
look at E-BAY for a remote control for its kind.
Aug 26, 2010 | Samsung BDC5500 Player
Remote will not control DVD/VHS
Tries change with new bateries,clean the The IR infered in the DVD/VHS combo unit,and the remote.
Aug 16, 2009 | Panasonic DMR-ES35VS
No remote - toshiba vhs w522
Unfortunately, many models are now without menu buttons. You will probably want to go to the Toshiba website and request a replacement remote, or try to find a remote that will work with all toshiba models.I don't recommend a universal one, only because they can sometimes be junk, if they are intended to control many different kinds of devices. You may want to try a single-device universal remote instead.
Mar 16, 2009 | Toshiba W522 VHS VCR
Need remote code to control a Panasonic Omnivision VHS PV-M2079 TV/VCR combination
You need to program the VCR (which turns the sey on/off) as an aux, then program any Panasonic TV type for TV, and then set the STB button to control STB, TV and AUX and you should be set.
Jan 03, 2008 | Televison & Video
How to program a universal remote to an older vhs tape player
i have rc 150 remote controll.its broken.where can iget the code for this controll
Oct 21, 2007 | Toshiba CT-90157 Remote Control
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
Electro Med Services...
