Question about Maytag Dryers
My Dryer does not turn on anymore. When I press
My Dryer does not turn on anymore. When I press the button it gives a series of clicks (similiar to a starter when it goes out on a car) Is it the motor or something different? Model # pyet344aym
  • Maytag Master
  • 43,501 Answers
There can be many reasons why your dryerMy Dryer does not turn on anymore.  When I press - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_tMy Dryer does not turn on anymore. When I press - 2_bing.gif
Dryer Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Jul 11, 2010
Not sure of year but i have a Maytag Performa, Model #PYE2300AYW and serial # 107-861-51YY..It wont do anything when I press the button to start the dryer it doesnt click anymore. I think it could be some...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 28, 2011 | Dryers
My kenmore 80s series dryer makes a clicking noise when I press the button, I dont believe its the belt based on what Ive read, help please?
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
heatman101
Mar 19, 2011 | Kenmore Dryers
Kenmore 80 series that does not dry anymore. Will not run anymore.
Dryer Repair - The
Dryer Repair - The
heatman101
Dec 20, 2010 | Kenmore Dryers
Left mouse click quit working
Hi
If this a laptop touchpad mouse button, I've had a similiar problem with a older laptop, the button was not getting touched properly, I had to press it harder a few times and it eventually started to work again.
There maybe something in between case and the button that is perventing it from being pressed completely.
If this doesn't help, try using a external usb mouse for example.
The laptop might need to be taken apart and the touchpad buttons looked at and possibly cleaned or the buttons / whole touchpad replaced to sort out the problem.
Thanks and good luck, let me know if you need further assistance.
Ekse
Aug 14, 2009 | Computers & Internet
Dryer will not turn on although the timer is working
IF your hearig a click when you push the start button then the button and relay are good check the saftey switch on the door to see if it has come loose and follen down or moved back if the switch is not pressed the motor will not work also I have seen the switches go bad you need to unplug the dryer and cross the too wires togeather plug the dryer back in and press the start button if she starts order a new swith. The motor could also be bad you nees to remove the back cover and check to see when the button is pressed if you are getting the correct voltage you will need a volt meter to check this they cost around 10- 20 bucks if you have correct voltage from the wires and the conections to the motor are ok the motor is no good and needs to be replaced hope this helps...
Jul 07, 2009 | Kenmore Dryers
Kenmore Dryer 90 Series will start but suddenly stop...
Hello , Sounds like your motor is over heating , it will run until the sensor shuts it down from getting to hot , it is most likley because the motor is covered in lint and needs cleaned. Hope that helps.
Dec 30, 2008 | Dryers
There is a clicking sound when you press start.
If you heat a click when you push the button,but the drum doesnt turn your belt is broken. About $15 and simple to install.
Oct 20, 2008 | Kenmore 63942 Dryer
My dryer won't work
set middle dial to 120 (minutes), or 90 or 60 minutes.  press the start button in and the half load button in.  that should do it.
Oct 15, 2008 | Malber WD1000 Front Load Washer/Dryer
Kenmore 80 series - quit working - no noise when I press the start button
Check the door switch in the upper right of the door frame. Ours snapped off so the door wasn't contacting the switch anymore.
Oct 07, 2008 | Kenmore 63942 Dryer
Notebook utilities
If you are using Windows XP then go to Screen Saver tab of Display properties. There you can turn on hiberation under the Power Setting command.
The shortcut to it is when you click "turn power off' and you get Standby, turn off and Restart buttons. Now press the shift key, the standby button will change to Hibernate.
Feb 03, 2008 | HP Pavilion ZE4300 series: 1170B01-90...
Dryers Logo
46 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
