Question about ViewSonic E70f (White) 17 in.CRT Conventional Monitor
Monitor viewsonic 15
Monitor viewsonic 15" power LED flickring and no display
  • 11,361 Answers
Posted on Jul 11, 2010
We have a Viewsonic VA2226W that goes to black screen after 15 seconds or so, is it toast or is there a way to fix?ViewSonic monitor VA2226w
Make sure you are supplying a valid timing mode to the display. Call ViewSonic technical support to resolve your issue.
Oct 01, 2014 | ViewSonic VA2226w 22" Widescreen LCD...
My Monitor ViewSonic E70fSB 17" Monitor is working
Causes of OSD LOCK
1. The monitor is incompartible with the system unit, especially for newer version units versus older monitors
2.Older monitors display attempting to much up to the improved definition functions of newer system units display an operating system malfunction, interpreted as monitor malfunction instead. OPERATING SYSTEM DISPLAY MALFUNCTION
hardware checks
1. consider changing the graphic card on the system unit after attempting to adjust the appearance settings on the desktop once the computer is powered on.
2.Once changing the graphics card on an old system unit, consider changing the processing chip for reasons of achieving peak performance of the new part installed.
3. Once the fxing of the parts are complete, the monitor would continue to display OSD requiring entire system restart or book. after which, adjusting the appearance setting that should by which time display new list capacities due to the new device changes
Dec 06, 2010 | ViewSonic E70f 17" CRT Monitor
VA902b Viewsonic monitor just went black this morning while working. Tried updating driver. Reboot. Does display during startup and goes black again. Monitor problem or hardware? I have 2 monitors.
The best thing to do to isolate the problem is to connect the problem monitor into a known working CPU. If the same problem occur, then the problem is the monitor. You may need to check if the power light (LED) is blinking or no light at all.
If there's no light, you may start replacing the power cable if the cable is detachable. But if it's built-in to the monitor, then send it to the authorized repair shop. They need to check if the panel is shot.
Thank you and good luck!
Nov 01, 2010 | ViewSonic VA902b 19" Monitor
No display on monitor when powered,Light is on.
change caps 1000mf-10v to 1000mf-25v in power supply and 470mf-10v to 470mf-25 or 16v.
May 12, 2010 | ViewSonic E50C 15" CRT Monitor
Viewsonic VG2021m Image Vanishes on Start Up
It is the picture picture board on your monitor that is malfunctioning, since the power led or button is on, but the display screen goes blank after a few seconds, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity or any service center to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
May 07, 2010 | ViewSonic Graphic VG2021m LCD Monitor
Vx900 no video display or on screen display. When powered up video signal displays for less than 1 second and then is gone. Power LED is stays solid green on, have tried other monitors and video signal is...
This monitor has a back-light problem and it could be a faulty inverter board or a faulty CCFL lamp.
For service parts and DIY info, check out LCD Parts, please click on this link to their WEB site :-
www.lcdparts.net
Feb 17, 2010 | ViewSonic Computers & Internet
I have a compaq 15" monitor which has no display.
1.poewr LED blinking or not.if in case LED blinks one time. problem in LOT .Cheak horzontal Transistor also.
1a) power out put voltages
2.drypoints in neck board.
3.cheak display cable.
Dec 19, 2008 | SAMTRON 55V 15" CRT Monitor
Blinking Light
This is the same problem with my 4 VG800 Monitors, you should be able to find the correct capacitor on your monitors by following the same procedure, I'm sure the boards are similar. Just get the correct value capacitor and try it in parallel with the initial filter capacitors right after the DC power in.
Alright, I had 4 VG800 monitors with the exact same problem. The front led is blinky OR constant reddish/orangish OR picture is white with colored vertical lines OR no picture with whistling from the back of the monitor and backlights illuminated. All problems have the same solution. You need to disassemble the monitor (2 screws on the back, remove lower front button panel, remove 2 screws holding panel in and remove speakers, then remove panel and unplug speakers. Now remove lots of tape and screws from the cover in the center of the monitor). Now that you've exposed the amplifier board and the VGA to LVDS board, you want to look for the pair of 25V 100microfarad capacitors that are nearby the DC power in (they are right next to the black "100" inductor). Desolder the capacitor farthest from the DC jack and replace with an electrolytic with the same specifications. If you want to check that this is the correct solution please put the new capacitor (WATCH THE POLARITY) in parallel with the capacitor there want watch the front panel indicator go green and the monitor work properly.
I'll be posting and Instructable entry in the next few days on the process, watch for the username Waterppk on the website www.instructables.com
-Chris
Dec 11, 2006 | ViewSonic VX910 19" LCD Monitor
ViewSonic E70f (White) 17 in.CRT Conventional Monitor Logo
Top ViewSonic Computers & Internet Experts
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
