Question about Zanussi Ovens
Could you tell me what error code 003 is for a zanussi zbd 903 built in double oven
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 174 Answers
This code is displayed when the user attempts to restart the appliance after an
error code 001 or 002
- Safety circuit malfunction
001 if the meat probe is open circuit or the temp of the food is over 100deg c
002 is if the meat probe is short(closed) circuit hope this helps
Posted on Jul 18, 2010
The setup routners for the tally odbc driver odbc could not be loaded due to system error code 193
Posted on Sep 29, 2012
GE monogram double oven . Self cleaning top oven and F9 in red showing and beeping noise
F9 is a problem with the oven door lock circuit. If the door is locked, it's probably a bad switch that tells the oven it's locked. If the door isn't locked, it's probably a problem with the lock mechanism.
A common problem on many built-in GE ovens (you don't say if yours is built-in or free standing...) is air circulation in the control panel. The fan that keeps the panel cool either stops working or gets clogged with dirt/dust and can't move any air. This causes the panel to overheat and can cause all kinds of odd problems and error codes. If you have a built-in, check to make sure the fan is working and the mesh screen behind it is clean.
Jul 17, 2016 | GE Monogram ZET3058SHSS Stainless Steel...
LG double oven shows f9 code in both ovens
Nov 19, 2013 | LG LWD3081ST Electric Double Oven
F9 error code
F9 is a problem with the oven door lock circuit. If the door is locked, it's probably a bad switch that tells the oven it's locked. If the door isn't locked, it's probably a problem with the lock mechanism.A common problem on many built-in GE ovens (you don't say if yours is built-in or free standing...) is air circulation in the control panel. The fan that keeps the panel cool either stops working or gets clogged with dirt/dust and can't move any air. This causes panel to overheat and can cause all kinds of odd problems and error codes. If you have a built-in, check to make sure the fan is working and the mesh screen it is clean.
Oct 24, 2013 | LG LWD3081ST Electric Double Oven
F9 error code
F9 problem with the oven door lock circuit. If the door is locked, it's probably a bad switch that tells the oven it's locked. If the door isn't locked, it's probably a problem with the lock mechanism.
Sep 07, 2013 | LG LWD3081ST Electric Double Oven
Should my new zanussi built in double oven have a grillpan handle & oven tray provided?
It certaily should, if they are not with the oven, then I would contact the people who supplied the oven in the first place, and request the pan etc.
Dec 21, 2010 | Zanussi Ovens
I need a new Grill Element for my Zanussi Built in double oven, Model no is FM5232
If you are in the u/k,then I suggest you go to the zanussi web site,
WWW.SERVICEFORCE.CO.UK
Altrnatively, you could try a local deaer,whoo repairs cookers etc, they often have these sort of parts in stock.
Feb 03, 2010 | Zanussi Ovens
My oven wont get to temperature why?
If oven is getting hot , but not hot enough, then the thermostat is probably faulty.if no heat at all, then you need to replace the oven element.
Please rate my solution.
Thanks.
Sep 09, 2009 | Zanussi Ovens
ZANUSSI ZDQ 595 BUILT IN ELECTRIC DOUBLE OVEN
have you reset the clock after the power outage?
this is necessary before oven will work
suspect you have it on auto in error
Sep 30, 2008 | Zanussi ZHQ575 Electric Double Oven
Why does my oven keep switching off?
there is a casing stat which senses overheat. this can be due to lack of ventilation if a built-in type or a fault with the fan
Jan 27, 2007 | Zanussi ZDQ895 Electric Double Oven
Ovens Logo
390 people viewed this question
Top Zanussi Ovens Experts
ashburton
Flipper
Level 1 Expert
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
