Question about Sharp R-55TS Microwave Oven
Sharp R-55TS -- Top grill heater is broken in half. Is this part replaceable? Is it safe to use the microwave functions in the meanwhile?
MicrowaveSvc
  • 9047 Answers
SOURCE: faulty microwave
Since that's a European model, I don't have solid info on it.
If it's an inverter-equipped oven, it may be a problem with the inverter or magnetron.
Otherwise, I would first suspect this to be a door switch issue or a bad door switch mount.
You could try holding up or down (alternately) on the door to see if that changes the performance.
Another possibility is the damper. Normally they will run for 49 seconds and then stop when the damper system has a problem, but maybe a non-US market has different requirements...
Please see the diagram below for a typical convection damper system.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Dec 04, 2007
  • 93 Answers
SOURCE: Hi my sharp microwave model
Replaced the magnetron with the diode.
Posted on Aug 03, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: grille replacement
That is part number PDIF-B027/KIT (best to copy & paste that number) and you can get it from Tritronics.
Posted on Aug 08, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: faulty microwave function on the SHARP R-957 model (900watt)
This is a problem in one of the damper-related components, most likely the switch, but it may also be the motor or the damper door.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample photo for a typical damper assembly.
Info on ordering Sharp UK parts / spares is here.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Dec 13, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Broken vent grille for a Whirlpool microwave hood combination
You can find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
At our Web site, we have a video available showing how to remove a typical grille in seconds.
Posted on Jun 06, 2009
I have chefmate microwave and suddenly stopped working. it is showing 2:50 code on the screen only...it was working fine and dont know what happened to it and touch pad is not working..how do i make it...
HELLO.
The code on the screen indicate electric panel fault resulting from the touchpad malfunction.
The touch pad on your microwave oven acts as the brain of the appliance. It not only contains the buttons that you use to enter cooking settings and times, but also controls the function of the entire microwave. If the touch pad malfunctions or breaks completely, the microwave will cease to function. In this instance, the broken touch pad must be removed and a new touch pad must be installed, to restore functionality to the microwave.
1 Unplug the microwave from the wall outlet.
2 Remove the two screws, located on the front or top of the grill at the top of the microwave.
3 Pull the grill off of the microwave.
4 Remove the mounting screw from the top of the control panel.
5 Lift the control panel up and out to loosen. Look behind the control panel to ensure there are no metal tabs securing the control panel in place. If there are metal tabs, gently rotate the control panel to free the tabs.
6 Transfer the wires from the old control panel to the new control panel one at a time to ensure that the wires are properly installed.
7 Install the new control panel into the microwave and secure using the mounting screw that was removed.
8 Replace the grill from the top of the microwave and secure it using the screws that were removed.
9 Plug the microwave back into the wall outlet.
Thanks.
Sep 12, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
My r880f microwave has lost its microwave function only grill etc still works any ideas ?
It could be that the magentron has failed. Does it make a loud hum or buzzing noise when you try to use the microwave only function? If it does, chances are that the magnetron has shorted out. The replacement cost can be as high as the cost of a new oven, so it rarely makes sense to fix.
May 24, 2011 | Sharp Microwave Ovens
Door will not latch
Door catches.
One of the latches may have broken off and is not lifting the other latch clear of the housing. Remove from any power source, remove the cover of the cabinet. Slacken off the clamp mechanism and ease the clamp over the guide to allow the door to open. When a new door lever is in place, the door may be easily adjusted by slackening off the screws that clamp the door catch/actuators in place whilst holding the door closed and then tightening the screws. The rear of the door may be adjusted by slackening the lower door hinge screws and adjusting as required.
I hope that helps.
Feb 12, 2011 | Sharp R-55TS Microwave Oven
The food in the microwave is not heating up I have tested the fuse (F8AH250V) and found that it has blown. Is it safe to replace this fuse (F8AH250V) on my microwave.
Fuses seldom just go bad on their own, but it's safe to replace. Before you replace the fuse, squeeze the tabs of the fuse holder clips together a bit. Sometimes they don't grip the fuse tightly enough, and this can cause heating which damages the fuse. If the fuse blows again there is a bad part in the oven that will need to be located and replaced. For a small countertop oven, it's probably more economical just to replace the oven than to repair it.
Jan 02, 2011 | Sharp Microwave Oven Microwave Oven
Not heating food but will heat plate. wont pop popcorn. takes three times as long to heat food even if on a paper plate
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Mar 04, 2010 | Sharp R-55TS Microwave Oven
A wafer-like part (4" x 3 1/2" size) needs to be replaced
The part is called a "wave guide cover." the parts are model specific so be sure to order the correct one for your unit.
Apr 03, 2009 | Sharp R-55TS Microwave Oven
Sharp R-55TS Microwave Oven Logo
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Ed Mac
Jim Thurston
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
