Question about Keurig B50 Coffee Maker
How to descale
The Machine is asking me to descale. I know I should add vinegar, but am not sure if I should dilute it adn how long I should leave it in machine. Thanks very much.
    Guru:
  • 1,051 Answers
Use 1/2 cup white vinegar in 1 quart water. No need to let it sit. After descaling, remember to run at least 3 cycles with clean water to remove any vinegar.
Posted on Jul 11, 2010
Can I use vinegar to sanitize my coffeemaker ? By putting 50/50 with water in the water tank and starting the descaling-cleaning program.
vinegar can be used to descale but BLEACH will kill the mold better and diluted will not hurt the machine either
Mar 17, 2016 | De'Longhi Magnifica S ECAM 22.110.SB...
B70 does not brew,it says to descale
It may be clogged up with hard water scale. Fill the reservoir with white vinegar. Place an empty coffee mug in the unit and continue to run vinegar through it until the reservoir is empty enough that it is asking you to add more water. Leave the unit alone and let the vinegar stand in the unit for 8-12 hours. Fill the reservoir with water and run water through the device (you might want to do this several times in order to make sure the vinegar is completely gone).
Also check to make sure that the piercing unit is not clogged with coffee grounds.
Hope this helps.
Oct 04, 2014 | Keurig B70 Coffee Maker
How do you descale the machine
my machine has stopped working it sounds like the motor is still running, not sure where to buy the descaler can I just use vinegar?
Jan 28, 2011 | Krups Dolce Gusto KP 2100 Espresso Machine
Can you reuse vinegar fpr descaling purposes
Yes, if the vinegar has not been diluted. If you have used neat, undiluted vinegar then it can be decanted into a bottle or jar and used again to descale.
Jan 16, 2011 | Sunbeam Kitchen Appliances - Others
Not enough water making it from holding tank to dispensing cup
your machine is "Short Cupping"
It needs to be descaled. Even though the descale light might not be on yet, the descale light only comes on when it is in SERIOUS need of a descaling. You should descale once every 3 months.
Fill reservoir with distilled white vinegar and leave the machine on for 4 hours (make sure to turn off the auto off option).
after 4 hours, run the vinegar through the machine until the reservoir is empty. Refill with water and repeat twice. you will notice a difference right when you start running vinegar through.
Apr 04, 2010 | Keurig Elite B40 Coffee Maker
I have a solis 5000 coffee maker and would like to descale. the users manual says never use vinegar as it will harn the machine. It recomends a product called SOLIPOL, is there another product that you...
Hi
Starbucks used to carry a descaling product for their machines. Yes don't use vinegar because it is only 5% before you dilute it. It also leaves a taste for about 2 weeks that will affect the taste of your coffee. You can use Citric acid. 1 tablespoon per 32 oz of water. Use at least 2 table spoons. Dissolve the descaling solution so there are no crystals left. Now.
Turn the machine off and then push and hold the 2 buttons at the same time. While holding them down, turn the machine on.
Release the buttons and turn the dial counter clockwise till it stops.
This will keep the machine from heating.
If you push the steam button the pump will activate.
Open the steam knob. Run 8 oz through the wand and rekease the button. Let it set for 10 minutes, then open the knob again. Repeat until the tank is empty. Rinse with a whole tank of fresh water and your done.
If you have the Digital there is a program in the menu for descaling. There is also a program for resetting the descal mode so it will tell you the next time it need to be done. Chose yes and push the enter button. Also change your water hardness to 4. Descale more often than not enough.
Jul 15, 2009 | Solis SCDIG-5000 Coffee Maker, Espresso...
What is the dilution of vinegar to descale my machine
Hello bpplums,
When cleaning your units system you need to use a 2 parts water to 1 part vinegar solution. Run two fresh vinegar solutions through if its been a while sense the last cleaning. Then run through a couple pots of fresh water to rinse. You should be good to go. Hope this helps!
Positive feedback is appreciated. Kind regards, NormanZ
Jul 04, 2009 | Briel Chamonix ES-35 Espresso Machine
Expresso machine
descaling gonna improved the pressure = stronger coffee and clean the inner boiler =warmer coffee but use descaler only not vinegar descaler melt calcium vinegar remove some calcium in littlt piece 1 part descaler 1 part water fill the water container open valve for a few second close it leave it for 15 minute and repeat untill empty after rince very good that stuff is corosif
THANKS FOR USING FIXYA
FROM MONTREAL CANADA PIERRE
Feb 18, 2008 | DeLonghi BAR 14 Espresso Machine
Keurig B50 Coffee Maker Logo
418 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
