Question about GE WSXH208A Front Load Washer
Ge front load washer leaks from bottom
I have a ge front load washer that leaks from the bottom. it appears to be leaking from two small holes on the underside that are located on a small protruding square located on the front right side if looking at the washer from the front. if you elevate the right side it doesn't leak, but when level it seems to almost pour. i can't find any diagrams or schematics on the model so i'm afraid to rip it open and dig around without some guidance. i'm competent but also a worrywort. any advice would be most appreciated.
  • 1 more comment
  • gorockytop Jan 05, 2009
    ge front load leaks, replaced boocoming from behind counterbalancet seal but still leaks, look like it is
  • vickihasley Jan 13, 2009
    Our front loading GE Adora is leaking substantial amounts of water out of the very bottom front panel. It was flooding the carpet in an adjacent room until I discovered the problem.
  • Anonymous Feb 10, 2009
    I have an adora that is less than 2 years old...smell is bad enough, but now it leaks roughly half a gallon every cycle ran---not very energy efficient if the water is on the floor instead of cleaning my clothes...I did find a filter on the front that clogs easily, but did not fix the leak...Honestly, I will never purchase another GE anything, non the less a front load. I would rather pay a higher water bill, than the GE repair man bill.
Does the door shut tight? I had a leak due to the door latch solenoid not engaging.
Posted on Apr 22, 2008
  • 487 Answers
Full display
And for the part numbers look here
Have fun with it and please rate me on this site
Posted on Apr 20, 2008
I have a GE front loader washer that leaks from the bottom sometimes. It is not leaking from the inlet or drain hoses. Small weeping from bottom near the front. Are they prone to this? Does it happen...
Hi, Open the door, and with a flashlight carefully inspect the rubber boot between door and tub pulling it back. You are looking for a cut or tear at the bottom of the boot. Hope this helps.
Jan 17, 2011 | GE WSXH208A Front Load Washer
Water is leaking from the bottom and does not discharge from drain hose
Part of the problem is that your filter is clogged. Remove the front bottom panel by unscrewing 3 small screws at the base. At the lower right, there is a filter cap that you need to unscrew by hand. Be sure to put a small pail before you unscrew it because a lot of water will come out. Then clean the filter and screw it back in.
In terms of the leaking, that started with my washer just recently. It's not the filter....think it's the rubber seal in the front. If you pull back the rubber, there are small drainage holes that can get clogged. Cleaning helps, but doesn't solve it.
Feb 25, 2010 | GE WSXH208A Front Load Washer
Water is leaking needs a new seal?
The GE front load washer Front seal does have a common problem withe the front seal getting riped. Open the door and inspect the bottom half, you might find the hole. if not you will half to remove the bottom access area and locate the leak.
Jan 08, 2010 | GE WSXH208A Front Load Washer
Whirlpool Front load washer - Water leaking
I would check to see if you have a hole or crack in the rubber boot inside the door. Open the door and seperate the fold in the rubber boot and check for a leak. If something sharp was left in someones pocket it will get stuck in this part of the bood.
Dec 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water leaking under washer
check your seal make sure there are no small holes in it the smallest hole will cause problems make sure your door glass is clean anything like hair or dirt can cause a leak
Mar 09, 2009 | Kenmore 46462 Front Load Washer
Water leak at front of washer
You should have a drain at the bottom of the rubber boot inside the washer. There is a possibility the drain hose clamp came loose or the boot has a hole in it. If you take the front of the washer cabinet off, you should be able to see where the water is coming from. Take the two screws out of either side of the door opening, pull on both sides of the front panel at the same time, tilt downward, and the panel should come off.
Jan 19, 2009 | Maytag Neptune MAH5500B Front Load Washer
Water leaking from the bottom of the washer at the rear right corner!
firstly check that the inflow water pipes connected to the machine are connected correctly, feel around the pipes that touch the machine to see if there is any water. If there is the washers may need replacing on the pipe. Or the pipe may simply have got a bit loose through the machines spinning.
Oct 20, 2008 | GE Energy Star WCVH6260F Front Load Washer
The Washer seems to continually leak.
Remove lower front axcess panel and check where leak is. Also check door boot for any tears,holes.
Jan 16, 2008 | GE WSXH208A Front Load Washer
GE WSXH208A Front Load Washer Logo
4,238 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
