Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
Bissell pro 2x the cleaner solution & water
Bissell pro 2x the cleaner solution & water is slow & very weak, all tubing & lines are clean.
  • Bissell Master
  • 43,501 Answers
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
shg
Posted on Sep 30, 2010
Brushes don't rotate on proheat2X,
How to Replace the Belt & Brushroll on Bissell ProHeat 2X ...
? 2:11
https://www.youtube.com/watch?v=Jj_43IHz9U4
Dec 28, 2012 - Uploaded by eVacuumBags
How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... How to Replace Bissell Deep Cleaner Pump Belt orBrush Belt - Duration: 1:44. ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
Brushes Will Not Rotate Deep Clean Essential - YouTube
? 0:53
https://www.youtube.com/watch?v=gbEXY5jkWSc
Apr 9, 2015 - Uploaded by BISSELL
If your machine is turned on and in the upright position yourbrushes will not turn. ... How to Replace the Belt & Brushroll on Bissell ProHeat 2X Series Carpet ... Won't SPRAY solution Rollers spin Fixing Bissell ProHeat Carpet ...
bissell pro heat 2x brushes wont spin Questions & Answers ...
www.fixya.com > Forum > Tags
... bissell pro heat pet 2x and my brushes won't turn or operate... check the belt belts ok brushes won't turn/rotate turn dial on bottom front on the water tank to ...
Feb 03, 2016 | Vacuums
Bissell pro heat 2X pet will not spray water.
Bissell 2X machines all seem to do this after 4 or 5 uses. It's a bad solenoid. Most vac shops won't touch the 2X with a 10 foot pole. Get a Hoover 5914 and stay problem free.
Oct 18, 2013 | Bissell 9500 ProHeat 2X CleanShot Upright...
My Bissell Pro Heat 2X steam cleaner is not releasing the water
Have you tried cleaning out the small filterfrom the reserve tank? Also, check the tank/resevoir valve is operating properly, when you take it out to fill try to make water release from tank.
Apr 29, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
I can't get the brushes to rotate and the water to spray on the bissel pro heat 2x.
I have a Proheat 2X and had the same problem. I tried the Water Rinse setting and found water came out and was suctioned properly, but on the Light Clean, Normal Clean, and Heavy Traffic settings, the unit failed to do anything. Problem may be with leaving the soap dispenser in-place, which might scum up the tubing.
SO, an alternative to throwing out my unit and buying somethign else was to put one capful of the Bissell soap in the water resevoir and keep the unit on Water Rinse. IT WORKS BEAUTIFULLY NOW. Don't know if this will help, but at least I didn't have to buy a new unit. Rinse everything after using and there's been no problem.
Apr 24, 2010 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell pro heat 2x not releasing water or cleaner
heatman101
bxnbx
Oct 05, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
I need instructions for bissell pro heat 2x cleaner
you can dawnload it from the manufacture,s website.you should go to there and dawnload it.
Sep 11, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9200 plumbing
do you have photos of how to re hook up the interanal water plastic tubes inside the 9200 PrHeat 2x cleaner by Bissell.
Aug 27, 2009 | Bissell 9200 Upright Vacuum
I have a bissell pro heat water wont come out
The pump may spin but the vanes inside could be broken or worn enough that they are unable to push water through the pump system. I am repairing a Bissell Model 8920 Pro-Heat 2X that has this very same problem.
I tested all the hoses to verify that they were not plugged. I then hooked the water and cleaner tub from the rear directly to the pump and held it above the pump assembly and water barely went through it with gravity feed and the pump was visibly spinning. The pump assembly can be acquired from AE Carters for $10.00.
I do not give any guarantee that this is the only problem.
Ron Goodrich
May 16, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Lost manual for bissell pro2X rug cleaner can I get inst. on line?
hi,
Just recently purchased proheat 2x rug cleaner ,miss placed my manual and can't get the water sucked up . Please Help
Thanks
Jun 26, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
141 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
