Question about Jura Capresso Impressa X7 Espresso Machine
Malfunction 8 ? It alerted with the malfunction 8 signal and it will not start nothing
F4i honda 2001 light is flashing 7 times on diagnostic code {fi light} then staying on does anybody know what 7 blinks mean
7 = Coolant Temp sensor or wiring.
A long blink = "10"
A short blink = "1"
DNS = Engine does not start
EON = Engine operates normally
BLINKS : PROBLEM, SYMPTOMS
No blinks: ECM malfunction, DNS
No blinks: ECM power / ground circuit malfunction, DNS
No blinks: ECM output line malfunction, DNS
No blinks: MIL circuit malfunction, EON
Stays lit: Data link circuit malfunction, EON
1 blink: MAP sensor circuit malfunction, EON
2 blinks: MAP sensor performance problem, EON
7 blinks: ECT sensor circuit malfunction, Hard start at low temp
8 blinks: TP sensor circuit malfunction, Poor performance on quick throttle operation
9 blinks: IAT sensor circuit malfunction, EON
11 blinks: Vehicle speed sensor circuit malfunction, EON
12 blinks: No. 1 Primary injector malfunction, DNS
13 blinks: No. 2 Primary injector malfunction, DNS
14 blinks: No. 3 Primary injector malfunction, DNS
15 blinks: No. 4 Primary injector malfunction, DNS
16 blinks: No. 1 Secondary injector malfunction, DNS
17 blinks: No. 2 Secondary injector malfunction, DNS
18 blinks: Cam pulse generator, no signal, DNS
19 blinks: Ignition pulse generator, no signal, DNS
21 blinks: No. 1 O2 sensor circuit malfunction (California only) , EON
22 blinks: No. 2 O2 sensor circuit malfunction (California only), EON
23 blinks: No. 1 O2 sensor heater malfunction (California only), EON
24 blinks: No. 2 O2 sensor heater malfunction (California only), EON
33 blinks: E2-PROM in ECM malfunction, EON
48 blinks: No. 3 Secondary injector malfunction, DNS
49 blinks: No. 4 Secondary injector malfunction , DNS
Aug 30, 2014 | 2001 Honda CBR 600 F(4)i
2001 ford escape won't start
If you mean "no crank", possible starter issue. check for 12v at the starter signal lead during crank, replace starter if signal is good.
Feb 23, 2014 | 2001 Ford Escape
I have a 1996 Chevy Suburban And Turn signals don't work, brake lights don't work, high beam headlights work, low beam headlights doesnt work what could be the malfunction.
Check the fuses for continuity using the tone alert on your digital ohm meter; you don't have to pop the fuses out. Then I would check the turn signal relay.
Dec 08, 2013 | Cars & Trucks
How do i get service code alert off my nissan tinos screen please its not on the list Nissan Tino
Hi there.I think i can help u to turn off service alert, Its done in the following way:-
1.Switch ignition on ( do not start engine )
2.Switch radio ON.
3.Start engine.
4.Switch radio OFF.
5.Press and hold INFO button.
6.Turn volume control knob at least 30 clicks until self dianostic menu is displayed and an audible
signal is heard. ( while still holding the INFO button )
8.Using the circular dial ( Joystick ) select Confirmation/Adjustment and press centre of joystick
to ENTER.
9.Select Service and press ENTER.
10.Select Reset and press ENTER
11Press BACK button to return to main menu.
12.Switch OFF ignition
This should do the job, sorry it`s so long winded
Good luck John ( South Wales UK)
Aug 02, 2011 | Nissan Altima Cars & Trucks
Won't start. No spark. Suspect oil alert.Only ran twice out of box. Had to buy another generator as I couldn,t take the time to fiddle. 10 or 15 yrs. ago.
That is easy enough to tell if it is the oil alert malfunctioning by disconnecting the wire that goes to the oil alert and making sure the wire is not grounded and check for spark.
Mar 11, 2011 | Electronics - Others
My motorola has an emergency alert button on top, when pressed and held it sounds an alarm on all other radios near it. we pushed it to test and it works well and is a cool feature. however, the call tone...
Your radio may be functioning normally for the emergency alert. Here is an excerpt from the user guide:
Emergency Alert Mode
The Emergency Alert feature can be used to signal members in your
group of your need for urgent help. MR series radios will operate in an
automatic "hands-free" emergency control mode for a total of 30
seconds after activating the Emergency Alert. MR series radios in your
group will automatically advance the speaker volume to the maximum
setting and sound a warbling alert tone for 8 seconds. The alert tone is
emitted from your own radio speaker and the receiving radios in your
group. After the 8 second alert, any spoken words or incidental sounds at
your end will be transmitted to the group for 22 seconds. For the 30
second duration of Emergency Alert mode, MR series radio controls and
buttons will be locked to maximize reception of the emergency message.
1. Press and hold the Emergency Alert button for 3 seconds.
2. Release the button after the LED Indicator glows red and the alert tone
begins to sound. There is no need to continue to hold the Emergency
Alert button or use PTT for your message to be transmitted.
3. After the alert tone ends you may speak into the microphone. Your
voice or incidental sounds will be transmitted. The LED indicator will
continue to glow for the duration of the 22 second period.
4. After 30 seconds your radio speaker will emit a Talk Confirmation
Tone and the LED Indicator will extinguish. Operation then returns to
normal two-way mode.
Note: All Motorola Talkabout EM, MJ, and MR series radios are fully
compatible with the Emergency Alert feature. Radios other than EM, MJ,
MR series can receive the emergency alert signal, but will not respond
with adjusted volume settings, locked controls, or a warbling alert tone.
Users of other radio models set to the same channel and Interference
Eliminator Code will hear a steady tone for 8 seconds followed by the
voice transmission for 22 seconds.
Warning: The Emergency Alert feature should only be used in the event
of an actual emergency. Motorola is not responsible if there is no
response to the emergency alert from the receiving group.
Here is a link to the user guide: http://www.giantintl.com/ContentManage/manuals/Moto/MR350-351%20User%20Guide%2012-16-08%20KEM-PK14190-90.pdf
Best regards.
Oct 22, 2010 | Motorola MR355R Two Way Radio
Can i fit an indian chief rear fender on my 98 fatboy softail
i hope this helps
5. Brake system alert – the notification is powered on if the ECU detects a problem to the brake system
6. Warning light – it signals an unidentified problem with your car; it usually requires the car to be serviced
8. Tire pressure monitor – the warning is turned on in case of low tire pressure which could raise the fuel consumption or affect the grip
24. Powertrain malfunction – if on, this light shows that the powertrain has been damaged and the car needs to be serviced as soon as possible.
Apr 06, 2010 | 1993 Harley Davidson FLSTF Fat boy
Oven door is open, but F9 now signals, trying to turn on
HI. this F-9 code is signaling a major door mechanism malfunction. the best action is to replace the entire door latch assembly. this will heel the F-9 alert and, fix the problem you are experiencing at this time.
Please rate and, have a great evening:)
Jun 16, 2009 | Amana AOCS3040 Electric Single Oven
DL F signal
Hi, this is a failed door lock alert. the FdL code represents this malfunction in the door lock mechanism. the unit will not operate if the door lock cant engage the latch. replacing the door lock mech will fix this issue.
Jun 05, 2009 | Kenmore Elite 45986 Front Load Washer
LRD6399SWS
LED Display gives you your display visual alerts, signal strength, and operation mode. Here is an attached link for the manual.....http://www.uniden.com/pdf/LRD6399SWSom.pdf
But to answer your question here is what the difference between the green light and the red light are:
1. X-Band Signal Indicator—A green LED lights and blinks to
indicate the presence of an X-band radar signal. The blink rate
increases as the radar source gets closer. A distinct audio alert is
also heard.
2. K-Band Indicator— An amber (orange) LED lights and blinks to
indicate the presence of a K-band radar. The blink rate increases as
the radar source gets closer. A distinct audio alert is also heard.
3. Ka-SuperWideband Signal Indicator— A yellow LED lights and
blinks to indicate the presence of a Ka-SuperWideband radar
signal. The blink rate increases as the radar source gets closer. A
4. Laser Signal Indicator— A red LED under L lights and blinks to
indicate the presence of a laser signal. A distinct audio alert is also
heard.
5. SWS Signal Indicator— When an early warning hazard or
informational signal is detected, the yellow SWS LED begins to
blink and the amber K-band LED lights. A distinct audio alert is
also heard.
6. Power-On Indicator— A green LED under P lights to indicate
power is being supplied to the unit and the unit is turned on.
7. LED Signal Strength Meter—Four LEDs give an accurate visual
indication of the strength of radar or laser signals.
8. City Mode Indicator—A green LED under C lights to indicate
that you selected City Mode.
9. Auto Mute Indicator— A red LED under M lights to indicate that
you selected the Auto Mute feature.
Please make sure you give me a rating and I hope this helps,
cbinny1
Oct 18, 2008 | LRD6399SWS Radar Detector
Jura Capresso Impressa X7 Espresso Machine Logo
59 people viewed this question
Top Jura Capresso Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Steve
Are you a Jura Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
