Question about Kenmore 62602 Electric Dryer
My gas dryer will not turn the clothes drum - Kenmore 62602 Electric Dryer
  • 10,319 Answers
The drive belt that turns the drum has broken off or fell off. Sears does sells these belts in a kit forn including the tensioner pulley. Purchase that. The top and front panel will need to come off to do this repair
Posted on Jul 11, 2010
Have a 2780 dryer stackable that is leaving grease/burn streaks on my clothes. it seems that lower front of drum is not sitting flush. there is a gap against the wall where clothes or dryer sheets get...
you need replace drum support roller,an check to make sure drum hadnt cut into back are the front of dryer the felt that drum roll around on may allso need be replace.some ge dryer have single bear it roll around on it attack to back of the dryer drum
Feb 28, 2018 | GE WSM2780DWW Unitized Spacemaker Washer...
Maytag gas dryer about 10 years old leaving black smudge marks on clothing. The wheel was hanging up on the dryer drum. Could there be other causes for the smudge marks?
your clothes are getting caught between the drum and the rim due to bearings out of the wheel guides. These guides are what the drum rests on when it is turning. Most dryers you can access these guides by taking the front off the dryer. Not a big expense just a little difficult to get to .
Apr 12, 2011 | Dryers
Brown marks left on clothing -- occasionally My dryer is not gas but electric but that wasn't a choice on here.
If your clothes get marked or torn in your dryer, check these: Rollers Rear seal Front glides Front seal Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Aug 01, 2010 | Whirlpool Duet Sport 6.7 Cu. Ft. Gas Dryer
Clothes get caught in-between the drum and where the drum rest at the front of the dryer and all the cloths have rust colored mark on them.
What is happening is the drum moves parallel to the door opening and drum liner. When the drum shaft gets wear, the drum tilts away from the drum liner. This creates a space through which your clothes fall into. The drum turns and your clothes wedge in this gap and become damaged from rubbing the interior liner.
To fix this is simple. Remove the front dryer cover and there will be 3 screws holding the drum to the shaft. There are plastic bushings to replace and then your drum will fit tightly against the liner. It may be a good time to replace the liner to insure a good seal.
Remember to turn off the gas at the appliance or unplug the electricity to the unit.
Servall is a supplier of appliance parts, and the Service dept. of Sears fir Kenmore, etc.
It should take an experienced repairman with the tools between 1 and 2 hours to fix.
Sep 13, 2009 | Dryers
Maytag Performa PYE G2200 gas dryer, the dryer seems to turn on but the drum will not turn.
Based on the information provided, it sounds like a broken drum belt is at fault. Below is an illustration of the drum belt.
http://www.repairclinic.com/SSPartDetail.aspx?s=t-PYG2200+-%3d%3di529597&PartID=529597
Here is a parts/disassembly diagram:
http://www.repairclinic.com/Dryer-Gas-Maytag-Style-Appliance-Diagram
Here is a belt installation diagram:
Dryers have a drive belt that turns the clothes drum. If the belt breaks, the drum stops rotating. Then you need to replace the belt, and often the idler pulley, because the pulley tends to wear out at the same time.
Click here for a belt installation diagram.
All links courtesy of www.repairclinic.com
Aug 16, 2009 | Maytag Dryers
GAS DRYER, JUST REPLACED BELT BUT DRUM WILL NOT TURN WITH CLOTHES IN IT.
My guess: bad motor bearings which let the rotor move off-center and bind.
Usually the motors are not repairable
Apr 25, 2009 | Dryers
Hi I am trying to clean my drain unsder my washer. I do not know how to pull the cover off.?? It appears I need special alan wrenchs for two little screws..?? any ideas??
Though the idea of repairing a clothes dryer can be pretty intimidating, the truth is that some types of repairs are surprisingly easy. Yes, dryers appear to be built like huge, impervious metal boxes, but they are typically pretty easy to open and relatively simple to fix.
As shown at How Clothes Dryers Works, a clothes dryer has a motor that turns a big drum containing the clothes, a heat source for blowing warm air into the drum to dry the clothes, and controls for operating the motor and heat source.
Some dryers have an electric element to do the heating while others utilize a gas flame; the latter must be vented.
Clothes dryer problems generally occur because the heat source doesn't heat properly or the motor fails to turn the drum.
If a gas dryer doesn't dry properly, the first thing to check is the pilot light or igniter--it may not be lighting the burner. The second thing to check is the dryer's vent-if it is clogged with lint, the heating system won't work properly.
Pay attention to basic safety measures when working on a dryer. Always unplug the dryer, and turn off the gas supply to a gas dryer at the appliance shutoff valve.
As with most appliances, maintenance will keep your dryer purring. Clean the lint trap after every load, and clean the vent system once a year.
Dec 13, 2008 | Whirlpool LTE6234D Top Load Stacked...
Gas clothes dryer not drying clothes
could be an ignightor problem reply and we can talk
Jan 03, 2008 | Dryers
Kenmore 62602 Electric Dryer Logo
52 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
