On the inside back wall of the 1986 Adcom GFA-555 Stereo Power Amplifier there are four fuses,two for each channel. Would you tell me please, what amp fuse they are and if they are the fast or slo-blow type? I paid for this once and got no answer. Please check your records for the credit card information that I sent to your web site!
    Problem Solver:
  • 12 Answers
Original are AGC 6/250v acting fast fuse
Posted on Jun 25, 2015
  • 11,800 Answers
Sorry to contact you this way but i've spoken to an older colleague of mine and it appears that before 1992 in the Adcom GFA-555 they were using bipolar transistors and the amp was rated fo a minimal impedance of 4 ohms - not like in the newer ones that have MOSFETs and are rated for 1 ohm in bridge mode. So the fast fuses that you need are of 6 amps , not 20 like in the newer models.
Sorry for my mistake.
Posted on Jul 12, 2010
Can I run two stereo amps from same preamp?
yes, and do tell, what speakers are you powering with these amps?
Jul 09, 2013 | Bose 901 EQ1915 Home Equalizer
Adcom GFA 7500 problems
My right channel went out on my GFA 7500 and the problem was TWO blown internal fuses. Each amplifier inside the GFA 7500 has two fuses. In order to get to the fuses you must first take the top of the amplifier off by removing the screws using an allen wrench. Then put the top back on.Turn the amplifier over and remove most of the screws from the bottom to access the fuses in the bottom of the amplifier. There are two different size allen wrenches on the bottom. Be careful to not drop a screw inside the amp and make sure you line up the screw holes that hold the amps using a small screw driver to push the amps into position. I replaced all the fuses on the top and the bottom. AdCom sells the fuses on their site.
Jun 11, 2012 | Adcom GFA-7500 5-Channel Amplifier
I have an Adcom GFA 555 type II that won't shut off when the power switch is turned off...I'm assuming a relay problem?
please replace power switch to solve amplifier problem as power switch internal contacts seems stuck and does not disengage to turn power Off.
Thanks.
Mar 19, 2011 | Adcom GFA555 Amplifier
Is a Adcom GFA-7500 5 channel power amplifier bridgable?
no this AMP is not bridgable to get more power out of this amp you need 4 ohm speakers.
Power rating
1 - 150 watts into 8 ohm speakers
1 - 225 watts into 4 ohm speakers
Feb 23, 2011 | Adcom GFA-7500 5-Channel Amplifier
Adcom GFA-7400 power amp; 1 dead channel (thermal protect LED on)
Hi...
I've contacted ADCOM before and they sent a pdf of the electricals
http://www.adcom.com/default.aspx
also try:
www.stereomanuals.com
Mar 30, 2010 | Adcom GFA-7400 5-Channel Amplifier
I turn on the ADCOM GFA-5802 amplifier... ...The power light comes on, but does not heat up nor output sound
Have it serviced. Do you know what GFA stands for. People at Adcom do have a great sense of humor. Take it only to a high end audio servicer. Contact Adcom. This is good stuff you wouldn't want a hack working on it.
Nov 23, 2009 | Adcom GFA-5802 2-Channel Amplifier
Adcom gfa 555 blows the 10 amp fuse and the 6 amp fuse on the far right
Any fuse blowing is caused by a shorted component in either the power supply section or main audio amp part. Follow the fuse circuit and see where it leads you. Look around for burnt of damaged parts. Suspect anything sitting on a heat sink. The most common culprit is the audio amp main transistors, especially if someone shorted the speaker leads together. In the power part it could be the transformer, the large Electrolytic capacitors, rectifier, or voltage regulator. Some amps use an IC for amplification and this can blow the fuse.
Oct 19, 2009 | Adcom GFA-5500 2-Channel Amplifier
How to bridge GPA 555 adcom amp from 8 om to 4 om
First of all, when bridging an anp, the impenence that it can handle usually goes UP not down. I don't believe that the GPA555 can be bridged without circuit modification.
Dan
Feb 11, 2009 | Adcom GFA-5400 2-Channel Amplifier
167 people viewed this question
 Grubhead
Grubhead
