I have a JMB VCR how do i set the clock on it????
  • Sandra Howley Jul 11, 2010
    thnx i will comment wen i have done it
    do i need a remote to get to my settings menu,i have a vhs JMB mod no JMBD1020 as i hav,nt got one if so wer can i get a remote from
  • 11,896 Answers
Go to the settings menu,
Find the time option
Use the up and down arrows to change the hour and the minutes
Posted on Jul 11, 2010
  • Nate Stansfield
    Nate Stansfield Jul 11, 2010
    Ok sounds good.
  • Nate Stansfield
    www.avukltd.com/brand/JMB.htm
    www.remotecentre.co.uk/JMB-remotecentre.htm
    remotes.com
    www.espares.co.uk/search/jmb/p/0/1057
    If you don't have a menu or settings button on the vcr itself and holding the up and down channel buttons at the same time doesn't get you into your menu settings, then you will have to have the remote to do it.
Set clock on sd-kv550-su
There are two ways to set the clock on your machine, firstly by using the 'auto clock' feature and also a manual setup, if the auto setup doesn't work then you will need to setup your machine manually. the 'auto clock' feature will atempt set itself up and will take approx 4 mins for the machine to adjust itself. There is also a daylight saving setting which you can either have set to on or off. The auto and manual steps that I have added below have been taken from the user manual for your your Toshiba SD-V295 pages 24 - 26.
Hope this helps,
James
Auto Clock Adjustment
Preparation:
• Turn ON the TV and select the corresponding video input.
• Press VCR DVD selector to select the VCR mode.
(The VCR mode indicator will light.)
1. Connect the Antenna or Cable system.
If you use a cable box, turn it on.
2. Plug the AC power cord to the AC outlet.
3. Make sure the DVD/VCR is turned off.
If you press POWER, the Auto Clock set is not programmed.
4. Wait at least three minutes and press POWER.
5. Press CALL DISPLAY to check the clock setting on the on screen display.
6. If the clock is not set, check the antenna
condition. The AUTO CLOCK may not function properly if the reception condition
is not good.
Manual clock setting
1. Press VCR MENU.
2. Press SET + or – to select “SYSTEM SETUP”, then press ENTER.
3. Press SET + or – to select “CLOCK SET”, then press ENTER.
4. Press SET + or – to set the month, then press ENTER.
5. Set the day, year and time as in step 4.
6. After setting the clock, date and time starts functioning automatically
Apr 25, 2010 | Toshiba SD-V295
How to set up auto clock on a jvc vcr
When you have it on VCR mode you can bring up the menu and set the clock.
Nov 25, 2009 | JVC HR-XVC27U DVD Player/VCR
I HAVE A PANASONIC VCR ITR WORKS FINE, BUT THE
If you go into the menu you should see clock setting,there will be manual or auto,set to auto and the clock will set its self,even if the vcr is turned off.
Oct 09, 2009 | Panasonic DMR-E75V DVD Player/VCR
To set clock on microvave
[Clock]
[Clear]
[<time in 12 hour format>]
[Clock]
May 06, 2009 | Microwave Ovens
Change clock
how do I change the time on my sansui vrdvd4000 dvd player / vcr combo
Nov 06, 2008 | Sansui VRDVD4000 DVD Player/VCR
Zenith XBV443 DVD Player / VCR Combo - Set Clock Manualy
I have the Zenith xbv613 model DVD/VCR player and also need to change the clock set up. For the xbv613 I had to switch the player to VCR. The menu button did not bring the clock set up in DVD. When I switched to VCR and hit the menu button the clock set up showed, where I used to right arrow button to change the time. Hope this helps.
Sep 24, 2008 | Zenith XBV443 DVD Player/VCR
Setting clock on older VRDVD4001AC
According to the manual, to set the standard time, you should press VCR MENU, then SET + OR - to select System Setup. Press ENTER. Press SET+ OR - again and then choose STANDARD TIME followed by ENTER to set your own time zone. Press SET + OR - one more time to select your time zone, and then again press ENTER. To return, press VCR MENU twice.
Just a note: The unit is set to AUTO CLOCK when it is shipped. If you leave it this way, the clock will set itself after you plug in the unit provided you do not press POWER for at least three minutes when you first plug it in. Also, your cable box or antenna must be attached in order for it to find the time.
Mar 12, 2008 | Sansui VRDVD4001 DVD Player/VCR
Toshiba VCR auto clock does not work, not way to set it. Please answer right away
you know it would be easier to help you if we knew what Toshiba vcr it is. it is usually easy to set clocks now. you push menu or setup on the vcr remote and there s usually a option to set the clock. only thing i can tell you right now is look here and type in yoru modle number on the vcr and see if ther eis a oweners manual on the site.
Sep 19, 2007 | Toshiba W603 VCR
How to set the clock
Check here for a similiar model: http://download.jazel.net/misc/filecache/3f/3fca776cb32a0a5f4402168c2ef88bbe_1071-ManualHSU448.pdf You have the remote box? Most functions, clock/date set, channel add/delete and so on are done with the remote, and cannot be so done with the limited buttons on the VCR itself. Early VCRS (pre-90s) were setup with these VCR located buttons.
Aug 25, 2007 | Mitsubishi HS-U446 VCR
Televison & Video Logo
35 people viewed this question
Top Televison & Video Experts
Electro Med Services...
