Question about GE Profile Spectra JGBP90 Gas Kitchen Range
Have xl44 GE Range /Oven--Oven and Broiler will not work. What do I replace?
Date: 8/2/2010
I have a GE XL44 oven. It's about ten years old. Oven would not turn on, so I replaced the igniter. The igniter has to light to "tell" the gas to come on. The part was $80 here in Oklahoma and it was super simple fix.
Pull the oven out of it's place and unplug. You can shut off the gas if your buidler placed a shut off valve.
1. The oven door pulls off without tools (I wish I knew this when I cleaned the oven last year) just open the door about three inches and pull toward your chin.
2. Remove the lower storage drawer.
3. Then remove the racks.
4. Remove oven floor. The oven floor comes off with two screws in back, then lift it about an inch from the rear and you can pull the front up, clearing the lip. This is a good time to clean the ten year old food off the oven floor.
5. You will see the aluminum burner. The lower ignighter is attached to the burner. The screws to the ignighter are at an angle, dont try to remove them with out taking the burner out. To remove the lower burner, get on your side and look way in the back of the lower drawer area. Remove the two screws at the very back where the oven drawer goes. You will also unplug the two (2) wires and the then the whole burner will lift up and come out, then you can remove the ignighter screws. Take the ignighter off and take it to a appliance repair store and they will sell you a new igniter. You can look on-line as well.
The new part does not have the connectors like the original, Just cut the old wires in half and pig tail them to the new part. The new part will come with ceramic wire nuts. This whole install takes about an hour, and will save you a service call. It can seem like a hard fix, but once you dig into it, it's pretty easy. Everything goes back together in reverse. This would be a good time to change the light bulb while you are at it.
These are the same type of ignighters that are on everything these days, hot water heaters, furnaces and they are the most likely to go out since they are used quite a bit.
Posted on Aug 03, 2010
My GE xl44 gas range broiler won't work,
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
Oven Problems Replacing the Igniter
heatman101
Jun 02, 2011 | GE Profile JGB900 Gas Kitchen Range
GE XL44 Oven and stovetop work - broiler does not work
The broiler is the top element in the oven. Look at it. Bad ones sometimes have burnt into or have a melted spot. If it looks ok take it out by removing the screws at the back and pull the wires out a little and unplug the element. With an ohm meter it should show continuity. Replace it if any of these things apply.
Feb 04, 2010 | GE Kitchen Ranges
The oven pilot does not light. The broiler will not work. The only thing that does is the light. GE XL44 range. The burners light and the pilots stay lit.
    If you have standing pilots, make sure the pilot for the oven/broiler is lit as well.  When you turn the thermostat up to call for heat, you should see the pilot get larger. That larger pilot flame heats a hydraulic sensor and opens the main burner valve.
    Jan 10, 2010 | GE Profile Spectra JGBP90 Gas Kitchen...
    Lower oven burner will not light.
    Hi I have a older GE that the oven won't light. It is a gas range that is electric ignited. The top burners do work but the oven will not light. Is it pricey to have this fixed?
    May 28, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
    GE XL44 oven not working, but the broiler is...???
    CHECK THE IGNITOR, IT SHOULD BE GLOWING ORANGE BEFORE GAS IGNITES. IF NO GLOW, REPLACE IGNITOR.
    Jan 28, 2009 | GE JGRP17 Gas Single Oven
    GE spectra xl44 not work
    I have the Ge Xl44 stove the burners and broiler work fine but the over will not heat up. How can I resolve this problem?
    Jan 21, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
    Ge xl44
    GE XL44... Oven does not work. It was working just fine one day & then would not work. Everything else works fine. Stove has electric ignitiion. Could it be it is not working on the oven? Any ideas?
    Jan 02, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
    GE Profile Spectra JGBP90 Gas Kitchen Range Logo
    1,503 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
    Craig Butler
    Craig Butler
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
