Question about Samsung HPT5054 50 in. HD-Ready Plasma Television
Samsung Plasma HPT4264X/XAA. No power. Clicking noise. Common problem. I'm told that the capacitator problem only happens with LCD, but it sounds the same as many consumer complaints. Are Capacitators PART of power board? Is this a manufacturiong defect for which Samsung SHOULD BE responsible?
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Don't think Samsung should be responsible for this as a plasma TV is a very hard working device. It is working harder than any TV that has been built before, and as a result it produces a lot of heat. 75% of technical problems in plasma TV's are caused by overheating problems. You’ll need to check the power supply board first for any swollen/bulged capacitors. As power supply board is the hardest working board in a plasma TV, it develops voltage to supply all components, high current + high voltage. All this is only recommended if you have electrical expertise & know how to solder/re-solder components as these units contain high voltages even when switched off. This kind of issues in plasmas usually occur after 3-4years. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jul 11, 2010
  • donnazor Jul 11, 2010
    Hey Rylee - Thank you. The fact that this is a "hard-working" component in no way absolves Samsung from their responsibility to provide a decent product that will last (maybe) 10 years. I'm not expecting the level of endurance that my old Sony Trinitron displayed (still chugging along after 20+ years), but 3 years for an item that cost just under $2000.00 is ridiculous. There is such a thing as an "implied" warranty and a breakdown like this, which is apparently shared by many (try "samsung" in consumer affairs), is not justified by the fact that it works hard. Too bad. It should also work longer.
  • 11,896 Answers
Capacitors are part of every board, including power board. It is a very common problem for caps to overheat and burn out. Also some have relays that can go bad but not very common, usually it is the caps that go bad. Look for burn marks or swollen caps for a sure sign of a bad one. You can purchase an analog meter to test the caps. That is likely the problem. All tv's have them, not just lcd.
  • 1 more comment
    Why is Samsung only acknowledging the problem with their LCDs? How much would it cost to replace the power board? Are the capacitators that Samsung uses cheap, underpowered, defective?
  • Nate Stansfield
    Nate Stansfield Jul 11, 2010
    Most capacitors now days are made cheaper. And with such a small space with the flat panel design, they get overheated. The power boards are $135 at partstore.com
  • Nate Stansfield
    A shop would charge about $350
Samsung 50" plasma HPS5033X/XAA shut off and will
HGi:
This model is nortorious for Y-sustain board failure, replace the Y-sustain board and you should be good to go. The Y-sustain board is the one while standing with back off the set is the board on the left side of the television.
Jul 05, 2011 | Samsung HP-T5044 50 in. Plasma TV
I have the 42" Plasma
I'm online now on pay question, I can exactly tell you what parts needed to be replaced and I will assist you to fix it yourself.
Jdvillanueva
Mar 31, 2011 | Samsung HP-R4262 42 in. Plasma Television
Samsung LNT4661FX/XAA 46 in. HDTV LCD Television - When tv is turned on it makes a clicking noise for about 15-16 clicks. Progressively worse. Finally comes on
Capacitors are bad on the power supply board, they will probably looked bulged at the top. I've enclosed an example.
Jan 02, 2011 | Samsung Televison & Video
Samsung lnt 4665fx/xaa lcd wont turnon just makes clicking sound
Sounds like the power supply board has failed, VERY common problem. You can call 1-800-samsung for the nearest service center.
Jan 22, 2010 | Televison & Video
My samsung 40 inch lcd tv is not swiching on it just keeps making a clicking noise
HELLO, I AM ALMOST SURE THAT YOU HAVE BAD CAPACITORS ON THE POWER SUPPLY BOARD, IF YOU OPEN THE SET LOOK FOR THE SWOLLEN CAPS THAT IS A COMMON PROBLEM WITH THIS SAMSUNG LCD TVS
GOOD LUCK
CAYPIANAN@YAHOO.COM
May 10, 2009 | Sanyo DP42746 42 in. Plasma Television
Samsung lnt4042hx/xaa 40in lcd tv wont turn on
I concur with Lightnbaby.... had same problem... my TV LNT4042HX/XAA took 10 min to start sometimes... the capacitors on the power supply board had bubbles on top 4 of them all 10/1000Uf. Samsung wanted to charge $220+ to have a guy come out and fix. J&J parts (samsung vendor) wanted $108 for a new board. I replaced the 4 capacitors for $4.68 and the TV works fine now!!!!!
Apr 14, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
Samsung HPT4254X/XAA plasma turns off and on by itself, clicking.
had the same problem, same tv... bad connection on a transistor....
Jan 07, 2009 | Samsung HP-R4262 42 in. Plasma Television
LG 47" LCD TV - 47LC7DF Clicking Noise
I was told that these clicking noises (which happen on my Magnavox LCD too) were due to the "power required" at the internal switch. Seems that the power required to immediately turn on the TV is too much for a standalone household outlet, so it "surges" power in a series to get enough there. Hence, the clicking sounds are actually mini power surges to send more power to the internal circuits to turn the TV on.
If your set is like mine, these noises generally stop after a minute or two, correct?
Dec 13, 2007 | LG 47LC7DF 47 in. LCD HDTV
Samsung HPT5054 50 in. HD-Ready Plasma Television Logo
956 people viewed this question
Jerry Greenberg
Jerry Greenberg
