Question about Danby Portable Air Conditioner
Air conditioner isn't very cool
Air conditioner barely works, the 12000btu conditioner can barely keep a room cool, and sounds more like the fan function.........air conditioning sound of it "booting in" doesn't really happen anymore, just a steady blowing sound, yet still feels cool enough that the air is slightly conditioned. Way too big to return or take anywhere to get fixed, still fairly new and filter cleaned....what can I do?`
  • Danby Master
  • 43,501 Answers
There can be a couple of things that could be happening...
The first and easiest thing is to check the air filter. Make sure that it is clean... clean it or replace it. Next check the air vents to make sure that they are open and giving you good air flow...
Also check to make sure that you are not icing up on the indoor coil... ice will tell you that you are low on refrigerant. You also could be low and not be icing over, but you would need to have gauges on the unit to check that.
Finally check and clean the outdoor coil...this also can give you problems if the heat is not being removed from the outdoor unit efficiently...
You may also have a unit that is sized in such a way that it hits the balance point at about 85...that means that your heat gain is equal to the capacity of the unit...I often try to size them for about that here in Northern PA. because wqhen seldom get hotter then that and the unit then is much more effective at removeing humidity at lower temperatures...
You can also check out the tips that I have wrote about Air conditioningair conditioner isn't very cool - 2_bing.gif trouble shooting and maintenance...
Here is one about cleaning the condenser coil and at the bottom of that one are links to others..
Condenser Coil Cleaning Condenser Coil Cleaner
http://www.fixya.com/support/r3850183-condenser_coil_cleaning_condenser_coil
heatman101
Posted on Jul 12, 2010
Not cooling very good anymore. its cool but not that good! all the settings work. one thing i did notice is that ice builds up on the cooling coil from compressor! ( ge room ac model # ast05lcs1...5500...
Your intuition is right, the ice buildup is why it's not cooling so well now: the evaporator isn't getting the correct air flow and surface area for heat exchange. The 1st thing you might want to check is to make sure that it's draining properly. The 2nd thing you might want to do is to check that the room is over 100 sqft. If you'r only cooling a tiny bedroom, the AC's basically oversized: your cooling already cooled air, so it freezes. The actual reason that is freezes is because the condition is just right for the immediate area near the evaporator to be at the saturation point. Think of it in terms of weather: warm and humid air collides with cool air and it begins to rain. The temperature drops further, and the rain turns into snow. One thing you could try to make it not freeze-up is to adjust the temperature setting a few degrees or change the fan speed.
Aug 04, 2011 | GE ASQ05LK 5,050 BTU Room Air Conditioner...
Tip
How to cool big home with small air conditioner(s)
A lot of people have only one or two rooms that can take an air conditioner in the window. Often times, the air conditioner is also rated at a cooling power that would make you believe that there is no way that it can to cool the whole house/apartment. You can crank it to the max to try to cool as much as possible, but then this makes one room too cold and the others still stay too hot. You can try blasting the cool air down a hallway with a fan on maximum speed, but that only works so well. And, it's noisy, too. Well, I have two 260 sqr ft rated room air conditioners and I am cooling 2000 sqr feet of house to a comfortable 72 degrees in all rooms and it's been 95 outside all day. How to do it?
The trick is setting up your home to take advantage of laminar air flow. Set your air conditioner to say 68 degrees and start it in the middle of the morning before it feels hot outside. Put the AC deflectors pointing downward and towards the door. Put fans in the doorways pointing out of the rooms that have the AC. Point them level to the floor (not up) and put a fan to one side near the end of long hallways. Set the fans on the lowest power setting (not high). If the hallway branches out into a bigger room, put a fan in the room that is blowing across at a right angle to the entry, pointing the air flow parallel to the wall. This will circulate the cool air around the room. Keep the fans on low and pointed parallel to the floor, not up!
What you have created is a re-circulating air flow system, much like the North Atlantic Current that moderates the temperatures of Europe. You can check this by taking a tissue paper and holding it up to the top of the doorway. The air flow should be pushing the tissue away from the room without the AC and toward the room with the AC. This happens because the warmest air will be toward the ceiling and you want that warm air to make its way across the ceilings and back to the room with the AC, so that it can be cooled again. The cooled air from the AC will sink to the floor and the fans will gently push the air out of the room with the AC. It will stay low and travel along the floor in the opposite direction and into the warmer rooms. If you crank your fans up, you will create turbulent flow and that will not cool your house as efficiently as will laminar flow. Monitor the outside temperature and when it gets cooler outside by a few degrees, turn the AC to fan for about 10 minutes to eek out the last of the cooling. Then open the windows for the night to take advantage of the free cooling that nature provides. That's it! Enjoy the summer!
on May 25, 2015 | Heating & Cooling
Just bought a 2 yr. old Danby DAC5209M window a/c unit that doesn't cool the air before it blows it into a room. The wiring looks brand new, it was barely dirty on the inside, anyway, I've...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 24, 2011 | Danby DAC5020 Air Conditioner
Air conditioner isn't blowing cold! Fan works okay but air isn't cool. Can hear hissing sound that sounds like normal compressor function. Do I need a coolant recharge?
You will need the condenser coils repaired before you can charge it. These come from the factory sealed and they should not ever need a charge unless you have a leak. The hissing sound is more likely air in the system being pumped by the comressor and it is coming out a hole in the coils.
May 29, 2011 | Frigidaire FAH126N2T Thru-Wall/Window Air...
Jusrt bought a mobil home with an Interherm unit. I live in Louisiana. When the air was hooked up is didn't cool very well. The fan motor outside had to be replaced. I was told it was the wrong...
There are a few things you can try.Close the vents half way in rooms your not using often too force more air to where you want it.
Inside coil and filter may be clogged or dirty.Change filter and clean coil with a degreaser spray,simple green works well mixed with water.
Thermostat location? is it in a common area like the living room.If not it should be there.
May 10, 2011 | Intertherm P3RA-024K Air Conditioner
Hi I have a Daytek 12000btu. The air con is blowing out cold air but despite having all windows and doors closed the cold air is not circulating around the room. Its only cold when you stand in front of...
air filter, cooling coil and blower wheel are full of dusty. Clean it. And also check RPM of indoor fan motor. If less replace capacitor. If rpm o.k, after clean run the unit. Thanks.
Feb 09, 2011 | Daewoo DSA-122L Air Conditioner
I have a 14.4 square metre office room, fitted with 12000btu split AC unit for cooling, will it be sufficient?
1tr could cover up area of 100 Sqft ( Nearly 10sqmtrs) 12,000BTU is 1Tr. Better you go with 1.5 Tr. Otherwise make any patrician work to short the area, if you can. Thanks.
Feb 01, 2011 | LG LS-L1210CL Mini Split Air Conditioner
B 2200 - Fan still working - no cool air
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 08, 2011 | Dometic Rooftop RV Air Conditioner
ROOM SIZE
Work on around 650btu per square meter.
Mar 25, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Danby Portable Air Conditioner Logo
262 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
1STHVACMAN
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
