Cables on motherboard
Hi. I'm learning to build my own computer and haveing problems with where to put some cables. They are a number of cables some single some more than one. Some of the cables are - Spkr, reset.led,pw pwstn. I,am not shore where they go. The motherboard 694 TAS. Could you help. Thany you.
    President:
  • 2,571 Answers
These are the cables from the front panel of your computer.
power/reset buttons, led light from power on button/hdd activity etc.
The manual for your motherboard will tell you where they go.
They fit on the two rows of pins, usually at the bottom left corner of the motherboard,
I agree with you, they are very fiddly and the manual is not usually very clear how to attach them
Posted on Jul 11, 2010
PUT A NEW SYSTEMCASE FOR PACKERD BELL IMEDIA S1710
I found a manual for a motherboard that should be the same:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=858&MenuID=16&LanID=9#fragment-Download
please check the diagram on page 22 for the front connectors.
Good luck !!
Oct 19, 2014 | Computers & Internet
Building computer from scratch need to know where cords connect
Not a problem hicksdusty3
Post the motherboard manufacturer name, and model number.
In the meantime here is a Generic guide, (Which I despise posting),
Power cables;
http://www.playtool.com/pages/psuconnectors/connectors.html
IDE (PATA) data cable information,
http://en.wikipedia.org/wiki/Parallel_ATA
SATA data cable information,
http://en.wikipedia.org/wiki/File:SATA_ports.jpg
http://en.wikipedia.org/wiki/File:SATA_Data_Cable.jpg
The plastic front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the Main wires from the Front Panel go to, is the Front Panel header.
Known by many names, and abbreviations.
I CANNOT give you the Front Panel pinout, without knowing what Exact motherboard we are dealing with here.
Can't tell you where to attach what cable to where, on the motherboard, or any peripherals.
(Harddrive/Optical Drive {CD/DVD drive)
I also need to know if the Harddrive is an IDE (PATA) unit, or a SATA unit.
Same with the optical drive/s.
Post back in a Comment.
Regards,
joecoolvette
Mar 01, 2013 | HP Computers & Internet
Hi i m pravin from INDIA . i m newly assemble mother bord but p.c. start only 30 sec. then off so what can i do
1) The metal plate that the motherboard mounts to is a Support Plate.
It can be a separate metal plate from the computer case, or part of the computer case itself.
Some Support Plates that are part of the computer case have protrusions, or 'Bumps' formed, that hold the motherboard up off of the Support Plate.
Other designs of Support Plates use metal or plastic supports that space the motherboard away from the Support Plate.
These supports are Spacers, or Standoff's.
A Spacer is made of plastic.
A Standoff is made of metal.
The metal standoff's have a hex shape around the middle, a threaded end on one end, and a threaded hole on the other end.
The Standoff's MUST match the motherboard mounting holes.
There Cannot be a Standoff sitting out on the Support Plate, that does not line up with a motherboard mounting hole.
If there is it can short the solder joints on the bottom of the motherboard, and cause the motherboard to short out.
Sometimes removing the motherboard, and making sure that all metal Standoff's line up with the motherboard mounting holes, will fix the problem.
Other times it is too late, and the motherboard is damaged.
2) Make sure ALL power cables from the Power Supply are attached, and securely attached.
If the motherboard requires a 4-pin ATX +12 Volt power cable, make sure it is plugged into the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
If the motherboard requires an 8-pin EPS +12 Volt power cable, make sure you are not using just one 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#eps8
3) Be sure you have a KNOWN to be good Power Supply, and it has at least the minimum Wattage needed for your computer build.
4) Make sure the top of the Processor's case is clean, and the bottom of the Heatsink, and that Thermal Paste is applied, and applied properly.
5) Make sure you observed Anti-Static Precautions when you were building, and are building your computer.
Static shock will ruin a computer.
Regards,
joecoolvette
Dec 05, 2010 | Intel Computers & Internet
Hi shut down my pc went to turn it on and would not turn on the led on the motherboard is red is that normal
Hi. i had that problem. it happens in many foxconn motherboards. all you have to do is\
---Buy a UPS, otherwise you will have problems.
remove the power cable that comes from POWER SUPPLY to the MOTHERBOARD.
put back the power supply cable to the motherboard.
fix all cables correctly. then you may start the computer.
GOOD LUCK.
Nuno ----- nunex2@yahoo.com
Sep 10, 2010 | Foxconn (945G7MA-8KS2) Motherboard
Im not sure if its the motherboard but i just got done building my computer but when i plug my keyboard in nothing happens and my moniter wont show anything on the screen
Hi, not sure what you meen? does the computer swich on and boot up, but only when you plug in your keyboard? Any way go back inside case with your instruction for your motherboard and double check all your cables, I have built hundreds of PCs and its always the smallst think that catches you out. Come back yo me with full details if you can.
Jul 02, 2010 | Intel Motherboard
I removed the front panel of my computer....i also (without thinking)removed the wiring harness from the motherboard. the problem is,the wiring harness is seperated into three harnesses amd i dont know...
Nothing to worry. Wirings will be written with positions to plug in to motherboard. Refer to *********** guide and it will help you to plug in those loose cables into right position. However, you will find cables written with HDD, Reset, etc, and in motherboard also there will be same inscriptions and you have to place proper cable to proper place.
Readings may look like one in the link
http://www.build-your-own-computer.net/image-files/computer-wiring-01.jpg
http://www.fixya.com/uploads/images/533772D.JPG
Hope this helps. Having problem, do let me know your motherboard details and I will try to find out the correct manual
May 19, 2010 | Computers & Internet
Need help, put in new mother board and need help putting in usb connection to front of computer have mach speed motherboard, does anyone have a map for this?
There are probably cables coming from the front of the computer. On the motherboard, you will see 2 or more groups of pins where these cables go. Unfortunately, sometimes the cables don't have a single plug, but have one plug that has 3 holes and then 1 that has one. Many times, too, there are 2 sets. So--let's see if this helps:
The pins will be labled something like USB and then several numbers.
The pins look like this ::::. (hope that shows up OK)
If your usb cable end has one large (3-hole) plug and one small, the large one goes over the first 3 pins from left to right. The one on the left is labeled VCC. The separate plug goes on the 4th pin.
You can use the top row of pins or the bottom. Nothing goes on pin #5 on the bottom.
Does this help? If so, rate it accordingly, please.
Apr 19, 2009 | Mach Speed MS945G-GLV Motherboard
Computer will not boot
This is a good trouble shoot guide written by a friend of mine.
http://forum.pcmech.com/showthread.php?t=132409
I build machines for a living everyday and I still use this "out of case" method from time to time.
Aug 12, 2008 | Biostar 945GZ-SE Micro Socket 775...
Can't turn on Computer
Have you attached the CPU power cable from the PSU to the CPU power terminal next to the CPU. Double check you have the power and reset connectors tthe correct way around.
Jan 28, 2007 | NZXT GUARDIAN ATX Mid-Tower Case
Computers & Internet Logo
69 people viewed this question
David Payne
David Payne
