Question about Canon i250 InkJet Printer
Canon i250 Error Message 5520 plus 8 orange led flashes + 1 green
My Canon i250 is constantly throwing up the '5200' error message with the orange LED flashing eight times, then on to green, then back to eight orange flashes.
I have done a through cleaning of all of the guts, rollers, etc., including washing out and thoroughly drying the waste ink absorber pads. Also, I have cleaned the print head cleaner pads and, with great care, the print head itself, but none of that that has made any difference.
After the service and cleaning, I have also tried various re-boot and 'clear error message' procedures as suggested on different web sites, but none of them clear the error message or re-set the machine.
Each time I try to run the machine from 'cold boot', it goes through the usual start-up processes as though it is going to function normally, but it the simply goes back to the 8 orange flashes error status and the print head 'parks' over the head cleaner pads at the right hand side of the carriage.
Is this a 'terminal' problem, or can it be easily rectified? If it can be rectified, what is the correct procedure?
  • 4,889 Answers
Well this error message means "printhead over heating" but more often than not, its just a false alarm. Unplug all cables(USB, power etc.,) and hold for a minute. Hopefully the error message will be reset. If not then it may indeed be a problem with the printhead and its time to get another.
Posted on Jul 11, 2010
  • 1 more comment
  • fourniers Jul 14, 2010
    Thank you for your response. However, my advice is that error message 5200 is a 'waste ink absorber pads full' warning and, as I explained, I have already given the machine a total clean but that did not resolve the problem.
    However, since posting this inquiry I have encountered a more serious problem in that my HP 6100 Pavilion laptop has gone 'belly-up', lost the display (a common fault with what I now learn is a very unreliable and unpopular computer), a problem which I told is economically terminal for the machine.
    As an emergency measure I have had all data transferred to another laptop we have (Asus X58) running Vista and, after downloading an i250 driver compatible with Vista, the printer worked normally with the error message no longer evident. Whether this is permanent or not remains to be seen, but I have also been provided with a utility (i350tool\i350tool_Win2kV100) which I am told should be able to reset error messages.
    Jul 14, 2010 - Thank you for your response. However, my advice is that error message 5200 is a 'waste ink absorber pads full' warning and, as I explained, I have already given the machine a total clean but that did not resolve the problem.
  • eagle338
    eagle338 Jul 14, 2010
    Hmmm.. Glad to hear that you have been able to reset the error message :)
    Cheers,
    Sai.
Canon ip2770 error 5100 and 5200
How to Reset Canon IP2770 Error 5100:
Error 5100 means that the cartridge can not be detected by the printer. Actually the printer is not actually loading the cartridge and showing you the error 5100.
To solve these follow the following steps.
Turn off printer
Remove both the cartridges from the printer
Use a clothe moistened with alcohol to clean the surface contact on the cartridges where the terminals inside the printers touches
Return the cartridges
Turn on the printer.
Error will be removed
How to Reset Canon IP2770 Error 5200:
1. The printer is turned off and plugged the power cord.
2. Press Resume button 2 seconds
then press the POWER button until the green light on (when pressing the POWER button, Resume button ... jgn released first)
3. Then release the RESUME button, but do not release the POWER button.
4. While the POWER button is still depressed, press the Resume button 5 times. Led will light turns green orange with the last glow orange. (Do not be mistaken 4x because the printer will die completely, but it is temporary too) Then ...
5. Release both buttons simultaneously.
6. Led will blink briefly and then will glow GREEN.
7. And the computer will detect new hardware, just ignore ...
8. Press the POWER button, then the printer will die.
9. Press the POWER button again then the printer will flash and ... IP2770 Printer is ready for use.
Other Ways Reset Canon iP2770 error 5200:
1. Turn the printer, and printer will look normal.
2. Run the printer for printing documents or print test, then the 5200 error will appear.
3. Jump unplug the power cord without pressing the on-off
4. Open it and slide it into the middle catridgenya manually (press the white penguncinya hook behind the head, for cartridge can be pulled into the middle)
5. Unplug all cartridges and leave the lid remains open
6. Turn the printer, hit the head will move left and right because the lid was still open and will stop in the middle.
7. Replace the cartridge, and close the correct
8. Your printer will return to normal. (Source: from all existing sources)
I hope this solution will helpful for you
Please don't forget to click on Four thumbs which are given below & then write testimonial for my appreciation if it is helpful
THANKS & Keep Using fixya
Jul 27, 2011 | Canon PIXMA IP5200 InkJet Photo Printer
I have a canon printer IP 2770 .....i try to one my documents and shows that error 5200... what does it mean
Here's How to Reset Canon IP2770 Error 5200:
4. While the POWER button is still depressed, press the Resume button 5 times. Led will light turns green orange with the last glow orange. (do not be mistaken 4x because the printer will die completely, but it is temporary too) Then ...
9. Press the POWER button again then the printer will flash and ... IP2770 Printer is ready to use
Mar 23, 2011 | Canon PIXMA IP5200 InkJet Photo Printer
Always time sow Error number; 5200 A printer
Mar 16, 2011 | Canon Pixma iP2700 InkJet Photo Printer
Canon i550 LED error sequence: 7 orange +1 green flash
According to Canon 7 orange flashes indicates a print head fault. Solution they recommend is to take it to one of their service agents. Problem is that replacement print heads are not cheap and it is usually more economical to replace the printer. You could try taking the print head to a cartridge refiller and have it professionally cleaned (cost you nothing or next to nothing) and see if that solves the problem.
Sep 19, 2009 | Canon BubbleJet i550 InkJet Printer
Error message 5200 on Canon printer i965
Sent the printer for repair to the local Canon Service Centre.
Apr 14, 2009 | Canon Office Equipment & Supplies
ERROR ON MY CANON PIXMA MP150
TRY THIS STEPS...
Mp150 Reset Counter
Service mode operation procedures -
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Oct 31, 2007 | Canon PIXMA MP150 All-In-One InkJet...
CANON PIXMA MP150
Error E/2/7 Solution=waste ink basket
Mp150
Reset Counter
button pressing
procedures below.
procedures below.
Sep 03, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Canon i250 InkJet Printer Logo
357 people viewed this question
old marine
old marine
