Question about GE Spacemaker JVM1640SJ Microwave Oven
Light's on, plate rotates, no heat
GE Spacesaver XL--no heat--light's on, plate rotates, no cooking
  • 11,896 Answers
When the microwave works properly but just doesn't heat, then the magnetron is bad and will need to be replaced. You can get the part and the diagram at partselect . com or repairclinic . com
Posted on Jul 11, 2010
Have ge profile spacesaver xl sensor. will not heat strange buzzing sound and burning smell. clock, light, vent still work
This is most likely a defective magnetron, especially with the burning smell. There are two other parts that can be a problem, the high voltage capacitor and diode, all three work together to heat food. If the magnetron is the culprit, probably cheaper to replace the microwave oven.
Mar 02, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Lights ,runs, not heating, plate rotates but does not cook
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101[]\\
May 16, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
GE Spacesaver XL
fixed the problem with my GE microwave turntable motor without having to replace it.
I removed the motor from the microwave and placed it in a small vise. Using a very small flat head screwdriver I was able to pry up the four tabs holding the casing together. You may need a slightly larger screwdriver after that to bend them back out of the way so you can remove the motor cover plate.
Carefully take out all the plastic gears and note their position for re-assembly. You will find that the primary gear, at the bottom of the rest of the gears is attached to the motor magnet. It has a shaft that acts as a bushing passing through the center motor magnet. On the underside it is attached to a plastic washer. This is where it breaks. The motor magnet spins free of the gear/bushing/washer assembly. I used JB Weld epoxy to glue this assembly back together and it works like brand new. Note: On mine there were four indentations on each side of the motor magnet which corresponded to little ‘bumps’ on the underside of the gear on top and washer on the bottom.
Place all the plastic gears back into the motor in the correct order, slide on the motor cover plate and use a small cold chisel with a round end and tap hammer to bend the tabs back into place.
If this worked for you please let me know – karlet@bellsouth.net
Jun 20, 2009 | GE JVM1339BW/WW Microwave Oven
Microwave won't heat up after something caught fire.
Sounds like the magnetron has failed. There are some high voltage circuits that feed the magnetron and you can potentially get hurt if you don't know what you are doing. Would recommend you have it serviced by a professional if you want it fixed, otherwise look for a new one since the cost of repair can come close to the price of a new microwave oven.
May 24, 2009 | GE Profile Spacemaker II PEM31 Microwave...
GE Spacesaver 1800 XL - rattling sound
Hi jnflanders,
You've probably solved this by now, but I'll answer just in case. That part is called the stirrer motor. You can replace it yourself, as long as you have an offset phillip's head screwdriver handy.
Before you order the replacement part, figure out if your stirrer is driven by a d-shaped or a square shaft. You can tell by taking off the round plate on the inside top wall of the microwave. GE makes stirrer motors for both d-shaped and square shafts, so you'll have to get the right one. Here's the d-shaped motor that fixed this problem with my microwave: http://www.appliancepartspros.com/part_details.aspx?part_id=2024961.
Apr 02, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
The micowave will not heat or cook anything
PLEASE HELP ME TO FIX THS PROBLEM....
Mar 10, 2009 | GE Microwave Ovens
GE XL 1800 quit heating
I don't like to pass on your problem but it sounds very much like either the high voltage supply ot the magnetron has bit the dust.
Either one would make the repair marginal at best.
This is apparently not a very good unit, many microwaves jsut kind of fade away as their magnetron emissions decay.
This one seems to have a bad rep. look at this link:
http://www.fixya.com/search/p489218-ge_xl1800_1100_watts_microwave_oven/not_heat
Sorry, have owned a lemon or two myself.
Aug 27, 2008 | GE XL1800 1100 Watts Microwave Oven
GE Spacemaker JVM1640SJ Microwave Oven Logo
626 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
vince
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
