Question about Lexar LDP-600 MP3 Player
How do I charge the battery in my Lexas MP3 player. I thought all I had to do was plug it in to my computer and it would charge that way. But that doesn't seem to work. Do I need software or something?
  • 11,896 Answers
Just need the drivers downloaded. You can usually get them from there website. Just download the drivers, then double-click on the file once downloaded so it installs into your pc. Then restart your pc, then plug in your mp3 player and you should be good to go!
Posted on Jul 11, 2010
My mp3 isn't turning on even thought it is fully charged but plays music when plugged into USB
There is a Problem with the Mp3 Battery its not Charging get it Replaced!
Dec 29, 2011 | Audio Players & Recorders
Low Battery Mp3 player How do you charge it? Thought it was thru the USSB port on computer with computer on?
Hi dave holte,
It should be through the USB port, I don't think any players nowadays have separate ports for charging. Nevertheless, check if there is any port other than the headphone and the USB, because it never hurts to check. Does the computer recognize the device when you plug the mp3 player into the USB? It might be loose connection as well. Or maybe it is not set to be recognized as an MTP or Plug-and-Play device. Once you have it plugged in, go to My Computer (I'm assuming you are on PC) --> Device Manager and then scan for new hardware changes. Probably then you have to manually install the device and its drivers. But do check for the loose connections. Ask back if it doesn't work.
Mar 25, 2010 | RCA TH1611 MP3 Player
Mine is a mp3 player that I have had for a while and it doesn't
i have a keo mp3 2gb player that decided to not turn on. I thought the battery was low but after charging it still would not turn on unless it was connected to the computer. Can you help?
Aug 31, 2009 | Keo 13464CU (1GB) Digital Media Player
MP3 wouldn't turn on?
The most common cause is a flat battery. There is a trick to charging the battery in these small mp3 players. It wont charge if it is turned on, and it won't charges if it's turned off. Here what to do...
1. plug the payer into your USB port. or wall charger
2. switch thje palyer on using the mechanical switch (on the side)
3. turn it off by either holding down the play button, or selecting "System" from the menu
4. The screen will go black and the battery will begin charging.
Jul 18, 2009 | SanDisk Sansa m250 MP3 Player
Not charging
Try connecting directly to USB port on your computer, NOT a hub. It needs power to charge.
Apr 29, 2009 | SanDisk Sansa c240 MP3 Player
When i connect my sansa clip 2gb it will not charge. it say connected and then goes off. I thought it was charging but when i checked it the battery had died what do you suggest i do to get it working...
Check for the following:
USB Cable
Make sure that the USB cable is properly plugged in and use the original cable.
Computer in Hibernation mode
Make sure the computer isn’t entering hibernate or sleep mode while the device is connected.  The computer must be on in order to charge your player.
USB Port 2.0
Make sure the player is connected USB 2.0 port (1.1 occasionally causes charging problems).
USB Port location
Try plugging in different USB port (i.e. USB port in the back of the computer); sometimes the front USB ports have problem charging up the device.
Battery
Make sure the battery is fully charged.  It takes approximately 3 hours to fully charge the battery.
Latest firmware
Make sure to update firmware by downloading and installing the Sansa Firmware Updater
Jan 23, 2009 | SanDisk Sansa e250 MP3 Player
My element GC-1020 still will not come on or work with my compute
inorder for your device to charge, you must "eject" it via the "Safely Remove Hardware" icon in the system tray, this is when using windows XP
Jan 01, 2009 | Sears GC-1020 MP3 Player
I cant get my coby mp3 to charge?
That's because u didn't plugged in your computer. Your computer have to be turned on..
Dec 26, 2008 | Coby MP-C7085 MP3 Player
Recharging mp3
Whenever the PD-6070 is connected to a PC, it will charge. The battery indicator on the OLED screen will slowly fill over and over as it is charging. When the charging is complete, the battery indicator will stay filled.
Jan 18, 2008 | MyMusix PD-6070 MP3 Player
Lexar LDP-600 MP3 Player Logo
120 people viewed this question
Top Lexar Audio Players & Recorders Experts
Mohammad Abumuailek
Mohammad Abumuailek
Are you a Lexar Audio Player and Recorder Expert? Answer questions, earn points and help others
