Question about Roper REX3614KW Electric Dryer
I was in the middle of drying clothes, and had to add an clothing item and when I went to start the dryer it would not start. Now it will not start at all, is it dead?
  • Roper Master
  • 43,501 Answers
There can be many reasons why your dryerI was in the middle of drying clothes, and had to - 2_bing.gif will not turn...
This tip that I wrote will help you to figure out what is happening...
Dryer2_bing.gif Repair - The Dryer2_bing.gif is not Turning
http://www.fixya.com/support/r4422207-dryer_repair_dryer_noI was in the middle of drying clothes, and had to - 2_bing.gif/a>
Dryer Repair ? The dryer2_bing.gif will not start
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Posted on Jul 11, 2010
Why dryer shuts off too early on auto
The sensor detects the moisture content of the clothes, If the clothing is packed tightly some of the clothes in the middle of the pile might not dry completely, if the clothes on the outside near the drum have low enough moisture. If you have a position on the control for dryer clothes or a more dry position try using that or use timed dry.
Aug 01, 2014 | Whirlpool Dryers
How To Clean Silk
Hand Wash the item. Gently move the silk fabric around in the soapy water. Rub stains with your fingers or a sponge to clean them. Pour the water out when finished washing your garment.
Rinse the silk garment in a vinegar solution. White vinegar removes soap, restores shine and softens silk. Fill the basin with cold rinse water. Add 1/4 c. (50 ml) white vinegar. Gently move the garment around in the water to thoroughly rinse it. Empty the basin again.
Rinse the item in cold water. Add cold water to the basin. Rinse the silk item a second time in a basin of fresh, cold water. Turn the garment over and around to ensure it is completely rinsed and free of soap.
Sep 16, 2013 | Sewing Machines
No lint on filter? Where is it all going? Checked exhaust vent bought a vacuum attachment and there is no lint. Twice and sometimes triple the drying time! Help!
Instructions
  1. Dryer Does Not Run
    • 1 Close the door firmly. The dryer will not operate if the door is not completely closed.
    • 2 Press the "Start" button firmly or push the knob in to start the dryer.
    • 3 Turn the dial past the "Off" position and away from "Wrinkle Prevent." The dryer will not start in the "Off" or "Wrinkle Prevent" position.
    Long Drying Times
    • 4 Remove the lint screen. Clean it and replace it.
    • 5 Check the temperature of the room. The dryer will not operate properly in temperatures below 45 degrees Fahrenheit.
    • 6 Inspect the area around the dryer. It requires at least 1-inch clearance on the front and sides of the dryer. A 5-inch clearance is needed on the back of the dryer. Move the dryer, if needed.
    • 7 Separate large loads and do not use an air dry cycle.
    Lint, Stains and Wrinkles
    • 8 Clean the lint screen before drying each load of clothes to prevent lint buildup on clothing.
    • 9 Add fabric softener sheets before starting a drying cycle. If the sheets are added after the load has partially dried, they can leave stains on the clothing.
    • 10 Dry small loads and remove clothing as soon as the drying cycle completes to prevent wrinkling.
    Dryer is Noisy
    • 11 Check the inside of the dryer for loose change, buttons or other items. Empty the pockets on clothing before drying.
    • 12 Separate items that are knotted together and restart the load. Knotted or balled up clothing will bounce and make the dryer vibrate.
    • 13 Level the dryer. Turn the leveling legs on the front of the dryer clockwise or counter-clockwise until the dryer is level. Turning the legs clockwise will lower the dryer. Turning the legs counter-clockwise will raise the dryer.
Jan 15, 2013 | Admiral Dryers
Dryer not heating very hot. need to run two cycles to dry
Dryer is not drying properly, In order to resolve try following things.
  • Check the exhaust hood outside the house, does it open and close freely, Clean the lint filter and exhaust duct.
  • Do not overload, 1 wash load = 1 dryer load. Sort heavy items from lightweight items.
  • Large, bulky items like blankets or comforters may require repositioning to ensure even drying.
  • Check the washer to be sure it is draining properly to extract water from the load.
  • Clothes load is too small to tumble properly. Add a few towels.
I hope this will solve your problem.
Good luck and have a nice day.
Jul 04, 2010 | Frigidaire GLGQ332A Gas Dryer
DRYER RACK DOES NOT DRY CLOTHES
try timed dry cycle instead of the auto-sensing setting. In your drum if you have auto dry such as less dry normal dry and more dry, There is a sensor sometimes in the drum and sometimes in the exhaust right after the blower. If in the drum then your clothes brush by this and if moisture is sensed then it keeps on drying. With your rack the clothes can't touch the sensor so it tells your dial to turn and that items are dry which in fact are not. Try this and see how it does.
Feb 17, 2009 | Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer...
Dryer stopped before clothes were dry and now it will not start again
possible bad thermal fuse remove back look for small white object on left side just above blower on side if lint screen housing with continuity checker ck to make sure there a closed connection through fuse
Jun 04, 2008 | Whirlpool LER3624JQ Electric Dryer
Roper REX3614KW Electric Dryer Logo
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Roper Dryer Expert? Answer questions, earn points and help others
