Question about Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator
Foods are freezing when in the crispers or towards the back
I have a Kenmore fridge with the freezer on the bottom. The top portion (fridge) is freezing our foods when they are placed in the crisper bins, or towards the back of the fridge. Help!
  • Kenmore Master
  • 43,501 Answers
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
RefrigeratorFoods are freezing when in the crispers or towards - 2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on Jul 12, 2010
GE Profile Brita Fridge. Have setting down as low as possible and crisper foods continue to freeze. How can I fix that?
You need an internal digital thermometer to see if 1 is the coldest or the hottest. If you turn it to 6 and the temperature remains the same, the thermostat is faulty.
If 1 is the warmest and it continues to freeze crisper foods like lettuce, you need a new thermostat. Your ideal temperature is between 3 and 4' Centigrade at the coldest part, usually above the bottom shelf.
Aug 23, 2016 | GE Refrigerators
Food in crisper drawers freezing
HI. UMMM I WOULD DEFROST ALL FIRST.24/48 HOURS.AND TRY.MIGHT BE PARTIALY BLOCKED WITH ICE IMPAIRING CIRCULATION.GOOD LUCK.ALI
Jul 05, 2012 | GE (GTS16BBS) Top Freezer Refrigerator
My Kenmore side by side is fine, except for freezing everything in the crisper drawers.
The coldest place in your fridge is in the crisper drawers, manufactures know this and they even put heaters under the floor of your fridge to try to heat it up a bit in there, if you set your freezer temperture to low there will be less cold air current that flows into your fridge but it will flow in over a longer period of time, that air is about -22C so it will be blowing on your items in your crisper for a long time and it will probably freeze them, all very confusing and complicated but it may help to turn your controles for your freezer to a warmer setting, on the other hand if you only open your fridge a few times a day the cold air being denser will settle in the bottom of the fridge and freeze the crisper area, not much you can do about this, except eat more food... :-)
Aug 26, 2011 | Kenmore Side by Side Refrigerator
I have a side by side Kenmore that is in our basement. Does not get too cold by any means, maybe 65 degrees year round ambient tempearture in teh storage room it sits in. 2 months ago we put a quarter of...
yes it sounds like your only problem is that the evaporator fan is not operating so open the freezer door and see if you hear it. if you do not hear a fan running in the freezer make sure that the other fan in the back and the compressor is running. just replace the evaporator fan in the freezer and that should do it
Apr 01, 2010 | Kenmore 54662 / 54664 / 54669 Side by Side...
Vegetables keep freezing in the fridge crispers
You have to heat the coil in the back of the fridge. Take everything out and open up the back, then take a hair dryer and heat the coil. After doing this, adjust the heat settings on the freezer.
Nov 19, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
There is water building up in the bottom of the fridge ( under the crisper drawers). If I leave it there it will freeze. What is causing the water? The fridge is 18 years old.
drain hose is plugged... the freezer it need to drain water when if goes into defrost .the drain from the bottom freezer down to the bottom of the fridge... there is a pan under the fridge that holds the water until it evaporates
Sep 19, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Water from freezer dripping into fridge freezing and accumulating in the crisper drawers.
Maytag , MZD2752GRW; Water accumulating and is freezing in bottom of the freezer, then runs out the door on to floor.
Jun 10, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Freezing eggs in fridge area and freezing produce in crisper
HI,
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
thanks,
Mar 29, 2009 | Samsung RB1955VQ Bottom Freezer...
Kenmore elite fridge crisper drawer freezing stuff
If you have a side by side model you need to look at the refrigerator compartment wall on the left of the bottom drawer and move the slide control to the warmer/fruit/vegitable setting instead of the meat setting.
I hope this helped. Please rate my help or ask for more help please. supertechks
Apr 05, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Fridge and freezer not working right
remove and refix the regulator inside the fridge....
Jan 04, 2008 | Fisher and Paykel Active Smart E522B...
Kenmore 73502 / 73504 / 73509 Bottom Freezer Refrigerator Logo
312 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
