Question about Seiko Premier Kinetic® Perpetual Watch for Men
I HAVE A SEIKO KINETIC PERPETUAL WATCH , HOWDO I MANUALLY CHANGE THE MONTH DATE SNP001P1 IS THE WATCH
Techjoel
  • 79 Answers
SOURCE: I have not worn my SEIKO kinetic wrist watch for a
Here is the information from the website. The link to the manual is provided below. HOW TO CHARGE AND START THE WATCH Swing the watch from side to side approximately 50 times. * Before swinging the watch, check and remember where the minute hand is so that you can tell if the start-up indicator has worked or not. First, check that the crown is at the normal position. * If the crown is pulled out and the watch is swung, the start-up indicator will not work even if the watch starts operating. * Swing rhythmically at a rate of twice a second. * No additional benefit is obtained by swinging the watch more quickly or with greater vigor. * When the watch is swung, the oscillating weight in the generating system rotates to drive the mechanism. As it rotates, it gives out a sound, which is not a malfunction. 1 2 The minute hand moves quickly and stops as the watch starts operating. (Start-up indicator) Then, it will move at 20-second intervals. 3 After checking that the minute hand has done this, pull out the crown to set the time. 4 After pushing back the crown in to the normal position, swing the watch further approximately 350 times to reserve one day of power, and then, put the watch on your wrist. http://www.seikowatches.com/support/ib/pdf/1m20_e.pdf Good luck, Techjoel
Posted on Jun 05, 2009
escapement
  • 2334 Answers
SOURCE: Perpetual Calendar 100M, Ineed the instruction
Follow this link and click on OPERATIONAL GUIDE.
http://www.seikousa.com/#FAQ
Rate, please.
Posted on Jul 29, 2009
  • 110 Answers
SOURCE: watch will not stay running
Most likely time to replace the capacitor with a new Lithium Ion battery. This is the correct way to fix this problem. No one uses the old capacitors any more. I do this repair daily as a Certified Master Horologist/watch repair man. Ron at TimelyWatchRepair.com
Posted on Dec 12, 2009
mcdevito75
  • 1970 Answers
SOURCE: men's seiko perpetual calendar watch stopped
mcdevito75 here, Your Jeweler had to mention your watch would go to Seiko for repairs. Seiko should notify you or your Jeweler with the repair particulars.
Posted on Jul 23, 2010
  • 2501 Answers
SOURCE: SEIKO KINETIC SQ 50 HAVE USE MY WATCH FOR 14 YRS
It is unlikely that the capacitor will have any charge on it so you should shake it gently to charge it up. You certainly can't do any harm by charging it, even if the capacitor did have any charge.
Posted on Feb 20, 2011
Is there any way that I can set my Seiko perpetual calendar watch at home?
What a great watch! It has a super-fine piezo-electronic motor to move the date wheel! Very cool. Its quite a show to go through the date/leap-year check, and then observe the watch catch back up to the correct time afterwards. Battery lasts ~five years.
I downloaded the manual (your model number on watch back) after a short search online (beware of trojans/viruses).
Setting after a battery replacement requires shorting certain pins inside the watch to set the leap-year, and date. The back unscrews, and may require the special watch-wrench, available online. I unscrewed mine VERY CAREFULLY with fine pliers, confirming that I was doing this in a clean, dust-free location. The instructions are quite specific, must be followed carefully to set up correctly. Have a fine wire jumper to set the leap-year. I learned this because I did not want to pay an inexperienced jeweler $100 to replace the battery.
Oct 13, 2014 | Seiko Watches
How to set date on seiko perpetual calendar watch
You can not set the date..it MUST be returned to Seiko for repair. A perpetual calendar watch does not lose the date if it does something is wrong. Seiko will repair for you.
Aug 11, 2014 | Seiko Watches
My kenetic battery ( i think) operated watch ,N0, on the back plate-
First, does it say "Kinetic" on the face of the watch? If not, it is not a Seiko Kinetic. (You did not mention if it was a Kinetic or not.)
Second, the Serial number is not like any Seiko Kinetic I know, which is 2 4 digit numbers.
Third: The number you gave itself may indicate the type of button battery you need.
Good luck.
Mar 02, 2013 | Seiko Kinetic watch
I have purchased a new Seiko kinetic SUN007 mens watch. After hours of swinging back & forth to charge the watch, the 'second' hand still moves in two-second increments. (After charging via movement,...
I have a Seiko kinetic watch and it has behaved perfectly for over two years and therefore I think that yours is faulty.
I suggest you send it to Seiko to have it repaired or replaced under warranty.
Apr 05, 2011 | Seiko Sun007 Kinetic Watch for Men
Hello. I have purchased a seiko premier perpetual snp025 watch. From the moment I opened the box the 2nd hand is moving consistently at 2sec intervals and it does not move normally every 1sec. Also the...
Two sec jumps is low power in the elec store,,, winds with movement back and forth as your arm would swing. Sometime the day date function is changed by pressing the small button type crown in slightly with your finger nail.it may have on or two detents if so it adjusts both functions. if not the stemcrown needs to be used to set day and button to set date.
May 09, 2017 | Seiko Premier Kinetic® Perpetual Watch for...
I have a Seiko Premier Kinetic Watch SNP005. The problem is that the date is supposed to change around midnight. Now the date changes around 9-10 in the morning. I have read the manual and the only...
Thank you for contacting FixYa.<br /> You will have to contact Seiko on this one. I would tell you to just change the date to the day before and then forward the time, but I think I would just contact them as it is such a delicate timepiece.<br /> <a href="http://www.seikowatches.com/technology/kinetic/index.html">http://www.seikowatches.com/technology/kinetic/index.html</a><br /> Best regards.
Aug 25, 2010 | Seiko Premier Kinetic® Perpetual Watch for...
The seconds hands moves every 2 seconds, but still is accurate
Your battery is probably weak. Very common issue when a battery is getting tired! :-) Watches are designed to do that so you know to change the battery! If your watch is a Kinetic or Perpetual Calender then you need to take it to a reputable watch repair shop, I recommend that for a regular battery change as well.
Jan 16, 2010 | Seiko Watches
Seconds hand stops moving
1st reason. This means your oscillating weight and paired gears are not generating enough power to charge capacitor, thus not be able to move hand properly. 2nd reason. Capacitor can not recharge itself to full power and needs to be replaced. 3 reason. Seconds or chrono wheel has a mechanical fault developed over the time and needs to be cleaned or replaced. Those are 3 reasons why the seconds hand stops moving in Kinetic watch. Which one is right, you will find out only after visiting watch repair shop, because I can not give correct estimate without seeing the watch myself.
Rate me, plz.
Jan 11, 2010 | Seiko Premier Kinetic® Perpetual Watch for...
Seiko Premier Kinetic® Perpetual Watch for Men Logo
144 people viewed this question
Top Seiko Watches Experts
Jerry Greenberg
Jerry Greenberg
just-ice
Are you a Seiko Watch Expert? Answer questions, earn points and help others
