Question about Casio EXILIM ZOOM EX-Z60 Digital Camera
I just opened my camera... as I have 100s of times before... and for the first time ever... a message came up that "the card is locked"! Took out the card, re-inserted it... the same. Checked out what's on the card. One thing... Picasa.ini Somehow, picasa write protected the disk. How can I remove this?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Casio Master
  • 102,366 Answers
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Jul 11, 2010
Every time I turn on camera,it displays CARD LOCK? and will not work
SD cards have a slide switch along one edge. The position farthest from the metal contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Nov 05, 2014 | Vivitar Cameras
I have a "! Protected Card" message on my screen
Look at the memory card again. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Dec 07, 2010 | Fuji FinePix S2000hd Digital Camera
Upon turning on my camera the message 'lens error restart camera' appears against black screen. I've turned off the camera and have tried turning on again. Still same message. Prior to the above...
Can't help with the camera- sounds like it has a fault.
The photos, however, should be recoverable by putting the memory card into a card reader on a computer.
Oct 27, 2010 | Canon PowerShot SD1000 Digital Camera
I put a new card in my camera because my last one was full. Then I took several pictures. All of the sudden i get a message saying "memory card needs formatting." I pressed "ok" format. It deleted all of...
First of all, do you know you're supposed to download the pics from your full card to your computer and then format the card in the camera? Keeping them on the card is risky since the cards are not made for long term storage. The pics can degrade over time. Formatting completely erases a card and that's what happened with your new card. All new cards should be formatted in the camera before using....that's what your camera was trying to tell you.
Jun 23, 2010 | Kodak EasyShare CX4310 Digital Camera
Tried to unlock Lexar SD 2GB and Lexar SDHC 4 GB - No luck
First of all, the 4GB card will never be able to work in your camera. Check on its face. It likely says SDHC, and SDHC cards as this format came out after your camera was designed (I know it looks exactly like a normal SD card, but it's not).
Now the 2GB card should work with your camera as it is a standard SD card. Remove the card from your camera. Look on the side of the card for the tiny slide switch, and slide it to the other "unlocked" position. Reinsert it in the camera, and see if that corrects the problem.
Oct 19, 2009 | Canon PowerShot A620 Digital Camera
How do you get rid of card locked message on Polaroid i832 when there isnt even a card in it , just internal memory
It's likely that the locking switch inside the camera's card slot is stuck. If you look inside the slot on the side of the slot where the SD card slide switch would be, you'll see a glint of gold color on the side. This is the camera's lock/unlock switch. The other glint's of gold that you may see at the far end of the slot are the reader's connectors (ignore those).
Somehow, the locking switch is making contact and has become stuck in the locked position. With a plastic toothpick, or other skinny NON-METALLIC item, tap against this switch to see if you can jar open the contact to its normal unlocked position. Also try blowing compressed air at it, as some gunk may have worked its way in there, jamming it closed. Occasionally, reinsert the SD card to see if the issue has been corrected.
If repeated tries fail, it may be time to consider opening the camera to force open this switch (not recommended unless you have some familiarity with electronics). In this case please see the following (xscrewdriver, hope you don't mind me referencing your blog):
http://www.myfixtips.com/blog/digital-camera/how-to-fix-a-%e2%80%98card-locked%e2%80%99-problem-125.htm
Jun 01, 2009 | Polaroid i832 Digital Camera
Sd card locked
Don't worry guys if you can change the tire on yout car you can fix the SD CARD LOCKED PROBLEM.
You will need a set of mini phillips screwdrivers (everyone has a set in there box)
Open camera door note the tiny scews I think 4~5 of them also two screws that hold the back-up watch battery. remove all of them.
there are more screw inside just take your time and find them.
Carefully lift out the guts and you will see a set of contacts along the side of the SD CARD SLOT.
You can slide your sd card in and out of the slot and note that the contact point open and close.
the reason your card reads LOCKED is because the contact points are dirty I used fine sandpaper
to clean them up after I done this the camera worked perfectly again. The whole job took all of 15 min to preform.
Aug 26, 2008 | Moultrie MFH-DGS-100 Digital Camera
Stuck shutter D100 Nikon
The R06 is the buffer indication, not part of the error. It would appear more work is required. Other components may have failed, or the shutter itself may be bad.
I'm afraid this one is not a DIY. Nikon is pricey on repairs, you may fair better checking the repair service search here on Fixya.
Mar 31, 2008 | Nikon D100 Digital Camera
CARD ERROR ON OLYMPUS 710 STYLUS
I repeatedly removed, ref-formatted and replaced the card.  I did this 3-4 times and, while the battery did run down rather quickly, the card error problem seemed to be resolved.
I took some sample pics, download to comptuter, replaced card in camera and was delighted to find them still visible, and no card error message came up.
I hope this is a permanent solution.... and will have to check again when I have a chance to download again.
Oct 23, 2007 | Olympus Stylus 710 Digital Camera
Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
57 people viewed this question
Top Casio Cameras Experts
pontelemon
pontelemon
Ron Grant
Level 1 Expert
Are you a Casio Camera Expert? Answer questions, earn points and help others
