Question about Maytag PYE2300AY Electric Dryer
How do you change the vent outlet direction? - Maytag PYE2300AY Electric Dryer
  • 166 Answers
There are knock out panels on both sides of the dryer. knock out the one you want to use with a hammer and flat head screw driver or chisel. Some dryers you have to remove the back (others you may have to remove the front) and disconnect the vent going out of the back of the machine and reinstall a new hose or pipe on the outlet where you removed the vent and run it through your new hole to the outside vent.
Posted on Jul 11, 2010
Hoover Dryer Model D6792A. Trying to find a user manual or find out how to use the rear vent once its panel is removed
If I remember correctly, there is a venting kit that you purchase which consists of a fitting to go on the back of the dryer and a large diameter hose which you put out the window or door to vent the hot air from the dryer. There used to be another kit which allowed you to connect to a wall outlet which vents directly outside.
Apr 09, 2015 | Dryers
No heat
Usually a sign of a problem with one of the blend doors under the dash.
The blend doors direct air thru the heater core and the outlet vents.
Feb 28, 2013 | 1996 Mercury Sable
Chrysler cirrus, heater blows warm through dash but cold on defrost and floor
If the heater is working correctly, and the air temp does not stay the same coming from different outlets, the problem could be a blend door under the dash. The blend doors direct air thru the heater core and out the vents.
Jan 24, 2013 | 1997 Chrysler Cirrus
Cold air comes out front vents in 1999 windstar
Usually a sign of a faulty blend door under the dash. The blend doors direct air thru the heater core and the vent outlets. One blend door is directly behind the radio.
Dec 18, 2012 | 1999 Ford Windstar
Exhaust fan direction
You can usually recongure the outlet on the vent to just vent into the room,but if you aren't going to use it,not an issue.
Dec 18, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
2005 ford explorer air only blows thru top vent
Usually a sign of a faulty blend door or problem with the control on the dash. The blend doors direct air thru the heater and ac then thru the selected vent outlets.
Aug 25, 2012 | 2005 Ford Explorer
How do I change the rear vent outlet on a Kenmore dryer to the left side?
If it's designed to change, there will be metal plate on the side that you remove and place over the back outlet (remove vent hose), then move the vent hose to the side and hook it up.
Jul 23, 2009 | Dryers
Heater works ok but wont send air thru defrost vents
check the control knob it may appear to be working but is not turning the actual controller
Jan 01, 2009 | 1995 Pontiac Grand Am
Heater only blows thru dashboard vents, won't defrost
chech cable on back of cluster dial some time pops of causing issue.
Maytag PYE2300AY Electric Dryer Logo
340 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
