Question about GE 24 in. GLD5860LSS Stainless Still Built-in Dishwasher
Dishwashing machine not fully draining (2 inches of water remain). I have an open problem concerning this problem. I have a new pump. dishwashing machine not fully draining (2 inches of water remain) For this machine.
  • Anonymous Dec 06, 2008
    water is not draining
    Brigadier General:
  • 3,614 Answers
Following a cycle, a small pool of clean water inside the tub is typical. Excessive water means the pump isn't pumping water out properly, the drain hose isn't carrying it to the drain pipe, or the house's drain lines are backed up. If dirty water spews from the air gap, the drain line is kinked or clogged. Note: If you've recently installed a garbage disposer, be sure the knockout plug for the dishwasher was removed when the connection was made (see your disposer instructions).
Posted on Apr 22, 2008
  • micromaster
    micromaster Apr 22, 2008
    1st
    Remove the cover from the air gap at the top of the sink (usually a short chrome domed cylinder that sits at the back of the sink) and, using a wire, clean it. Also check the entire length of the drain hose for kinks and blockages, especially at the drain connection to the disposer or drain line.
    2nd
    Once the dishwasher is cool, shut off the power to it, and--if your dishwasher is made to allow this-- remove the strainer, located under the bottom spray arm at the base of the cabinet. Unscrew the hubcap, lift the spray arm off, and remove any clips that hold the strainer to get it out. Scrub it clean with a brush, then replace it.
    3rd
    Determine whether the sink trap or house drain line is clogged
    4th
    If it still doesn't drain properly, the drain hose may be clogged or the drain valve may need replacement. At this point, it's usually best to call a repair person. You can check the drain hose for obstructions, but this sometimes involves pulling the dishwasher out from under your counter to access the hose, disconnecting the hose at both ends, and flushing it out with a faucet or garden hose.
My LG dishwashing machine model LD 2131 SH displays a F error. What does it indicate?
LG DISHWASHER ERROR CODES AND DESCRIPTION MODELS LD 1420W2 D1420WF LD...
ERROR CODES; FAULTS & REMEDY ERROR DISPLAY [IE]
Inlet error.
Condition: Not reached to the normal water level in spite of 10 min. water supply.
Possible causes:
  1. The Water Tap is not opened.
  2. The Inlet Hose is twisted.
  3. The Filter of inlet valve clogged by impure water.
  4. The Inlet Water Valve is normal ?
  5. The water pressure is very low. ( below 0.5 kgf/ )
  6. Inlet valve is blocked by safety device for leakage sensing.(In case of Inlet Valve).
Remedy
    • Open the Water Tap.
    • Repair the Inlet Hose.
1.Close the Water Tap.
2.Unscrew the Inlet Hose (Inlet Valve side)
3.Clean the Filter of Inlet Valve.
> Replace or repair the Inlet Valve.
> Check the water remain on the base.
1.Check the point of damages and repair or replace the related parts.
2.Disconnect the inlet hose to dishwasher to unlock the safety valve.
ERROR DISPLAY [OE]
Drain error.
Condition: Not fully drained out in spite of 5 min. drain operation.
Possible causes:
  1. The Filter clogged.
  2. The Drain Hose twistec or blocked.
  3. The Drain Pump/Motor or circuit is troubled.
Remedy
    • Clean the Filter.
    • Remove the cause of twist or block.
    • Replace the Drain Pump/Motor or repair the Circuit.
ERROR DISPLAY [E I ]
Leakage error.
Condition: The water level in Tub goes down during operation.
Possible causes:
  1. Water leakage in Hose connections.
  2. Water is leaked by damages.
  3. Impeller of the washing Pump is worn away.
  4. The Thermal Protector of the washing motor is functioned
Remedy
    • Replace the connections of Hose.
    • Check the point of damages and repair or replace the related parts.
    • Replace the washing pump.
    • Check the applied voltage.
ERROR DISPLAY [ F E ]
Excess error.
Condition: Excessive water is supplied than normal water level.(Automatically drain Pump operated.).
Possible causes:
  1. The Inlet Valve is troubled.
  2. The Air Break is troubled.
  3. The Sensor Assembly is troubled.
  4. The Controller is troubled.
Remedy
    • Replace the Inlet Valve.
    • Replace the air breaker.
    • Replace the sensor assembly.
    • Repair or replace the controller.
Jul 09, 2017 | Washing Machines
Is it normal for 2 inches of water to remain in space where filter container is positioned...whenever filter is removed water is in the compartment where filter rests
In my experience the lowest section of the washer has always retained some water about a cup or two. If the one way valve(check valve) in the drain hose has failed or residue trapped in it more water will drain back at the end of cycle. You can see from the image the volume of additional water that would be trapped in the hose that if the one way valve leaks; the water in the hose would leak back into the tub.
the drain hose is required to go above the drain connection to prevent back flow into the washer. the one way valve in the drain hose is required to prevent back flow into the tub in the event of a blocked drain.
I hope that this helps.
Check Valve Replacement part 8268375 Whirlpool Dishwasher Repair
In some washers the check valve is critical because the pump reverses during the normal cycle. The attached video is an example of the check valve replacement in a Whirlpool. I have found all washers are similar.
You can usually hear when the pump has emptied the tub by a change of pitch from the motor. If you quickly open the door and observe the remaining water level that is as low as I would expect.
Jan 05, 2016 | Dishwashers
HOW DO I DRAIN REMAINING WATER FROM BOTTOM OF DISHWASHER
Thank you for your inquiry, friend!
I see that you need assistance in draining the remaining water out of your Frigidaire dishwasher. It is normal for a little water to remain inside of your dishwasher. If it is more than two or three inches it could be a draining issue. I would check to make sure the drain hose is not clogged or restricted. You should also review the filter, which you can find under the bottom rack, to make sure that it is not clogged. If you have reviewed these steps and water still remains it could be a possible issue with your drain pump. I recommend having a professional technician out to perform repairs because this will require you to uninstall and disassemble your dishwasher. I hope this information is helpful. -Matt
Feb 27, 2015 | Frigidaire Dishwashers
The dishwasher is not draining fully. Water remains on the bottom just lower than the heating element. How can I check...
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a dishwashing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated.If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump: http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Thank You for using fixya
Sep 26, 2011 | Kenmore 24 in. 15932 Built-in Dishwasher
Water remains in machine. Machine stops after a minute or so and diplays F11.
F11 means Drainage fault.
Water present in appliance and is not being drained off. The display shows Drain fault F11. The buzzer is activated for 2 minutes.
Background information:
After each drain pump step, the circulation pump operates for 2 seconds and heater pressure switch B1/13 checks the water level. If it is too high (large quantity of residual water remaining in the cabinet), the drainage time is extended. If, after a further check, the water level is still too high, then the program is interrupted, the fault code is saved and the drain pump is activated. Fault code F11 is also registered if heater relay 1K1 is not activated after the fault code F51 register check; see Section 080-3.18. Drain hose kinked. Remedy: Check the drain hose for correct positioning.
Cause: Drain blocked.
Remedy:
1. Clean the on-site drain.
2. Check the sump drain.
3. Check the filters.
4. Check the heater pressure switch and replace it if necessary.
Cause: Ball in non-return valve in sump has not opened (e.g., jammed).
Remedy:
Clean the non-return valve in the sump or replace it if necessary. Cause: Foreign objects in the drain pump.
Remedy:
Clean the drain pump and its impeller.
Cause: Drain pump defective.
Remedy:
1. Check the voltage supply to the drain pump.
2. If correct voltage is present, check the drain pump motor winding.
3. Replace the drain pump, if necessary.
Cause: Foreign objects in heater pressure switch.
Remedy:
Check the heater pressure switch for blockages and correct switching point.
Cause: Heater relay defective. Heater relay (coil or contacts) becomes defective during the drainage step (after fault code F51 register check).
Remedy:
Replace the heater relay.
Hope this helps to solve it.
Jul 05, 2011 | Miele G2432SCISS Builtin Dishwasher
The water used to completely drain out of the whirlpool dishwasher after the last rinse cycle. now water remains in the bottom. Also noticing decreased flow when actually draining into the garbage disposal...
Pumps. There are 2 pumps in most dishwashers. The drain pump,( which describes itself -it pumps the water out of the machine.)
The recirculating pump which forces the water at high pressure through the spray nozzles and arms. (This is how the cleaning action is performed)
These pump may either leak, or burn out. Either way, the only solution is replacement.
Mar 09, 2010 | Whirlpool 24 in. ADG6340iX Built-in...
Water is not draining completely from the dishwasher. About 1-2 inches remain in the bottom. Seems to drain most of the water during the wash cycle, but a bit remains. Thoughts on how to fix this?
either the check valve on the end of the drain hose that connects to the drainpump motor is closed shut or sometin is clogged inside the drain hose..... also maybe you pump motor assmbly is faulty... u prob need wet/dryshop vac and drain it out from inside then check that hose... hope this helps... possibly may need to replace that drain hose,,, prob not worth reparing if its a pump motor depending on which brand some had 5 yr part warranties on the pump motor assembly
Jan 30, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
We have a Jenn-Air dishwasher. The water does not fully drain when washing cycle is complete. Roughly 1/2 to 3/4 inch of water remains. Any suggestions are appreciated.
Check the that the drain hose is not kinked in any way under the counter and leading to the garbage disposal. Also check that the port in the garbage disposal is not partially restricted, or that the kitchen drain is not slower than normal.
I had the slow drain issue recently, and it would take the dishwasher forever to complete a cycle.
Dec 17, 2009 | Kitchen Ranges
Ran on normal cycle when done 2 inches of water on bottom
Test by restarting the cycle and see if water drains if it does not then there is either a blockege in the pipe ,pump,or in the machine where the water passes out normally through a filter if you have checked and cleaned out filter and drain pipe and there is still no draining then listen to the pump if you can hear a humming niose then there is something in the pump itself and you need to take it out and inspect the impelar houseing remove what ever is there put back and enjoy if there is no noise and pump is clean then it is proberly fualty and nedd replaceing.
Jan 23, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Drain
Happens on mine also. It's normal for a little water to remain after the rinse water is pumped out.
Oct 22, 2007 | Bosch 24 in. SHU53 Built-in Dishwasher
GE 24 in. GLD5860LSS Stainless Still Built-in Dishwasher Logo
1,223 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
