Question about Whirlpool LER5636P Electric Dryer
I have an Admiral ADE7005AYW that will not start. We have checked the plug and it is fine but the dryer will not turn on or light up. What could be the problem?
  • 166 Answers
I f the cord is ok where it connects inside the dryer then There are several other things that could cause this.
A couple of the more common things to check are:
1. You could have a defective door switch. you can check the switch with an ohm meter for continuity.
2. You could also have a bad thermal fuse.Also check this thermal fuse for continuity. this fuse shuts the dryer down if it over heated. if the thermal fuse is bad check your venting for blockage or crimping.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5176934
Posted on Jul 11, 2010
How to I recove the covering of my admiral dryer mo no ADE7005AYW
Posted on Sep 22, 2011
2 Suggested Answers
  • 4088 Answers
SOURCE: Can't open Admiral ADE7005AYW
Try sliding a thin putty knife rearward at each front corner of the top while lifting upward slightly. Shine a light into the joint and look for metal joining the two halves. Once the top is loose, look for screws in the inside front edges and lift up on the front panel to release. Make sure to pull the power plug while working in there.
Posted on Oct 22, 2009
How do I take apart admiral dryer model ade7005ayw
You can use Google search your model numbers an it show you a video on how to take your dryer apart the right way .
Mar 03, 2015 | Admiral Dryers
I have an admiral dryer, model #ade7005ayw, that will not tumble. the motor will spin manually and the belt is brand new and properly installed. what could cause this problem?
This Admiral site lets you select symptoms, offers solutions, has videos, and instructions, plus authentic parts for ordering.
Worth a look.
My ADE7005AYW Model Overview from PartSelect com
http://www.partselect.com/Models/ADE7005AYW/Symptoms/Will-not-tumble/
Feb 28, 2015 | Admiral Dryers
Converting 4 prong admiral ADE7005AYW to a 3 prong
Hi pete
Go to the following webpage and you will find the answers you are looking for.
Bud
Apr 24, 2013 | Admiral Admrial ADE7005AYW, ADG7005AWW...
Where is the heating element located in an admiral model no. ADE7005AYW
Take a look at this video to show you how to open the cabinet. The element is on the lower right side.
Nov 05, 2012 | Admiral Admrial ADE7005AYW, ADG7005AWW...
Admiral Heavy Duty Super Capacity Plus dryer does not start when button is pushed. The dryer buzzes when the start button is pushed, but the dryer will not start tumbling. The model number is ADE7005AYW...
Motor runs, but drum does not turn
1. Broken or slipping belt---replace
2. Loose pulley---tighten pulley on shaft
3. Drum jammed or bearing frozen---check for foreign object & clear it
Clean or replace bearing
Sep 21, 2011 | Dryers
I have an Admiral ade7005ayw dryer and it started making a loud squealing noise. I believe it is the drum glides causing the problem. How do I fix them?
First it may not just be them. You need to check all the rollers also. Turn off the power or unplug. Take off the front panels.Then the front bulkhead. pull belt off motor then slide drum out. The drum glide will be 2 plastuc strips on the front bulkhead. The rollors wil be on the back bulkhead. Give them a spin if they don't spin freely replace both cause you don't want to do this again in a short amount of time. To take off those rollers you will need a set of lockring pliers. Also check the Idler pulley that puts tension on the belt for wear.
Dec 28, 2010 | Maytag ADE7005AYW Dryer
Oct 22, 2009 | Whirlpool LER5636P Electric Dryer
Dryer not starting
Luckily, these units usually have a wiring schematic on the back, if not google it. The first thing on a washer or dryer to fail is the door switch. It's easy to replace or bypass. After that the start button itself may be bad. Follow the circuit, be careful. Use a continuity meter that beeps to check stuff. You mention a light. That means the door switch controls the light and the dryer, there will be a normally open leg and a normally closed leg. Good luck.
Nov 18, 2008 | Whirlpool LER5636P Electric Dryer
Whirlpool LER5636P Electric Dryer Logo
560 people viewed this question
Top Whirlpool Dryers Experts
Tim Whalen
Sal De
Craig Butler
Craig Butler
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
