Question about Kenmore 3.5 cu. ft. King Size Capacity Top Load Washer
Water Just Keeps Filling!
If I turn off the washer it just keeps filling and filling, the only way to get it to stop is to turn off the water supply to the machine. Even flipping the cycle to spin won't stop it, it just keeps filling with water and overflowing.
Any ideas?
    Genius:
  • 1,073 Answers
Replace the water inlet valve, the valve that the black hat and cold lines connect to
Posted on Apr 20, 2008
2 Suggested Answers
SOURCE: Filling With Water
I recently had the same problem. I checked the end of the air hose coming from the tub. It had a tear in it right at the connection. I just cut off the hose at the tear and placed the hose back on the connection.
Posted on Jul 18, 2008
Water wont stop filling up
If water keeps filling or dribbling into the machine with the power off it's the water inlet solenoid. If it overfills only during the cycle then it is the pressure switch or pressure switch tube.
Jul 10, 2013 | Meiko Dishwashers
Water over fills and machine does not start washing
put the washer on warn and start to fill,turn washer off,if it keeps filling then you need a new water valve,if it does not stop filling your water level,hose has come loose or the water level switch is bad-mike
Feb 09, 2010 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Keeps filling up with water even on spin
Close the water supply valve and allow the machine to completely drain the water from the tub. Turn off the machine and disconnect it from the power outlet. Open the water supply valve. Replace the water inlet valve if water drips into the tub when the machine is off.
Start a new cycle if the machine stops filling when it is off. The control board or the water level switch is malfunctioning if it keeps filling even during the spin cycle. Indicate the model number for proper troubleshooting and repair assistance.
Feb 05, 2010 | Washing Machines
My Whirlpool front load washer keeps filling with water when off.
turn off water supply taps when not using machine
Dec 21, 2009 | Kitchen Ranges
Water keeps filling up washer
u have a bad water valve. thats the plastic piece behind the washer that the hoses hook upto. part roughly 39.99-89.99 labor 75-125.00 depending on were u live and who u use. if you decide to do it yourself i would say a 5 on a scale of 1-10 . turn water supply off, remove both hose.turn off power remove top panel 2screws in back and push panel back and off. remo 2 screws that hold water valve in place. remove wires from pld valve too new one. reassemble . hope this helps.
Oct 07, 2009 | Kenmore Elite 45986 Front Load Washer
Water Overflows from washer
Hello,Sounds like a problem with either the inlet valve or the pressure switch, way to determine which on is while it is filling pull the plug..if water keeps filling it's the inlet valve..if it stops filling it's the pressure switch..If you have any other questions or concerns please feel free to comment again..good luck!! Mike
Aug 18, 2009 | Kenmore Washing Machines
Keeps filling with water when turned on
A lot of wahing machines use a bunch of micro-switches to turn the various solenoids on and off. If your washer has that type of switch, it could be sticking, subsequently sending an "on" signal to the fill solenoid.
Apr 19, 2009 | Washing Machines
Wont stop filling
If when you press pause while filling and it keeps filling then you have a faulty valve. If the filling stops then valve is ok.
If you filling keeps going until overfilling the machine which is what i understand is your problem, then most likely that you have a small pinhole in your pressure tube.
Apr 18, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Estate washer, new, water will not stop, overflowing
you need to replace the inlet valve something is stuck in the valve not allowing it to shut.
Dec 23, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washer constantly fills with hot water even when turned off.
Sounds like a bad mixing valve. To verify that it is the valve you need to turn off the washer when it is filling. If water keeps running, replace the valve, Cost is under $50. for most washers.
Jan 03, 2008 | Washing Machines
Washing Machines Logo
665 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
