Question about Denon DRA-685 Receiver
My toddler pressed a bunch of buttons, and now it won't work, it flashes the word "Protection" on the digital screen.
    President:
  • 1,561 Answers
I advice you power off the device and power on after few minutes, if the screen still display the protection on the screen, power off and power on again, while your device is loading, pull out the plug from the AC socket and wait for some minutes before you plug and power on again, you can also check the manual of your device to see what the protection is about and how to fix it, the manual should shed and explain the information as regards this.
Take care.
Posted on Jul 11, 2010
Rca 24" tv remote won't operate tv
If set turns on with the power button on set the remote is : not set to TV, not programmed for the set, has bad batteries or is bad.
If it even works one function it may need to be reprogrammed or taken apart to see if works---you can test the remote by pointing it at a digital camera with a LCD screen and pressing buttons to see if it makes the screen flash on the camera.
Test the remote first
Apr 09, 2012 | RCA Televison & Video
AOC A15X221 have picture no sound
Try a factory reset:
1. Press and hold "Menu" and "Channel+" on the TV. (do not use the remote)
2. Using the other hand, press the Power button.
3. A small screen should appear in the top left part of the screen.
4. Using the remote, select "Memory Recall" and Enter.
5. Power off and reboot the TV and Computer.
6. Run channel auto-scan to regain the picture.
Nov 20, 2011 | AOC A15X221 15 in. LCD Television
My camera is several years old. The flash stopped working. I replaced the batteries. Any ideas?
Here are some simple things to try first for a camera that won't take a picture when the shutter button is pressed, or with an inoperative flash. They won't work for every case, but they're worth a try:
Aug 30, 2011 | Canon PowerShot A630 Digital Camera
Ixus 430 will take photos when flash is turned off, but will not take photos when flash or redeye is selected
Here are some simple things to try first for a camera that won't take a picture when the shutter button is pressed, or with an inoperative flash. They won't work for every case, but they're worth a try. (Hint, make sure that all the screws around the perimeter of the case are present and firmly seated.)
Jun 01, 2011 | Canon PowerShot S410 / IXUS 430 Digital...
My toddler started pressing a bunch of keys on the keyboard all at once and so I shut the laptop and when I went back later to try and turn it on it wouldn't go. I can't get it to boot up at all. Any...
Try restarten cpu,,k ,,imediatly press esc buttonn,,jus keep tapping it,,it should go to a boot option screen,,tell it to boot from hdd,,hard drive,,press the number that is next to hdd on screen,,ok should be good to go,,ok,,goodluck
Nov 09, 2010 | Computers & Internet
When i turn on my digiweigh dw 100ax scales F--H appears on the screen how do i fix that and calibrate the scales when done
I thought the scale was just completely broken, I was able to fix by doing the following.
1. turn unit off
2. hold down the on/off/tare AND the MODE button.
3. The unit will come up with a bunch of numbers on the screen. Release the buttons
4. Press MODE once, you will see "100" flash on the screen. if you don't press the button a second time.
5. place 100g of tare weights on the scale.
6. Press MODE button again. After this my scale said PASSED and shut off.
7. remove tare weights and turn device on. It should now register properly.
In my case. the scale was misregistering the 50g weights as 75. I shut it off. I pulled up ever so slightly on the scale plate on the hinge side of the plate are repeated steps 1-7.
I have no idea why they don't have a 3 part calibration on these.
It is working like a charm now!
Sep 04, 2009 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
When taking pic in sunlight - lcd screen is whited out!!
I think that's normal. I also have experienced the same always when the screen is exposed to sunlight. Try adjusting its brightness or use an anti-glare protection.
May 26, 2009 | Olympus FE-20 Digital Camera
Remote control touch screen is not working
Flip ipen the front face of the remote control so that you have access to the buttons underneath. Press and hold the "light" button on the outside right of the remote while pressing the "enter" button to the right of the number "1" button.
THIS WON'T WORK IF YOU HIT THE "enter" BUTTON BETWEEN THE ARROW KEYS.
The screen should now flash PRESS and VCR 2 - press the onscreen key marked VCR 3.
The screen should now flash PRESS aqnd OSD - press the onscreen key marked OSD.
Test all of the onscreen keys. If you find them still unaligned, repeat the process.
Feb 24, 2009 | Nakamichi SoundSpace 12 System
Need an urgent solution regarding "Protection" problem (I have a program to record in next 2 hours) pls pls help !!!
have suddenly getting a "Protection" message in Camera mode. - The viewfinder is OK and i can see the view but a "Protection!" message is blinking in the middle of the screen and the record button is not working if i press
Apr 13, 2008 | Samsung VP-D103i Mini DV Digital Camcorder
Won't start
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
Jan 13, 2008 | Kenmore 24 in. 15689 Built-in Dishwasher
Denon DRA-685 Receiver Logo
121 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
