Question about Gateway Performance 800 PC Desktop
I need to know more about a Gateway Performance 800 motherboard. I added a second 128 meg SDRAM 100 Mhz simm in bank 1 (the board came with a simm in bank 0). The BIOS recognizes the original simm as 128 meg, but sees the simm in bank 1 as 64 meg (total of 192 meg of ram). Is there a jumper I need to setup? This computer was purchased new in 2000. A number on the motherboard is P06B005502012449 (board ID?). Thanks.
  • 61 Answers
Check the specs for your new ram. It sounds like you have double density ram installed. If your motherboard only supports single density it will only see 1/2 of the modual hence 64meg showing for 128 stick.
Please rate this solution if it has helped you.
Thanks, Gary
Posted on Jul 13, 2010
Need Manual for Slot1 PIII Gateway Jabil Tabor III Motherboard.
The memory specifications for that motherboard are as follows:
  • 100-megahertz (MHz) Memory Bus Speed (FSB)
  • Three 64-bit or 72-bit Error Checking and Correction (ECC) 4-clock, 3.3V, unbuffered synchronous DRAM (SDRAM) Single or double-sided DIMMs in the following sizes: 8 MB, 16 MB, 32 MB, 64 MB, 128 MB
  • Expandable to 384 megabytes (MB) of SDRAM, CAS latency of 2, using 64-Mbit chips
  • DIMMs must adhere to the Intel 4-clock 100-MHz 64-bit unbuffered SDRAM DIMM specification, latest revision
  • Uses gold-plated DIMM socket
  • ECC signal and multiple bit detection, single bit correction, supported, using ECC DIMMs, can be enabled and disable in the BIOS Setup Utility
  • Jun 21, 2009 | Gateway Computers & Internet
    Dell Demension 4600 motherboard memory
    From the Dell specifications page for Dimension 4600:
    Memory
    Architecture
    Dual Channel DDR SDRAM
    Memory connectors
    Four
    Memory capacities
    128-, 256-, 512-MB or 1-GB
    Minimum memory
    128-MB DDR SDRAM
    NOTE: Between 32 and 64 MB of system memory may be allocated to support graphics, depending on system memory size and other factors.
    Maximum memory
    4 GB
    Memory type
    PC2700 (333-MHz) or PC3200 (400-MHz) DDR SDRAM
    (non-ECC)
    Mar 09, 2009 | Dell (2336V) Motherboard
    Need to know bus speed of Trigem Cognac MB used in HP Pavilion 6730. Is it 100 MHz or 66 MHz?
    it's 100 other info as follows:
    Component Attributes RAM (standard) 64 MB SDRAM standard Maximum 256 MB (2 x 128 MB DIMM) Speed 100 MHz synchronous Sockets Two 168-pin DIMMs Size 16, 32, 64, and 128 MB DIMMs Type Supported SDRAM, 100 MHz, Intel PC SDRAM unbuffered DIMM specification, revision 1.0 compliant
    Cache Level Quantity Level 1 (Primary) 32 KB (on processor) Level 2 128 KB (on processor) Upgrade Sockets None
    Dec 09, 2008 | Computers & Internet
    I have a 838gm gateway,Ive tried to install 4gb of ram ,when I install more than 2gb,it will not boot
    Gateway's website says this motherboard will support 4GB of DDR333 or DDR400 memory. I would suggest testing each memory modules by plugging it into the board by itself, then rebooting. This way you can catch a bad DIMM that might be causing problems. If each one checks out then start adding one module at a time, rebooting after each one. If it still stops booting after you add a module, you probably have a bad system board, and only now that you are adding the extra memory are you finding that out. If that is the case, try contacting Gateway support. Maybe they would be kind enough to cover repair under warranty.
    Nov 27, 2008 | Computers & Internet
    RAM cuantity
    The motherboard you mentioned supports DDR1 RAM.
    For windows xp and general application 512 MB is enough.
    But if you use memory intensive applications like image/video editing then you can opt for 1-2 GB RAM.
    Nov 24, 2008 | Intel D845EPI (INTELKD845EPILPAK10)...
    Regarding upgradation of SDRAM
    hi dear
    there is always speed mismatch problem occur when we use low processor & high ram
    so try to use 256 ram
    also try to use 1 slot of 256 ram & 2 slots of 128 ram diffrently
    & compare the speed
    hope it will help to u
    Jul 08, 2008 | ASUS SiS Chipset CUSI-FX Motherboard
    I have a P3 at 500MHz and was wondering with this Motherboard,
    The motherboard has three, dual in-line memory module (DIMM) sockets. Minimum memory size is 16 MB; maximum memory size is 768 MB. The largest DIMM supported at this time is 256 MB using unbuffered 128 Mbit technology parts. The BIOS automatically detects memory type, size, and speed.
    The motherboard supports the following memory features:
    • 168-pin DIMMs with gold-plated contacts
    • 66 or 100 MHz SDRAM
    • Non-ECC (64-bit) and ECC (72-bit) memory
    • 3.3 V memory only
    • Unbuffered Single- or double-sided DIMMs in the following sizes:
    DIMM Size Non-ECC Configuration ECC Configuration 16 MB 2M x 64 2M x 72 32 MB 4M x 64 4M x 72 64 MB 8M x 64 8M x 72 128 MB 16M x 64 16M x 72 256MB 32M x 64 32M x 72
    Synchronous DRAM (SDRAM) can be installed in one, two, or three sockets. EDO DIMMs are not supported. Memory size and speed can vary between sockets.
    Note: Intel® Pentium® II processors with 100 MHz front-side bus should be paired only with 100 MHz SDRAM. Processors with 66 MHz front-side bus can be paired with either 66 MHz or 100 MHz SDRAM.
    All memory components and DIMMs used with the Intel® SE440BX-2 motherboard should comply with the PC SDRAM specifications. These include: the PC SDRAM Specification (memory component specific), the PC Unbuffered DIMM Specification, and the PC Serial Presence Detect Specification.
    Note: It is recommended that SPD memory DIMMs be used with the SE440BX-2 motherboard. However, the BIOS will allow the use of non-SPD DIMM memory.
    So the max you can go is 3 x 256 MB.
    Thanks and please take a moment to rate fixya.
    Jul 06, 2008 | Intel Desktop Board SE440BX-2 Motherboard
    Installing Ram in a Dell Laptop
    Yo u have 2 slots in u r machine I am sending u details information of updradation in ur machine :
    frequency of ram should be
    667 MHz Dual Channel DDR2 SD RAM
    option 1.
    A system ready for the next generation of applications and games 3 or 4GB1 Dual Channel2 DDR2 SDRAM
    2.
    A system capable of handling Windows Vista® Aero as well as today’s latest games. 2GB Dual Channel2 DDR2 SDRAM
    3.
    Basic performance for the Windows Vista® AeroTM interface (PCs purchased with Windows Vista Home Premium and less than 1GB of memory will NOT be capable of running Aero). 1GB Dual Channel2 DDR2 SDRAM
    4.
    Basic performance, lowest initial cost (Windows Vista® Home Basic) 512MB Dual Channel2 DDR2 SDRAM
    Jun 21, 2008 | Dell Inspiron 8600 Notebook
    Motherboard processor support
    Processor Family Processor Speed System Bus Frequency Cache Size BIOS Version Notes Pentium® III processor 850 MHz 100 MHz 256 KB P14 or greater The following board revisions (AA numbers) support these processors: 754552-200 or later
    754558-200 or later
    A01450-200 or later.
    See the board revision note, below, for an explanation.
    800 MHz 100 MHz 256 KB P14 or greater 750 MHz 100 MHz 256 KB P14 or greater 700 MHz 100 MHz 256 KB P14 or greater 650 MHz 100 MHz 256 KB P14 or greater 600E MHz 100 MHz 256 KB P14 or greater 550E MHz 100 MHz 256 KB P14 or greater 600 MHz 100 MHz 512 KB P12 or greater All board revisions support these processors 550 MHz 100 MHz 512 KB P07 or greater 500 MHz 100 MHz 512 KB P07 or greater 450 MHz 100 MHz 512 KB P07 or greater Pentium® II processor 450 MHz 100 MHz 512 KB P01 or greater 400 MHz 100 MHz 512 KB P01 or greater 350 MHz 100 MHz 512 KB P01 or greater 333 MHz 66 MHz 512 KB P01 or greater 300 MHz 66 MHz 512 KB P01 or greater 266 MHz 66 MHz 512 KB P01 or greater 233 MHz 66 MHz 512 KB P01 or greater Intel® Celeron® processor 433 MHz 66 MHz 128 KB P01 or greater 400 MHz 66 MHz 128 KB P01 or greater 366 MHz 66 MHz 128 KB P01 or greater 333 MHz 66 MHz 128 KB P01 or greater 300A MHz 66 MHz 128 KB P01 or greater 300 MHz 66 MHz 0 KB P01 or greater 266 MHz 66 MHz 0 KB P01 or greateri hope that this solved your request.
    Sergio
    Mar 13, 2008 | Intel Desktop Board SE440BX-2 Motherboard
    IS DDR SDRAM IS DDR II RAM OR DDR
    No. DDR replaced the SD in RAM so SDRAM and DDR RAM are two completely different things but each ram type has its own frequency hence you get SDRAM 100(mhz) and SDRAM 133(Mhz) just like you get DDR 1 RAM at 266(mhz) and 400(mhz) and DDR 2 RAM at 533(mhz) and 800(mhz). Therefore as you can see how these things differ, but if your mboard takes SDRAM that it can take and frequency of SDRAM but you must ensure that all the frequencies of all your RAM modules in all your slots correspond otherwise you will have problems, meaning that if you decide to use 133mhz RAM then all your RAM modules that you use must be the same. Let me know how you go. thanks
    regards
    Feb 06, 2008 | Intel D101GGC Motherboard
    Gateway Performance 800 PC Desktop Logo
    87 people viewed this question
    Top Gateway Computers & Internet Experts
    Prashant M
    Prashant M
    Alun Cox
    Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
