Question about Samsung HCL5515W 55" Rear Projection Television
Samsung Model # HCL5515W S/N 3CET300477H
Since two weeks ago, we do not have image, only a blue screen, also no sound. It started not having sound back in December. We have standard cable at home and we switche to another tv on this room, and this one work good. Please let me know if there is anything that we can do to get it fix. It is a nice TV.
    Novelist:
    Champion:
  • 203 Answers
If you have on-screen display change to video input and try bypassing tv tuner using audio/video cables. If no osd, problem could be shorted picture tube or problem on crt board, often caused by leaking coolant from tube(s). This is fairly common on your model. Hope I've been helpful.
Posted on May 29, 2008
I have a Panasonic Quintrix F TV. About 6 weeks ago the tv screen started displaying
Rule out the signal source by seeing if same issue when a DVD etc is used.
Usually a wave like motion from bottom to top is either signal related or a problem in the power supply (wave moves from bottom to top suggests that).
If not on rear inputs (A/V) it is not the power supply.
Model number is not indicated here and might be helpful.
SD TECH
May 26, 2012 | Televison & Video
I have a Samsung Rear Projection TV HCL5515W. Getting a burning smell after the TV died wth a funny sound. (Red light still comes on). Any clues? One of the posts talks about a blown up capacitor. Any idea...
maybe theres other parts is opened causing to blow up the capacitor. the best is to have to repair your tv to the qualified technician coming from samsung service centers in your area. that problem is easy for them.
Jun 19, 2010 | Samsung HCL5515W 55" Rear Projection...
How do you adjust the focus lenses for an HCL5515w TV?
You have one of two problems. Sometimes both.
Problem #1) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #1
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Problem #2)
Your TV may have a convergence failure. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSolution # 2
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can hire a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a step by step picture instruction guide, original OEM parts, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
Mar 12, 2010 | Samsung HCL5515W 55" Rear Projection...
Samsung HCL5515W...when using coax input pic convergence is off, red and blue seem off....when I use the component inputs it constantly flickers between the squigly lines and picture with convergence off?...
on component your device may have to be on progressive. old dvd players you could switch back and forth on progressive and normal. the squigly lines sound like you need to make sure its on progressive. hook it up using the yellow video slot on player and tv (any cable will work). go into menu and look for progressive and change it on.
Jul 14, 2009 | Samsung HCL5515W 55" Rear Projection...
My samsung HCL5515W turns on has audio but no pic
Your loss of video is likely caused by the failure of the high voltage power supply necessary for the projection CRTs in the set. The supply may be separate and user removable.
Check with Samsung and ask about a possible repair service or the replacement cost.
Nov 25, 2008 | Samsung HCL5515W 55" Rear Projection...
TV problem
It sounds like there is a fault on the chroma panel of some kind.
Jul 23, 2008 | Samsung HC-P4752W 47" Rear Projection...
Where to find replace bulbs
They are CRTs they are actually very exspensive. however you can get some at the following link that are used but fully guaranteed I work there as a support tech, and i know they parted out a samsung two weeks ago that had a bad Main board but the tubes are good and you can get both that you need for about half what one would cost anywhere else. they have free shipping and they include instructions on how to replace them and their tubes have the lenses and everything still on them. Heres the link.
http://servicemanuals.vstore.ca/
Jun 20, 2008 | Samsung HCL5515W 55" Rear Projection...
Samsung HCL5515W
You need to replace both convergence ICs they are STK392-040 you can get new replacement ICs at the following link and they come with free instalation instructions with pictures and free tech support by way of instant messaging in case you need additional help. hers a link to where you can get the new convergence Ics.
May 28, 2008 | Samsung HCL5515W 55" Rear Projection...
Convergence problem
check all resisters around conv ic's, also replace ic that connects to the burnt resister.
Feb 13, 2008 | Samsung HCL5515W 55" Rear Projection...
Samsung HCL5515W red convergence problem
sounds like your convergence IC's have fail and possibly a bad dcm. Some of there models have a small board with the ic's them. It may be cheaper to replace the board. But you can repair it if you have proper equipment
Jan 20, 2008 | Samsung PCN5425R 54" Rear Projection...
Samsung HCL5515W 55" Rear Projection Television Logo
54 people viewed this question
Jerry Greenberg
Jerry Greenberg
