Question about Refrigerators
I have a soleusair party fridge.model MC-88/MC-88S/MC-88SB
I have a soleusair party fridge.model number MC-88/MC-88M/MC-88S/MC88SB the fridge makes a whirring noise when turned on goes away after awhile but comes back sometimes can you help
It's your fan, take the wheels off, unscrew the bolt that holds the wheel bracket on, take the screws out of the black plastic surround and pull it off the bottom. The unit is connected so don't pull out too far. The fan is plugged into the "motherboard", just use pliers to unplug, take the two screws out of the fan and look for a replacement. No, Soleus does not sell parts. Look at a computer repair store of your choice for something similar.
Posted on Sep 04, 2012
2 Suggested Answers
  • 1156 Answers
SOURCE: I have an MC-88 Soleusaire
A noisy refrigerator can be more than aggravating, it can also be a sign that something may be wrong with the appliance. With a little investigation, you will be able to find the cause for the noise so that you can determine how to rectify it.
Self-defrosting
If your refrigerator is a self-defrosting variety, you will find that it has a fan on one of the inside walls that enables this process to take place. Open the door and check whether this makes the sound worse; if this is the case, the problem is likely to lie with the fan. Ensure that it is not blocked by any food items or ice and is running properly. Clear away any items that are blocking it and tighten any loose fasteners. The motor that runs the fan can also cause a noise if it is old or defective and is struggling to continue running, if this is the case, the motor will need to be replaced.
Door Seal
Examine the door seal of the refrigerator to ensure that it is intact and has no defects. If there is a problem with the seal, it can prevent the door from closing properly which will force the refrigerator to work harder as it will also be cooling the air around the refrigerator. Replace the door seal and ensure that the door is able to close properly to see if this reduces the noise.
Element
The wire element that is either located on the rear or the base of your refrigerator. The element can often become noisy after getting covered in dust and debris. Rectify this by switching off the power supply before vacuuming the element. Carefully use a cloth to clean any other surrounding components that are affected by stubborn grime.
Ice Build Up
Where refrigerator is unable to regulate itself, you may find that it can suffer a buildup of ice. When the ice become sufficiently thick, it will stop the refrigerator from being effective and will force the motor to work harder in order for it to keep working. Prevent this problem by defrosting your refrigerator on a regular basis or whenever it is required.
Condenser Fan
The condenser fan is likely to be located at the rear of the refrigerator and can become noisy if it is defective or covered in dirt. After switching off the power supply, use a cloth to clean the blades of the condenser fan if you find that the noise is coming from this component.
Compressor
The compressor is the black box that you will find on the base or rear of your freezer and is where the normal noise of the running the refrigerator comes from. The pipes and wires necessary for the refrigerator to work stem from this box and can become noisy if there is a problem, which is more likely with an older appliance. A defective compressor cannot be repaired so it will need to be replaced.
Hope this help out......
Posted on May 07, 2011
Can I still get the lens covers for model MC-505LC
I cannot find a camera with that reference number - please can you provide the make and model number ? Most lens caps, from 37mm to 82mm, are available on Ebay
Mar 10, 2017 | Cameras
How do I find an exploded view of a LX-140?
SOLEUS PORTABLE Parts Model LX 140 Sears PartsDirect
Sears has a diagram that if you click on it will expand it and you can pan around. If that isn't sufficient, you might try emailing the distributor directly: email to contact@soleusair.com
Jan 16, 2015 | Soleusair LX-140 14,000 BTU AC and 14,200...
Dealer/repair company for this model
Here's the main page for your unit;
http://www.soleusair.com/ph4_13r_01.html
Additionally, for help with repairs you may wish to give them a call.
The phone number is 1-888-8-Soleus. Your call will be directed to a Customer Service Representative Monday through Friday, between 8:30 A.M. to 8:00 P.M. EST.
Let us know if this helps or not.
~Thank you.
Sep 12, 2014 | Heating & Cooling
Need part number for hose alone for panasonic MCV9610
The following hose fits models MC-V9610, MC-V9620, MC-V9635, MC-V9647.
It can be found at: http://www.pasc.panasonic.com/epartr/PartsListChoice.asp?validate=1
AMC94P-GEZV004
Jan 08, 2011 | Panasonic Vacuums
How can i convert 4GB pendrive to 8GB ...?
can i convert the 4gb pendrive to 8gb..?
this is because the mc used in both are same, how to change default firmware installed in mc that flashes and make mc to increase its intensity of storage...if any1 kno..pls tell me da process..
Aug 19, 2010 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
Trying to establish approximate age of old Hotpoint Refrigerator
http://www.waptac.org/sp.asp?mc=techaids_refrigerator_energyuse
Looks like between 82-84
Jun 25, 2009 | Refrigerators
Order drive belt
Panasonic belt # MC-V2708 is the correct belt for model MC-V7395.
Dec 11, 2008 | Panasonic MC-V7395 Vacuum
Soleus CFM40E
http://www.soleusair.com/soleusair/Manuals/Dehumidifiers/CFM-25E_CFM-40E_manual_revised%20_07-24-2007_.pdf
Looks like 1 yr warranty so if a coolant system problem and more than 1 yr old, not worth repairing, but try:
Jun 26, 2008 | Soleus CFM-40 Dehumidifier
Refrigerators Logo
133 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
