Question about Norelco Arcitec Electric Shaver - Gray/Black
How do I remove the heads for monthly cleaning on the 1060x norelco arcitec
  • 8,197 Answers
On link below tells you how to clean anr remove the head from your shaver. It starts on page 22 to page 26.
http://www.p4c.philips.com/files/1/1050x_22/1050x_22_dfu_aen.pdf
Good Luck and please rate 4 thumbs up for the free answer.
Posted on Jul 11, 2010
To charge
Men\'s Grooming / Norelco
1-800-243-3050
Monday - Saturday 9:00 AM - 9:00 PM EST
Sunday 9:00 AM - 6:00 PM EST
Excluding Major Holidays
good luck
Apr 19, 2014 | Philips arcitec 1060 Electric Shaver
I need a users manual for my philips norelco arcitec razor users manual so I can remove the cutter blades for cleaning
The user manual will not help you with this because the Arcitec models were designed so that the cutters could NOT be removed to be cleaned. This is a major disadvantage with the Arcitec models as you can not disassemble the heads to thoroughly clean them. This causes you to have to replace them more frequently.
You can try running the shaver head in a dish of rubbing alcohol to try to loosen the build-up and rinse it out but that's about all you can do.
If you need to replace them, you will find at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/norelco-philips-rq10-arcitec-replacement-heads-p-353.html
Oct 30, 2011 | Norelco Arcitec Electric Shaver -...
How do I replace the head
philips norelco RQ10 replacement heads for electric shaver norelco 1060x cutter blades replacement parts.
and get how to replace RQ10 at SmallAppliance.com
Jan 16, 2011 | Philips arcitec 1060 Electric Shaver
It does nto cut like it use to. The blade is only 6 months old Whats the best way to clean it. It seem to be cutting with only 1 of the triple head
The Arcitec shavers have a poor design which makes it difficult to clean well. The blades can not be removed from their combs, therefore, the only way to clean this is by running them in a cleaning solution. Norelco makes a shaver cleaned that can be used for this. It is available from shaveroutlet.com at the link below. Rubbing alcohol can also be used.
http://shaveroutlet.com/shaver-accessories/norelco-hq200-smart-touch-jet-clean-solution-p-258.html
Simply fill a container about 1 inch deep with the cleaner and then stick the shaver head down into the liquid with it running. Run for several seconds, remove and repeat several times.
Note that if your shaver is badly clogged, this still may not work that well due to the poor design of the shaver heads. If you require replacement, you will also find them at shaveroutlet.com. See link below
Dec 14, 2010 | Norelco Arcitec Electric Shaver -...
The red light showing the shaving head remains on and the shaver discharged the shaver is one year old
Philips suggests changing the heads every 12 months. The indicator is instructing you that it is time to change them. You will find replacements for model 1060x at shaveroutlet.com. See link below
Dec 01, 2010 | Philips Arcitec 1060X
How to remove the blades on a norelco arcitec razor
On Arcitec shavers, the blades can not be removed from the head assembly. This makes it difficult to thoroughly clean them and they must be replaced reqularly because of this.
If needed, you will find replacements at shaveroutlet.com.. See link below
Nov 18, 2010 | Norelco Arcitec Electric Shaver -...
I need a user manual for the Norelco arcitec 1060x electric shaver.
You can get the manual on the link below.
Sep 30, 2010 | Philips Arcitec 1060X
I need to remove the saving rotating heads for cleaning, how do i go about this ? I have the norelco arcitec - Thank you
The blades on Arcitec models can not be removed from their holders. This type shaver is the only model type that Norelco has made with this very poor design.
The only way to clean them is to run the shaver heads in shaver cleaner or under very hot water or in a solution like rubbing alcohol. If that doesnt do it, you will have to replace them. Replacements can be found at shaveroutlet.com. See link below
http://shaveroutlet.com/norelco-philips-rq10-arcitec-replacement-heads-p-353.html
Sep 07, 2010 | Norelco Health & Beauty
How long should heads last on Norelco Arcitec razor
Norelco suggests changing the shaver heads every 12 months for best performance. If you need to buy some, you will find them at shaveroutlet.com. See link below
Aug 20, 2010 | Norelco Arcitec Electric Shaver -...
My razor blade heads no longer rotate but when removed the mechanism underneath is spinning normally - the razor is clean and fully charged.
It sounds like your heads are damaged and need replaced. You can not repair theheads if damaged. You will find replacements for Arcitec shavers at shaveroutlet.com. See link below
May 06, 2010 | Norelco Arcitec Electric Shaver with Jet...
Norelco Arcitec Electric Shaver - Gray/Black Logo
208 people viewed this question
Top Norelco Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
