I have a coleman powermate pressure washer 2400 psi,the siphon injector shoots water out of the top when i am not using it to wash my car or clean my gutters or over hang on my house.
  • 10,319 Answers
The hoses connects to a block which houses a valve. IT HAS DIRT OR DEBRIE IN IT. iT WILL NEED TO COME APART AND CLEANED. aFTER CLEANING IT SMEAR vASELINE OVER IT ALL SO IT WILL SEAL. REINSTALL AND TRY IT OUT. THE VALVE WILL HAVE ANOTHER VALVE BELOW THE FIRST ONE YOU REMOVE SO REMOVE THE LOWER ONE AS WELL UPON CLEANING
Posted on Jul 11, 2010
  • charles wright Jul 12, 2010
    this is not a clothes washing machine. this is a pressure washer that pressure wash sidewalks, brick houses, gutters & overhang on houses, driveways, cars,etc. its similar like a gas generator. ypu can pull it up at www.powermate.com. the siphon injector sits on top of the gas motor. it mixes chemical solution with water which cleans the item, then you rinses it off with clear water. you can take the injector off. it has a spring and a ball bearing inside of it. it needs fixing, it should not have water coming out of it.
    this is not a clothes washing machine. this is a pressure washer that pressure wash sidewalks, brick houses, gutters & overhang on houses, driveways, cars,etc. its similar to a gas generator. you can pull it up at www.powermate.com. the siphon injector sits on top of the gas motor. it mixes chemical solytion with water which cleans the item, then you rinses it off with clear water. you can take the injector off. it has a spring and a ball bearing inside it. it needs fixing, it should not have wayer coming out of it.
After about 5 min of use, the trigger no longer activiates the hose.
the triger has a small ball bearing and a spring in it,,,strip out the triger
dont loose the bits and clean then grease it using water proof grease so its free to slide then the jobs a good un? get yourself a drink and go back to power washing ,,but this time it stops when you tell it to?
Aug 08, 2010 | Coleman Powermate DuraBuilt 1400 PSI...
I have a factory reconditioned Coleman Powermate 2400 PSI-2.0GPM and am getting no pressure at all! Help!
bad pump..take it back where ya bought it or call coleman for service
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/sean_54c3a3dc48a7773c
May 16, 2010 | Coleman Garden
I have the Coleman powermate 2400 PSI pressure washer and on initial start it sprays and has great pressure. But once I release the spray handle it will not spray again, not even one drop of water. I have...
Sounds like the valve in the handle is sticking closed. May have a broken spring, or maybe a part is stuck..
I say take it apart, and the answer will present itself.. Play with it with nozzle out too... Maybe something is stuck after storing so long and will loosen up.. Fingers crossed
Oct 22, 2009 | Coleman Garden
Coleman powermate wont restart spraying after release trigger
Make sure your fluid level in the pump is changed and at the right level.
Sep 24, 2009 | Coleman Garden
I have a coleman powermate 2400. It started fine
Did you try a new spark plug. Old one may have fouled.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Jun 25, 2009 | Karcher 2500 PSI Pressure Washer
WATER LEAKS FROM INSIDE THE 1400 PRESSURE WASHER
Replacing Compasster, where on the terminal block does the black and white wires go?
Mar 08, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
Coleman Pressure Washer Problem
your pressure relief valve is stuck open. i know that may sound too simple but it depends on if you use a cleaner with the water when your using it , not flushing with clean water after use can cause the housing of the aluminum housing of the relief valve to corrode. the valve can't move back and forth as it should because the o ring won't slide.
Jun 20, 2008 | Karcher 2500 PSI Pressure Washer
Washing Machines Logo
128 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
