Question about SanDisk Sansa e200 MP3 Player
Help my sansa player keeps on going to the language menu every time i turn it on and it will not get my music synced when i put it on my mp3 player
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 26, 2008
My playlists from sansa m250 disappeared but when i connected ..
When transfering the songs from computer to player. First, sync device before transfering. Only do this the very first time. If you try to sync with songs already on the player, they will be erased.
To test the device. Open your comuters music file folder, keep folder open, than go to start menu, go to my computer and open the folder (D: or F: folder) It will have your player listed there.
Now with both folders open, take a song from the music folder, drag it to the sansa folder and drop it in there. It should be added to player.
May 05, 2009 | SanDisk Sansa m250 MP3 Player
Sansa e250 Problem
Use the menu button to switch menus. Here is a link to the user manual:
http://www.sandisk.com/Assets/File/Downloads/user-guides/c200-ug-eng.pdf
-Tha Mp3 Doctor
Sep 13, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
I cant put songs on to my MP3
Sounda like a corrupt DB - try getting a firmware upgrade, and then try rerunning the Sansa Recovery Tool. menach- the Sansa is not compatible with iTunes.
-Tha Mp3 Doctor
Jun 02, 2008 | SanDisk Sansa Clip MP3 Player
Download music to my scandisk sansa e260
When you turn on the player, select the music menu, and then scroll down until the playlists logo appears - select that and then your playlist name should be there.
If it still isn't there, then the songs that you tried to sync have some sort of licensing restriction on them that does not allow them to be synced to a portable device - wmp will show them as synced, but alas - they will never actually show up on the player.
May 22, 2008 | SanDisk Sansa e260 MP3 Player
Stuck in language mode
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
-Tha Mp3 Doctor
May 13, 2008 | SanDisk Sansa e260 MP3 Player
Music not showing up even when downloaded
Try this: disconnect the player from the computer, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
or
-Tha Mp3 Doctor
Dec 25, 2007 | SanDisk Sansa e260 MP3 Player
Continued Lost Memory...
or
-Tha Mp3 Doctor
Oct 27, 2007 | SanDisk Sansa e260 MP3 Player
My sandisk e200 wont add songs
-Tha Mp3 Doctor
May 08, 2007 | SanDisk Sansa e200 MP3 Player
Every time i turn on my sandisk e200 the language menu comes
-Tha Mp3 Doctor
The player asks me to pick language every time I turn it on...also no longer playing wma's
-Tha Mp3 Doctor
Jan 09, 2007 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e200 MP3 Player Logo
21 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
