Question about Whirlpool Duet GHW9150P Front Load Washer
Washer stopped mid cycle
My duet stopped mid cycle and the lights are flashing. I canot open the door by pushing the any button for three seconds. I unplugged the machine several times and this did nothing. Now, I have a load of very wet clothes in there that I cannot get out.
  • 5,911 Answers
This could be a momentary program glitch. In order to reset the Central Control Unit (CCU), you need to unplug the washer for AT LEAST 30 minutes. This should reset the CCU and allow you to open the washer.
If the door remains locked and still will not open following a CCU reset, the following link explains how you can use the manual release to get the door to open:
http://www.fixya.com/support/r3576511-door_jam_on_kenmore_elite_and_whirlpool_
You may want to try using a wet/dry shop vac to pull a vacuum on the drain hose to try to pull as much of the water (if any) ot of the wash tub BEFORE opening the door.
NOTE: Is your washer displaying any error codes? If so, the error codes are NOT listed in the Owner's Manual. For a complete explanation of all the error codes, each one of these appliances comes with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front feet of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to accurately troubleshoot this problem.
Read through the information provided and let me know if you need further assistance. I hope you find this information helpful.
Posted on Jul 11, 2010
Door locked with flashing red light on model W10578789
This might work try unplugging it for about 45 -60 seconds and see if it clears the problem. The red light is some type of warning and I would be safe in saying it is a safety device gone bad. Sorry I couldn't be of more help.
Col. Dana Gillespie
Aug 14, 2014 | Whirlpool Duet Steam WFW9550WL 27"...
Washer Duet Control Locked, cannot do anythink, tried the advice but nothing when I push on ON & Cancell I see three bars --- in red, thats all,
Various control lock features on differing models:
Press the end of cycle signal button for 3 seconds
OR
To reset press the DRAIN/SPIN button and hold it for 15 seconds.
OR
Press and hold the END OF CYCLE button for 15 seconds to reset the control.
OR
Press options and select for 10 secs till LOC is no longer displayed
OR
Unplug washer
Remove lower kick panel
Reach up and locate bottom of door lock switch
Grab the teardrop shaped tab
Pull gently till yall hear a click
The door will be opened
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 05, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My Maytag Epic Z washer stop in mid cycle then locked the door, we unlock the door via holding the cycle signal button down for 3 seconds, now we can open the door, close it, power up, start a cycle, but...
The low humming sound is from the pump. Remove the 3 screws on the bottom panel and remove it to check the pump filter. Here is a video for the "Duet Sport" washer. This washer is about the same. This video will show you the process and in this video the problem was similar to yours.
Happy Holidays The FixYa Team
Dec 19, 2010 | Maytag MHWZ600TB Front Load Washer
Whirlpool Duet front load washer. Put car mats in to wash. They are too wide and don't let drum spin. Stopped in first few seconds of cycle and error code came up but, door remains locked. How do I open...
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 20, 2010 | Whirlpool Duet GHW9150P Front Load Washer
It's STUCK
Hi
The light is flashing due to the door lock error. The door lock is activated as the machine experienced an error or was stopped in middle of a cycle. Or the door was being pulled while the machine was running a cycle. Try unplugging your washer and restart the washer to check if you are still getting the same blinking light. If error is still not resolved then start the rinse/spin cycle & stop the cycle, now press and hold the cancel button for 5-10 seconds. However, if you are still not able to get the door open then you'll need to open the door manually by disassembling the washer. Please post back for any further assistance.
Daniel
Jul 25, 2010 | Whirlpool Duet GHW9150P Front Load Washer
We have a Whirlpool duet washer that doesn't finish washing
its probably a blocked water filter to this fabric water valve or the coil has failed on the valve,it should be 3800kohms,check the filter at the water inlet connection,hope this helps
Jan 08, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Need to reset whirlpool duet front load washer
How do I reset a front loader Whirlpool washing machine. The time keeps flashing. I drained the washer and now I need to reset it.
Jun 09, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Duet washer stopped during wash cycle.
take off the panel below the door three screws and look for the tech sheet located on the right side. It will coach yoou thru the codes and common problems. Sounds like it may be the door swithch does it lock when you push the start? If not the door switch my guess would be a machine control. 877-262-1479 parts.
May 30, 2009 | Maytag EPIC MFW9700S Front Load Washer
Help with whirlpool awm 8103/1
Okay, ther manufacturer recommends unplugging the washer for at least 30 minutes to reset the computer. It could be you have a momentary glitch causing some problems. If you still have the same problem after leaving the washer unplugged, the following link explains the "FH" error code:
http://www.fixya.com/support/r615354-fh_error_code_whirlpool_duet_kenmore
If your clothes are stuck inside and you still cannot get them out because the door will not unlock, you will have to use the manual release to open the door. The next link explains how:
http://www.fixya.com/support/r622155-kenmore_elite_whirlpool_duet_door_jammed
I hope this helps you. If you require additional assistance, please let me know.
Aug 27, 2008 | Whirlpool GHW9300 Duet Washer
Front Loading Duet Washer will not start
You have to set your programme FIRST, then put the "on" switch. Try.
Mar 26, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
209 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
