Question about Sony STR-DE845 Receiver
Sony STR-DE845 5.1 Receiver, No Sound
I have a Sony STR-DE845 5.1 Receiver, it powers on but there is no sound from my speakers and it will not change tuner stations. I hear the relay switch over then it switches back.
Solution please, I don't want to go out and buy a new reciever.
    Brigadier General:
  • 8,546 Answers
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Posted on Jan 21, 2011
I have the sony: STR-DE 685. The sound in the
This sounds like a very poor connection. Please make a new splice on speaker and receiver. This should take care of this for you.
Feb 26, 2010 | Sony STR-DE597 Receiver
Sony STR DE-445 unit powers up but no sound
Check the fuse, Sony is known for its random problems with sound. The one I have you must tap it on the side. Its a flicker switch inside.
Feb 13, 2010 | Sony STR-DE445 Receiver
No sound from Sony STR-DH500 when playing dvds with HDMI
no sound via hdmi cables, you must use optical or coaxial
Dec 10, 2009 | Sony STR-DH500 A/V Receiver
Sony str de405 receiver...was working fine, now no sound
I have a problem with vintage reciever Sony STR-11L. Power transistors were replaced and I dont know what were original ones. Sound is no good and radiator is hot-I think problem is in replacement. Can anybody help me with?
May 14, 2009 | Sony STR-DE405
No center speaker sound on my Sony STR-DA5200ES receiver
It sounds like a set-up problem. If the receiver was in front of me I could figure it out.
http://esupport.sony.com/perl/select-system.pl
goto this web site to download the owners manual it's free.
Mar 06, 2009 | Sony STR-DA5200ES Receiver
No sound from rear speakers during test tone usng Sony STR-DE475
I had this problem last night.
To solve it, you can reset the amp by:
1) Put the receiver on stand-by
2) Hold down "MODE" button and press on button
3) "S.F. CLR" appears in the display and surround is back on.
Good luck
Dr Gardner
Jan 21, 2009 | Sony STR-DE475 Receiver
STR--DG910: no rear speaker sound, no center speaker sound
if you confirmed all connection repeat your speaker setup.
Jul 06, 2008 | Sony STR-DG800 Receiver
Sony STR-DE635 Receiver-no sound at all
sorry my expertise is in appliances, youl need to repost you question to another tech
Mar 21, 2008 | Sony STR-DE635 Receiver
Turn your volume down,press the tape monitor button.then turn up?
Mar 20, 2008 | Sony STR-DE635 Receiver
No output on main speakers
I have experienced a similar problem with my Sony STR-GX57ES and took it to a certified tech only to find it needed the power supply replaced. I opted to hunt down a compatible power supply but have been unsucessful thus far. That being said I picked up an STR-D665 for next to nothing and found the power supplies to be quite different (you would hope so any, with the ES meaning Elivated Standard and all) but with the D665 working flawlessly I'd rather have something working than nothing. Good luck!
Dec 06, 2006 | Sony STR-D665 Receiver
Sony STR-DE845 Receiver Logo
348 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
