Question about Garden
Excell 2300psi quantum 6.0 hp power washer. motor runs fine but no water pressure
  • 583 Answers
SOURCE: excell vr2500 pressure washer ,no pressure
check the water filter ---high pressurehose must have bbackpressure to develop pressure so disconecting it wont acheive ,much ,if you have agood water supply ,oil in the pump--- adjust pressure by srewing the brass fitting that the pressure hose attachesto, down that is clock wise a couple of turns or so and see if that makes a difference if not seals in the pumpmay be gone tha t should show by water in the oil
Posted on Jul 30, 2009
SOURCE: Honda excell pressure washer does not have pressure
if the machine is running on suction, ie sucking out of a barrel there may be an air leak on the suction hose or pump. it will pull air easier than pulling water .
put the machine under mains water pressure, hose pipe straight from tap to pump.
check all around the pump and inlet pipes for leaks.
if water leaking this needs rectifiying for it to work on suction.
run the pressure washer while on mains pressure with the hose on, does this make a difference?
if not then probably the unloader is stuck in the pump head. remove unloader , clean and replace it
parts breakdowns are available on the internet for your machine.
possibly valves stuck, or the valve springs have broken, seen this quite few times on these machines. if so replace springs .
These sort of machines do not last very long anyway, about 50 hours use if your lucky.
Posted on Jul 22, 2009
jeff_drakesr
  • 155 Answers
SOURCE: Gas powered pressure washer wont start
On pressure washers the more you pull the cord the more pressure builds up making it difficult to pull and start. I hold the trigger down as i pull this keeps the pressure down. If this is not the problem then take a look at the Spark plug, Air Filter if all is fine then check the fuel. How often do you use it, fuel loses its Octane when sitting around. Please give a 4 THUMBS UP if this free answer is helpful in anyways. Good Luck and have a Great Day.
Posted on Apr 02, 2010
SOURCE: xr2600 excell pressure washer I was using it and
I have the same problem and it seems the piston in the back has a ring and the ring is broken i half i'm talking it to get fixed tomorrow i will keep you informed.
Posted on Oct 11, 2010
jyackle5
  • 8197 Answers
SOURCE: Need a owners manual for
Do you have a model # so I can help you find the manual
Posted on Jul 28, 2011
Testimonial: "Great job"
Have a Excell 2300psi pressure washer. Pull cord
yes very short ones. or pop rivet back on . easy and inexpensive
Oct 11, 2014 | Garden
Have a Excell 2300psi pressure washer. Pull cord broke took off top cover but looks like the recoil is pop riveted in can i remove and put screws back in
You dont need to take it apart, simply wind up the tension and feed the new cord through both holes, tie the knot and release tension to rewind new cord
What is causing water to leak out of the resovior when the power washer is running?
I am assuming you mean the chemical resovoir tank? If water is running out of it then water is coming back up your chemical injector. This usually means at some point the ball and spring in your injector got stuck...typically people take them apart at the nipple to ry and fix it. not realizing there is a small ball and spring in that nipple. This is actually a ball valve to prevent water from coming out of the chemical injector nipple. Replace the ball and spring if needed as well as the oring seat in the nipple. This will stop your tank from filling up. Good luck
Sep 06, 2014 | Honda GCV160 5.5HP 2300PSI GAS-POWERED...
I have an excell pressure washer vr2500 with a 6.5 hp Briggs and Stratton motor after pouring gas into empty gas tank see gas leaking from carburetor
YOU HAVE A FLOAT IN THE CARBURETOR THAT MAY BE STUCK THERE IS A SMALL NEEDLE VAULE THAT ALSO MAY BE STICKING YOU CAN GET A REBUILT KIT FOR THE CARBURETOR
Feb 23, 2014 | Cam Spray 25006BX 2500 PSI Cold Water Gas...
Need a owners manual for Craftsman Power Wash- Quantum Gold 6.0 2300psi
Jul 28, 2011 | Garden
I have an old briggs stratton 2001 power washer its hard to read model number it looks like EXYRB2321 or EXVRB2321 its 6 hp when i put in ether number at B&S sit they say no results i need a...
Excell pressure washers used a series of numbers such as yours. I believe that that number will be for pump or pressure washer as a whole unit. Check Excell web site for a match. If you are looking for the engine model number check the fan shroud or valve cover or tag on engine itself. Good luck
Sep 06, 2010 | Briggs & Stratton 020324 3700 PSI Pro...
Xr2600 excell pressure washer I was using it and it lost water pressure does not have any pressure. the engine runs fine just don't know what the problem is.
Aug 16, 2010 | Honda Garden
Apr 02, 2010 | Briggs & Stratton Gas Pressure Washer...
Gas leaking from carb on Briggs and Stratton engine
`v already answerd this,are you slow? with oil in the sump you can do no damage by running the engine with abit of smoke,it will clear up very quickly. i find it hard to believe youhave done the things you claim if you dont know what a carby bowl is!! it is the receptical under the carby,take brigg`s advice and replace the gasket it is needle and seat or flappervalve
Jul 25, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
Garden Logo
807 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
