Question about Brother IntelliFAX 4100 Laser Fax
Outfeed tray is broken
The out feed tray is broken at the attaching ends, where can i get another tray for a Brother type fax machine.
  • 31 Answers
Try ikonsale.com website. or google it.
Posted on Jul 16, 2010
Installing the rear outfeed support tubes
About 11,900 results (0.88 seconds) Search Results
    Bosch TS1002 Table Saw Rear Outfeed Support ... - YouTube
    ? 3:59
    https://www.youtube.com/watch?v=d5B4227hBUk
    Jun 18, 2012 - Uploaded by Isabel De Los Rios
    Bosch TS1002 extends 18-inches and stores flush to table. It extends the working depth of Bosch 4000 10 ...
    Tool Free Way of Attaching the Out-Feed Table. - Angelfire
    www.angelfire.com/.../funwithtubes/.../ss_outfeed_table_mounting.html
    The outfeed table which is available from Shop Smith works very well once ... The bottom part supports the far end of the table while the near end attaches to the ... the screws can be installed through the brackets on the outfeed table to hold it in ....Insert one of the extension tubes in the rear rip fence rail, adjust it so it sticks ...
    Craftsman 137.415030 Operator's Manual - ManualsLib
    www.manualslib.com > ... > Saw > 137.415030 > Operator's manual
    be installed underneath the rear. outfeed support tubes (2). Fig. L. 3. Insert the rear outfeed support. tubes (2) into the two holes in the. rear of the saw table, and ...
Feb 08, 2016 | Saws
Says manual feed. Load paper
There is a manual fee slot just above the paper tray. Sounds like the manual feed slot isn't closed all the way. Here's a link to support for your machine: MFC 7860DW Others Brother Solutions Center Note there is a firmware update available.
Jun 19, 2014 | Brother MFC 7860DW - Multifunction fax /...
Fax feeder is pulling sheets through at the same time
Sounds like the separation pads in the paper tray are worn out. You can contact Brother and purchase the parts from them. It should be less than $10. as long as the paper is being pulled from the tray it sounds like the rollers are okay.
Oct 08, 2009 | Brother IntelliFAX 4100 Laser Fax
Says no paper feed
check paper tray picking gear. if it is broken replace chase
Aug 07, 2009 | Brother IntelliFax-2820 Laser Fax
Broken paper guide and difficult fax input.
Lets start with the paper feed problem. You need a new paper feed roller to pull the paper in when it should. You need a new seperation pad to prevent multiple pages from being fed at the same time. you will have to look at your machine to determine which parts are needed. here is a link to a company that I do business with. You can find the trays here also.
http://www.precisionroller.com/manufacturers/brother-intellifax-4750e.html
May 23, 2009 | Brother IntelliFAX 4750 Plain Paper Laser...
Broken piece from jammed paper tray
what did you break off?????? let me know so i can help you
Dec 29, 2008 | Brother IntelliFax-2480C Fax
Outgoing fax makes loud clicking noise
2 different problems here. 1st is with document feed and 2 is with paper feed.
1st prob seems to be with the paper feed roller not meshing at the gear. Probably a broken piece on the lower document tray assembly. No real fix for this unless you can strip it out and haywire it.
2nd prob is probably a poorly meshing drum unit. Examine the gear teeth on both the drum and the machine. As you have replaced the drum already (presumably with a brand new one) You might possibly find a missing or badly worn tooth on the messhing gear in the machine.
Oct 02, 2007 | Brother IntelliFAX 2800 Laser Fax
Auto feeds crooked
Are we talking about a paper feed problem from the paper cassette tray or the Auto Document feeder on the top. Either way, check the the paper width guides, or if it is the paper cassette tray, remove it and check the paper pick up roller locking clips.
Jun 08, 2007 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFAX 4100 Laser Fax Logo
42 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
