Question about Scotts Company Scotts 73730 AccuGreen 3000 Deluxe Drop Spreader
The handle that should release the fertilizer, does not work.
Squeeze the handle, push spreader...no fertilizer comes out....
P.S. I tightened the wire by turning the "thingy", but still no fertilizer.
  • 63 Answers
With the bucket empty and the handle pulled open are ther holes in the botom of the bucketif not its jammed shut just needs cleaning with wd40
Posted on Jul 24, 2010
Scotts Accugreen 3000
www.scotts.com/smg/.../index.jsp?...
Jul 17, 2013 | Garden
Wire that comes down won't open or close so seeds can come out or stop
Hello, is the spring at the bottum of the spreader in place? Sometimes the spring can break or fall out. The spring is what opens and closes the ports to release and stop the seeds or fertilizer.
Apr 19, 2012 | Scotts Company Garden
I own a scotts 3000 and the handle that releases the fertilizer, is broken. I need the item, that I may use this spreader. Where or whom do I connect with for parts. Thank You, Conrad
Sorry to hear about the problems you are experiencing with your spreader. We may have replacement parts available. Please contact Scotts at 877-465-5160 to check part availability.
Hilary @ Scotts
Sep 03, 2011 | Scotts Company Scotts Lawns Edgeguard...
The little door on the hopper of my Scotts Speedy Green 1000 spreader does not close when I release the contol handle. Is there a spring that has come off and can a replacement part be purchased? Dennis
Hi Dennis. I don't think there are any after market parts for Scotts spreaders. I do recall a wire and a spring on one type of Scotts spreader. There was an eyelet hole just off center that the wire and spring attached to. You could probably rig something up pretty easy. Would be a matter of locating a spring and wire.
Before you get to deep into this... flip it over and look for dried / caked fertilizer on next to thehinge area. I have seen this stop spreader application doors from closing often.
You can ask Scotts here:
http://www.scotts.com/smg/helpcenter/helpCenter.jsp
Kelly
Apr 26, 2011 | Scotts Company Garden
How do i calibrate the scotts speedygreen 2000
Your SpeedyGreen 2000 Rotary Spreader spreader was calibrated at the factory. However, a spreader's calibration may change or slip during periods of frequent or heavy use.
You may check the calibration by using the following directions. First, adjust your micrometer setting to 2. Squeeze the trigger against the handle. The calibration line is a small, raised line embossed on the top of the spreader's shut-off plate. With the micrometer set at 2 and the trigger squeezed against the handle, the calibration line should be aligned with the back edge of the hopper opening.
To adjust the alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer rate setting barrel. Adjust the screw until the calibration line and back edge of the hopper meet. If you have any difficulty checking the calibration, contact us and we will be happy to help walk you through the adjustment.
When you are not pulling on the trigger handle, the cable should be loose. When you pull on the handle, the cable becomes taut and the shutoff plate slides open.
If you have any additional questions feel free to contact Scotts directly @ 1-800-543-8873
Jan 24, 2011 | Scotts Company Garden
Many years ago I bought "shutes" that attached to each side of my Scotts drop spreader. They could be filled with ordinary flour and manually released with a handle on each of them so I could see the area...
Scott's no longer makes this handy helper. Do this, get some white sand and mix it with the grass seed. It will mark your lawn and help you see where you spread the seed or fertilizer. Joe
Mar 31, 2010 | Scotts Company Scotts& Accugreeen 3000...
How do I calibrate Scotts Accugreen 2000 for pounds of Fertilizer per Sqft. What do setting equal?
To adjust calibration, do the following:
1) Adjust the micrometer setting to 6.
2) Turn the spreader over.
3) Squeeze the trigger against the handle.
4) The front edge of the shutoff bar should be aligned with the calibration line engraved on the bottom of the hopper.
5) To adjust alignment, use a small wrench to turn the black calibration screw at the lower end of the control wire leading from the micrometer insert.
Note: If the hopper is missing a calibration line - with the setting at 6 they should be able to pass a 9/64" drill bit through the opening just to the right of center. (First opening to the right of the spring.)
Nov 08, 2009 | Scotts Company Scotts& Accugreeen 2000...
Repair parts for a Republic EZ Broadcast Fertilizer Spreader
I have a problem with a broken handle it looks like there is no parts for the EZ Broadcast Spreader. The sad part is the rest of the unit is in great condition.
Looks like plan obsolescent!
Sep 06, 2009 | Garden
How do I calibrate my acugreen 1000 drop spreader?
The spreader comes already calibrated. The opening of the gate is determined by the setting that you input from the handle. This will correspond to the recommended settings provided on the fertilizer bag.
Best regards, --W/D--
Aug 09, 2009 | RTO Accugreen 1000 Drop Spreader
I have a Republic EZ drop fertilizer spreader. The gray plastic device (2 pieces, one screwed inside the other) up by the push handle that rotates to widen or narrow the slot at the bottom of the...
I have a Republic EZ drop fertilizer spreader. The gray plastic device (2 pieces, one screwed inside the other) up by the push handle that rotates to widen or narrow the slot at the bottom of the fertilizer storage bin when the handle is squeezed is broken. The cable connecting the device to the movable part of the slot is OK. The gray plastic has numbers on it that show through a small square opening in the gray plastic closest to the push handle. Where can I get a replacement part?
May 11, 2009 | Garden
Scotts Company Scotts 73730 AccuGreen 3000 Deluxe Drop Spreader Logo
363 people viewed this question
Top Scotts Company Garden Experts
john h
lnbn1975
jhnolson
Are you a Scotts Company Garden Expert? Answer questions, earn points and help others
