Question about HTC Verizon XV6700 Cellular Phone
I need a list of number from 0000-9999
My samsung intensity from verizon andi turned it off and when i turned it back on it was asking for a nam# code of some sourt so i need i list of numbers using the number 0-9 of all the numbers
How can I get my samsung intensity 2's back light to turn off?
I suggest that you take it to the nearest Verizon store and ask them for technical assistance. It sounds as if there might be a mechanical problem with the phone.
Oct 28, 2015 | Samsung Intensity II U460 Verizon
How do tyou unlock your phone if you changed the setting to nam 2
So you're playing with all the settings in your phone and you notice this nice security menu. Wow, maybe you should enable the lock code. But you don't want to have to enter the lock code all the time, so you set your phone to only need a code when it turns on. Ah. Some piece of mind. What's this other sub-menu? Network? What's a NAM? Hmm. Let's set NAM 2 and see what happens. EEEK! Your phone's rebooting. Why's it doing that? Okay. Here's that new prompt for the security code. It's okay. I remember it's the last 4 digits of my phone number. Oh No! That didn't work. Unfortunately, when you switched to NAM 2, you switched your phone over to a different phone number. Your code's no good. Your phone is useless.
There are 2 solutions. The safest and best solution is to take your phone back to Verizon and have them reprogram it. A few people have told me Verizon is uninterested in doing this. A more risky solution is below. It will reset your phone to its original settings and erase all your phone numbers you have in the phone but it should get your phone working again. I've never had to fix this problem on my own phone, but a bunch of people have emailed me their thanks to say that this works. If this doesn't work or you make it worse, please don't blame me, especially if you don't follow the directions very carefully. I believe this proceedure works, but there is one mistake that if you dial a 9 at just the wrong moment, then you're going to be guaranteed making a trip to Verizon (so speaks the voice of experience). So, without further ado, here's the proceedure:
Do this exactly:
  • With your phone on, dial 47*68#13580
  • This will bring up a menu that says something like "-TEST CDMA-"
  • Dial 22
  • Your phone will now say "Send NAM 2"
  • Dial 222222 (the number 2, six times)
  • With each key press two digits will appear on your screen. Something like "000000-84100". Write down the 3 digits after the dash (e.g. 841). These are the first 3 digits of your unlock code.
  • Dial #
  • Dial 73
  • Your phone will say "Clear All." and it will just sit there for a while. Don't panic, just let it clear all the settings. It's not clearing the programming, just all the ringers and key beeps and menu settings that you entered (and more importantly, its reseting your password to something predictable). After about 30 seconds a "." will appear after the 73 you dialed. when that happens, the menus are cleared.
  • Dial 02
  • This will reboot your phone.
  • When the phone finishes restarting try the 10 possible security codes that start with the 3 digits you wrote down (e.g. 8410, 8411, 8412, 8413, ...). One of those codes should work.
  • When your phone is unlocked, switch back to NAM 1 by pressing Menu, 0 for Setup, 2 for Network, 1 for Set NAM, and select NAM 1.
Apr 19, 2012 | Samsung Brightside U380 Smartphone Verizon
Changes NAM Settings?
Here's some ideas for unlock codes, most phones use the last 4 or possibly 7 digits of the phone number, 4 or 5 - 0's or 12345.
Basically your NAM settings contain the phone number info for a carrier, and you can put two different numbers in the same phone using NAM1 and NAM2, what you have done is switch it to an empty NAM so it is asking for the rest of the programming info to set it up.If you can switch it back to NAM1 it should work again. Most phones have an option in the menu for phone settings that allows NAM switching without needing a code.
Aug 30, 2009 | Cell Phones
I have a sch U740 samsung phone nam 1 code
The lock code should be the last 4 digits of your phone number or 0000.
If that doesn't work, perform an activation by dialing *228 send. Then select option 1. After this is complete your phone's lock code should be reset to the last 4 digits of your phone number.
Jul 09, 2009 | Samsung SCH-u740 Cellular Phone
Good Morning.
You either can ask Verizon Customer Service to request it from Samsung for free but it may take a couple days, or you can buy the unlock code. Usually people will sell the service of unlocking phones on Ebay. I've never bought it, but I would guess it would take some a day or two just like asking Verizon to get it.
Mar 17, 2009 | Samsung Cell Phones
INITIAL PROGRAMMING NEEDED ON JUKE?
you can't fix it you have to get a new one...the same thing happened to me and im getting a new one
Dec 26, 2008 | Samsung SCH-U470 Juke Cellular Phone
NAM2 locked.
http://ars.samsung.com/customer/usa/jsp/faqs/faqs_view.jsp?isARS=Y&SITE_ID=22&AT_ID=87077&ARS_ID=9833651
its in the samsung frequently asked questions. All you do is go to windows calculater turn it to HEX enter the hex number under your batery switch the calculator to dec and the last 4 numbers is the NAM2 code
Oct 26, 2008 | Samsung SCH-u740 Cellular Phone
Lock code for nam2 settings
Ok i sent an email to sumsung and i got this response
Thank you for your email. If you switched the NAM to NAM2 you will need to calculate the code. Listed below are the steps on how to do so:
1.Obtain the Hexadecimal ESN of the phone. The ESN should be printed on the sticker on the back of the phone, under the battery. The Hexadecimal ESN is the one with letters and numbers.
2.Open Windows calculator by going to Start -> Run -> type in "calc", then click OK
In the Calculator, click "View" then "Scientific".
3.Click on Hex and type in the Hex ESN
4.Click on Dec for the decimal conversion and use the last four digits for the code on the handset
5.Once the code is entered and the menu can be accessed, switch the NAM to NAM1
Jul 06, 2008 | Samsung Glyde SCH-u940 Cellular Phone
HTC Verizon XV6700 Cellular Phone Logo
540 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
