Question about Jenn-Air JFC2089HE French Door Refrigerator
Runs and cools to desired temperature for 2-30
Runs and cools to desired temperature for 20-30 minutes and then stops cooling. Fan keeps running and door seperator on front of fridge gets very hot. We unplug and then it starts to run frin again until 20-30 minutes.
  • Jenn-Air Master
  • 43,501 Answers
As the weather is getting warmer for many people their freezerRuns and cools to desired temperature for 2-30 - 2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on Jul 12, 2010
What is difference between on an auto on thermostate
I'm not sure exactly how this applies specifically in a car, but on a home heating and cooling (air conditioning) thermostat, it is often associated with the fan or blower setting.
If for a system fan:
"Auto On" setting in a heating / cooling system would start the fan when the temperature climbed above or dropped below the setting you on the thermostat and start the heat or cooling source. Once the thermometer indicates the desired temperature had been reached, the heating / cooling source would be stopped and the fan would turn off.
"On" would run the fan all the time, regardless if the thermostat tired to start the heat or cooling source. This would result in constant circulation of the air in the space(s) and tend to keep warm or cool spots (rooms) from being created.
Nov 30, 2015 | Cars & Trucks
2001 ford escort cooling fan will not turn off please help?
sounds like either the temperature sensor is keeping it on, the cooling fan relay is fused together, or that you have some wires touching keeping power to the fan.
Aug 18, 2014 | Cars & Trucks
Air handler fan cuts on runs a few minutes and then cuts although thermostat is set to off.
your thermostat could be wired in to a energy recovery venilator which will bring the unit on for a certain amount of time every hour some thermostats have recirculate mode which will do the same thing to help filter the air
Apr 16, 2013 | Goodman Heating & Cooling
1993 RX7 - cooling fan always comes on when engine is shut off.
I would want to know if the computer is grounding the fan relay to make it come on, or if the relay is faulty. On some models the computer turns the fan on to keep the radiator from overheating when the engine is stopped, but that should only happen with the engine at operating temp.
Sep 28, 2012 | 1993 Mazda RX-7
Intermittent colling in Samsung Window AC
so your reported figures show that the unit is operating as planned
the closer to ambient temp the shorter it runs for
the further away from ambient temp the longer it runs for
when the desired temp is reached , the compressor will stop but the fan will continue to run to circulate air past the thermostat so that it will switch back on when the room temp reaches too high temp
and that is why it is recommended to set the temp at 25 C as that is the most economical temp to run it at
Oct 30, 2017 | Heating & Cooling
1986 Mazda 323 coolant fan comes on when motor is hot and stays on.
Is the engine actually cooling off? If the temp switch isn't seeing a drop in temperature, it will keep the fan running.
Oct 02, 2017 | Cars & Trucks
I have an Everstar portable air conditioner Model MPA-08CR but when it is working for 10 minutes...it is working fine cooling the desired space but the next 10 minutes it is only working like a fan...then...
The problem may be that you don't have the temperature set low enough and the unit reaches the set temperature quickly and then only the fan runs. Try lowering the set temperature.
Thanks for choosing FixYa.
Aug 05, 2011 | Heating & Cooling
I turn on my hitachi 50v720 tv it runs for 5 minutes shuts off and the temp light comes on.what could be going on?
It's most likely the cooling fan is not operating either due to the supply line for the motor missing or the fan itself at fault. This means when the lamp reaches a certain temperature (after 5 minutes) the temperature sensor should then active the fan to keep it cool, if this does not happen it will go into protection 7 shut down.
Sep 16, 2009 | Hitachi 50V720 Television
Lg split indoor fan runs non stop
Hello Hamid,
The unit is designed to run the indoor fanmotors continuously when in cooling mode on both indoor units (evaporators). The reason is that this circulates the air and the temperature thermistor or sensor is able to sense return air temperature and in turn start or stop the outdoor unit and compressor as required according to the setpoint temperature. The reason for either unit not reaching setpoint temperature can be a couple of reasons. A) Incorrect design - the unit may be too small for the application. You can calculate this roughly at 650BTU per square meter of room in a relatively warm ambient climate. Or secondly B) The outdoor unit has leaked and is short of refrigerant. You can check this when the outdoor unit is running by feeling the thicker copper tube on the right hand side of the unit. This should be cool to cold. If no temperature difference is felt, it is short of refrigerant. Hope this helps you. Goodbye
Aug 11, 2008 | LG LS-L1210CL Mini Split Air Conditioner
Thermostat ?
The Air conditioner are good only the adjustment of thermostat are the problem, select the thermostat in lower #3 you observe the thermostat will off in such time temperature reach to #3 If you full adjustment the compressor will not off.
In fan selector the compressor will autamatic off because no connection attached fan only .
Jan 05, 2008 | Kenmore 73089 Air Conditioner
Jenn-Air JFC2089HE French Door Refrigerator Logo
80 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
