Question about Frymaster Dean Frymaster/Dean HD50G Deep Fryer
I am not able to get the pilot light lit on my frymaster gas fryer. I have had this issue before in the past two months and it was a clogged gas orphus. Were is the gas orphus located so that i can take it out and insure the orphus is not obstructed by grease? is there a diagram available for me to instruct me on were it is located?
    Scholar:
  • 81 Answers
All Manuals are available on Frymasters website. the orifice is located in the pilot line where the gas line connects to the pilot. You will have to unscrew the fitting and remove the orifice. It is best to clean the entire pilot assembly and the gas line going to the orifice. Many times when a pilot tube has leaked and possibly burned incorrectly, the gas line can fill up with suit. Your clogged orifice could recur if the line is not cleaned as well. I have had to return to customers locations only to find an orifice I cleaned was clogged again. I then removed the pilot feed line, when I blew through is it filled my hand with black suit. It can be a messy and frustrating job to pull all this apart. You may want a professional. Be sure you have no gas leaks upon completion, use soap bubbles to check for leaks! Click here to download manual from frymaster
Posted on Jun 24, 2011
Wont start up pilot is lit and thats all it will do
Here are some pointers:
Check first if the unit receive standard gas pressure required on the nameplate.
Ensure that the thermopile is free of soot or any form of dirt.
Pilot flame quality must be good so that it can properly heat up the thermopile.
Gas valve knob must be turned to "ON" position after the pilot is lit.
Thermostat set at temperature higher than present oil temperature.
Wires are all tightly connected on terminals.
Regards.
Jun 21, 2011 | Frymaster Dean 2424G Deep Fryer
Can't locate pilot on vulcan lg300
TO LIGHT THE PILOT
1.Open the door. 2. Turn the thermostat OFF The thermostat is located behind the door. 3. Push the gas control valve knob and turn to OFF. Wait 5 minutes for unburned gas to vent. 4. Push and turn gas control valve knob to the "L" in PILOT. 5. While still holding the knob in, light the pilot with a lit flame. Continue to depress the knob until pilot remains lit when knob is released. If the pilot does not remain lit, repeat step 3 through 5. 6. Depress and turn gas control knob to ON
Jun 02, 2011 | Frymaster FPEL217 Deep Fryer
We just purchased a brand new frymaster Dean SR42G fryer for the restaurant. It was working fine for about a week and but now the pilot light will not stay lit. I hold it for well over a minute, but it...
I'm assuming this has a standing pilot (always lit)
It only takes a tiny piece of dust/dirt to stop up the tiny hole in the pilot oriface.
to clean the oriface you have to remove the pilot, the oriface is inside the pilot on the gas line end.
Remove the gas line from the pilot and then a small round piece will fall out be careful it is easy to loose because it is small and also it may stick and then fallout when you are not looking.. it has a very small hole in it must be clear, hold up to bright light should see light through the round hole.
To clean first DO NOT damage the hole If you dammage the hole instead of a0ne inch pilot flame you will have a very large flame a fire hazard. I use one bristle from a wire brush they are very thin
stick in ther hole gently, then hold up to light again if now you see a clear hole reassemble.
Patrick Mot
Feb 11, 2011 | Frymaster Dean SR42G Deep Fryer
My pilot light will not stay lit. I have replaced the thermocouple and still will not stay lit. Can the valve be bad?
Make sure the thermocouple is deeper into the flame of the pilot light. It needs to reach a high enough temperature to produce a high enough voltage to keep the pilot light lit all the time. I do not think that the main gas valve is bad at all.
Nov 25, 2010 | Frymaster Dean SR42G Deep Fryer
Unit ( model SR142gp serial 0608MA0448 - propane fuel ) operates as designed, but can not cut flame to pilot with the thermostat. must cut the gas control to pilot to the get pilot flame & pilot...
The pilot light should remain "ON" all the time. It is not intended to ever go off, unless you are not going to use the fryer for several months at a time. Then you can just shut off the propane which will shut off the pilot light flame. It does not cost that much to run the pilot light all the time. About one to two dollars a week.
Sep 11, 2010 | Frymaster Dean SR142GP001 Deep Fryer
Pilot light stays lit when I turn the gas valve to on. But nothing happens when I Turn the thermostat on. Help
The thermostat control is bad, you will need to replace the thermostat switch and everything will work just fine. Basically the thermostat switch is not sending a signal to the gas valve telling to to turn on
May 25, 2010 | Frymaster Dean SR42G Deep Fryer
Piot light will go out
its likley to be the thermal cut out playing up its not holding the gas on as its getting week a new one will sort this problem out first time
Nov 12, 2009 | Frymaster Dean GF14 Deep Fryer
I need to know how to lite the pilot on my frymaster fryer
fry099_16_4.gifMake sure the thermostat is turned off. Units burners will light as soon a pilot in it is on. fry099_16_5.gif 3-2 Lighting the Pilot and Burner Figure 1 Figure 2 3. Push the knob in and light the pilot. Continue to hold the knob in for about 60 seconds after the flame appears on the pilot. Release the knob. The pilot should remain lit.
I suggest that you boil it out before using. This cleans the pot of any contaminants here is how to do this.
Boiling Out the frypot To ensure that the frypot is free of any contamination resulting from its manufacture, shipping, and handling during installation, the frypot must be boiled out before first use. Frymaster recommends boiling out the frypot each time the oil or shortening is changed. 1. Before lighting the burner, close the frypot drain valve and fill the frypot with a mixture of cold water and boil-out solution or detergent. Fill to the lower oil-level line. 2. Light the fryer in accordance with the lighting instructions in Section 3.1. 3. Simmer the solution for one hour.
I would attempt to paste the complete owners manual but it's just way to large. I do warranty for Frymaster is how I have access to it. Good luck
Oct 17, 2009 | Frymaster Dean GF14 Deep Fryer
Frymaster Pilot not lighting
first thing I would check is to make sure the quick disconect on the gas hose is fully connected,and that the cut off valve is tured on.Sometimes the orifice in the pikot assembly can become stopped up.(where you light it by the burner)you can check there by undoing the gas line at the compression nut on the assembly.the hole is really small and you can use a small needle to clear it.
Mar 28, 2009 | Frymaster Dean FM345EETC Deep Fryer
Frymaster blowing back fire
google sams manuals.is your fryer propane or natrual gas if so the baffles and orfices in the fryer are clogged.propane burnes very dirty.
Aug 12, 2007 | Frymaster Dean 2424G Deep Fryer
Frymaster Dean Frymaster/Dean HD50G Deep Fryer Logo
234 people viewed this question
Top Frymaster Dean Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Thomas Perkins
Thomas Perkins
Paul Carew
Are you a Frymaster Dean Kitchen Appliances - Other Expert? Answer questions, earn points and help others
