Question about Sony 4GB Memory Stick PRO Duo Memory Card
If the camera says "access" when the memory stick is in, and there is a red light lit by the memory stick insertion slot when it is inserted, and the camera cannot take or read photos when the memory stick is inserted, what can i try to read the photos to save them to pc or cd?
  • ntgarcia0715 Jul 11, 2010
    I appreciate the way I always got a response to my additional questions. Thanks
  • Sony Master
  • 6,993 Answers
the memory card is not being read by the camera. It might be as a result of incompatibility issue or an error. Formatting the memory card should resolve the issue but you will loose the files/items on the card.
Now, you need to get the files off the memory card. To achieve this, you will have to insert the card into a PC that has a memory card slot or you can use a PC memory card reader. Store/save the files on a PC and then format the memory card using the camera, that is, format the memory card with the camera.
I hope you understand this.
Good luck.
Posted on Jul 11, 2010
  • 4 more comments
    do know where i can by that memory stick reader to view them on my pc? i dont have a pc that you can stick a memory card into
  • Walesarumi
    Walesarumi Jul 11, 2010
    you can get it directly from any computer accessories store/shop within your vicinity or you can buy it online via e-bay.com, bestbuy.com, amazon.com, etc..
    Take care.
    I just went to walgreens and used their memory stick adaptor to try to have their machine read it, no luck, was that the same concept that you were talking about or is it still worth getting a pc memory stick reader
  • Walesarumi
    I just hope that the memory card is not damaged beyond repairs Do buy the card reader yet, we need to make sure the memory card is still working. I would suggest that you look around for a friend that has a laptop with memory card slot, or a phone that uses the same memory card. This is to know if the card is still working. That should be the reason the camera is not seeing the memory card.
    If the card is damage, there is not way you can retrieve the files on it.
    Take care.
    Thank you for your help!
  • Walesarumi
    Okay!
When memory card is inserted the camera wont work
You can insert CF memory and some memory stick cards when you use a special adapter. When you use a memory tick, make sure it is compatible, because the memory stick is the most incompatible memory card, if you have not the correct one.
When you use a CF memory card, check all contacts. Not one contuse pinn in the camera should be belt a little. Use a bright light and a loupe to check.
Feb 13, 2014 | Sony Alpha DSLR-A350 Digital Camera
Sony Cyber Shot DSC-H9
The camera may display a MEMORY STICK ERROR or C:13:xx message (xx can be any random number) on the LCD screen for the following reasons:
IMPORTANT: If model-specific information is required to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
  1. Remove and re-insert the Memory Stick® media several times.
  2. The inserted Memory Stick media is not compatible with the camera. Check your instruction manual for information regarding Memory Stick media compatibility.
  3. The inserted Memory Stick media is not formatted. Format the Memory Stick media using the FORMAT option in the camera menu. WARNING: There is a risk of data loss. Formatting will erase all stored data, images, movies, etc., from the Memory Stick media.
  4. The terminals on the Memory Stick media are dirty. Remove the Memory Stick media from the camera and use a soft dry cloth or pencil eraser to clean the contacts. Make sure there are no residual particles on the Memory Stick media before re-inserting it into the camera.
  5. The data on the Memory Stick media or the Memory Stick media itself is damaged. Try using a different Memory Stick media in the camera.
Thanks
Proton
Oct 02, 2008 | Sony Cyber-shot DSC-H9 Digital Camera
Says error on formatting memory card.
The camera may display a FORMAT ERROR if the inserted media is not formatted or if the media was formatted on a computer. This error may also display if the inserted media is not supported by the camera.
Try to remove and re-insert the Memory Stick media several times.
Make sure that the inserted Memory Stick media is compatible with the camera. DSCW310 Camera is compatible with the Memory Stick Pro Duo upto 32 GB.
You may also try formatting the Memory Stick media to resolve the issue. Format the Memory Stick media using the FORMAT option in the camera menu.
Formatting will erase all stored data, images, movies, etc., from the Memory Stick media. FORMAT option is available in the Memory Card Tool Menu of the Camera which is in the Settings Menu. Please back up the data by inserting the Memory Stick in the Computer Memory Card slot.
This may also happen if the terminals on the Memory Stick media are dirty. Remove the Memory Stick media from the camera and use a soft dry cloth or pencil eraser to clean the contacts. Make sure there are no residual particles on the Memory Stick media before re-inserting it into the camera.
This should resolve the issue. If the error continues to display, the media may need to be replaced or the camera may require service.
Jan 23, 2011 | Sony Cybershot DSCW310 Digital Camera
I have format error on my cybershot camera. I need to access photoc on camera
The Camera may display the FORMAT Error if the inserted media is not formatted or if the media was formatted on a computer. This error may also display if the inserted media is not supported by the Camera. The maximum supported capacity and media used is Memory Stick Pro Duo with 1 or 2 GB.
If you've already captured the images in the Camera and the error message displays, then try to open different images captured in the Camera and check if the message appears for all the images.
If this happens with all the images, then remove and reinsert the MS (Memory Stick) in the Camera and check if it works. You may also try cleaning the MS terminals and also check if the Internal Memory of the Camera displays the error. If the issue persists, then insert the MS in the Computer slot and transfer all the images to the Computer. If the images appear normally in the Computer, then Format the media in the Camera. To Format the Memory Stick, select the Format option in the Memory Stick Tool Menu of the Camera. (Menu-->Setup-->Memory Stick Tool-->Format)
Formatting the MS will delete all the files saved.
Formatting the MS should resolve the issue.
Thanks for using FixYa.
Jan 18, 2011 | Sony Cyber-shot DSC-S700 Digital Camera
When i try to turn my camera on it flashes a small red light and then it won't turn on, how do i fix this?
The Red indicator flashing in the Camera may be the Access Lamp or the Power Lamp. The Access Lamp is located below the Control buttons and the Power Lamp near to the power button. If the Access Lamp is flashing, it indicates that the Camera is accessing the Memory. Do not remove the Memory Stick or Batter while the Access Lamp is lit.
If the Power Lamp is flashing, it indicates that the Camera is turned on. If the Lamp is lit in Red it shows that the Battery is not having enough charge. Insert new batteries or charged Nickel-Metal Hydride batteries to resolve the issue.
You may also try power resetting the Camera. To power reset the Camera, remove the batteries from the Camera and then press and hold the POWER BUTTON of the Camera for 15 seconds and then reinsert the batteries after 1 minute and check if the Camera works normally. If the issue persists, service may be required.
Thanks
Oct 21, 2010 | Sony Cyber-shot DSC-S730 Digital Camera
How to use the memory card reader
To access the memory card reader without using the software provided, follow the steps below. If no card is inserted, the green light on the card reader will be on.
Insert a memory card.
• Insert the card with the brand name label facing up.
• If there is an arrow on the card, make sure it points toward the printer.
• If needed, make sure you connect the memory card to the adapter that came with it before inserting it into
the slot.
Wait for the light located to the right of the slots on the printer to come on. The light blinks to indicate the memory
card is being read or is transmitting data.
• The printer recognizes one memory card at a time. If you insert more than one memory card, a message appears
on the display prompting you to remove all memory cards inserted.
• If a USB flash drive is inserted together with the memory card, a message appears on the display prompting you
to choose which memory device to use.
When reading of images is complete, the number of photos found appears on the display. Then you can make your selection and print. these are the types of memory card supported by you printer.
xD-Picture Card
• Secure Digital (SD)
• Secure Digital High Capacity (SDHC)
• Mini Secure Digital (with adapter)
• Micro Secure Digital (with adapter)
• MultiMedia Card (MMC)
• Reduced Size MultiMedia Card (with adapter)
• MultiMedia Card mobile (with adapter)
• Memory Stick (MS)
• Memory Stick PRO
• Memory Stick Duo (with adapter) or Memory Stick Duo PRO (with adapter)
Mar 18, 2009 | Lexmark X5495 All-in-One &USB...
Memory Stick Will Not Engage
You need to replace the damaged memory slot with new one. If you know basic electronics and have tools for replacement, pls goahead.
Jul 26, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Memory card
Dear Starrr63,
I think the slot where you insert the memory card has been damaged or it doesn't make contact with memory stick. See inside slot in good light, hope you will find damage/tilted pins there.
May 25, 2008 | Sony Cyber-Shot DSC-F505V Digital Camera
Sony 4GB Memory Stick PRO Duo Memory Card Logo
78 people viewed this question
Top Sony Electronics - Others Experts
 Grubhead
Grubhead
Argospete
Argospete
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
