Question about Microsoft Windows XP Professional for PC
What is a unit matrix - Microsoft Windows XP Professional for PC
    Brigadier General:
  • 10,406 Answers
It's a matrix that only has "zero" and "one" values, including absolute values, e.g., (1,0,0,-1) is an unrolled "unit" matrix, but (2,0,0,1) is NOT, because '2' is neither '0' nor '1' nor '-1'.
Posted on Jul 13, 2010
Sunspot on screen humminbird matrix 27 can it fix ?
No, typically with led matrix screens, it is near impossible to find someone to replace screen for cheaper than new unit. Same goes for tvs and computers, etc. Also, and not to be rude but rather if you are faced with buying another unit, do not buy Hummingbird. They are a very cheap quality for not much less money. Best bet will be either Furuno or Garmin. Good luck!
May 14, 2014 | Humminbird Matrix 12 Fishing System
Video matrix switch uninitialized?
Use a Hyper terminal, Hercules SETUP utility is user friendly for this. Attach a Serial cable to the unit (straight through cable not null modem) or use a USB to serial cable.
Set the Baud rate to 115200
Data size 8
Parity none
Handshake OFF
Mode Free
do not check the box for Hex
For the 12x8 digital/ analog audio matrix switch cat5 enter the command [S,M,Q]
12x8 digital/ analog audio matrix switch [S,M,L]
8x8 component video digital/ analog audio matrix switch cat5 [S,M,C]
8x8 component video digital/ analog audio matrix switch [S,M,B8]
12x8 component video matrix switch [S,M,I]
12x8 component video matrix switch cat5 [S,M,H]
8x16 digital/ analog audio matrix switch [S,M,G]
8x16 digital/ analog audio matrix switch cat5 [S,M,E]
8x16 component video matrix switch [S,M,F]
8x16 component video matrix switch cat5 [S,M,D]
12x16 component video matrix switch [S,M,J]
12x16 component video matrix switch cat5 [S,M,O]
12x16 digital/ analog audio matrix switch [S,M,K]
12x16 digital/ analog audio matrix switch cat5 [S,M,R]
Oct 31, 2013 | HDTV Supply 12x8 stackable digital/analog...
Hummingbird matrix 12 not powering on
The Power Supply just crapped out, Sorry.....
Apr 12, 2013 | Humminbird Matrix 12 Fishing System
Set the Battery Date on a Matrix 3000 UPS
According to the user manual (available here: http://www.refurbups.com/KB-M-Matrix) this can only be reset by using the PowerChute software available from www.apc.com and requires the unit to be connected to a computer.
Mar 06, 2010 | APC Matrix-UPS 3000VA UPS System
Toyota Matrix Instrument Cluster Interchangeable?
I am not sure if these facia units are interchangeable or not but i can assure you that the electronic mileage is unique to every unit and will have to be changed by using specialust diagnostic equipment.
Dec 20, 2017 | 1998 Toyota Camry
Battery Charging Failed on APC Matrix 5KVA
you will need to replace the unit. the charging circut has failed
Dec 27, 2009 | APC Matrix-UPS 5000 UPS System
Power Flo Matrix pump, leaking from underneath?
Replace the pumps mechanical seal with a replacement seal #200. It's less than $10.
Jul 19, 2009 | Hayward 1 HP 2 SPEED POWER-FLO MATRIX PUMP
When powering up[on land] it says transducer not connected,checked cable and connections.It use to work maybe went bad? Humminbird Matrix 10
Disconnect cable from back of unit clean the pin connections on the unit and on the cable. If rusty clean with Corrosion X are WD
IF it doesnt work replace cable Jim OMC Retired Mech
Jul 05, 2009 | Humminbird Matrix 12 Fishing System
No battery communications
You will get that message when the communications cable is not hooked up. It looks like a phone line and daisy chains from one battery to another and ends at the Matrix Control unit. If you have those installed and it still says no communication the system need service.
If you have a volt meter you can check the voltage from each battery at the plug. It should be 48 volts or more, usually on a fresh battery pack it will read 54.0+ volts.
Hope this helps,
Dean
Dec 09, 2008 | APC Matrix-UPS 5000 UPS System
Hummingbird GPS Matrix 12
evidently the installer put 2 inline fuses to the power line. After more investigating I located the second fuse which was blown.
Jun 22, 2008 | Audio Players & Recorders
Microsoft Windows XP Professional for PC Logo
49 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
