Question about GE DPSB613EDWW Electric Dryer
My dryer squeaks when running a load. How do I fix it?
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryermy dryer squeaks when running a load.  How do I - 2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Posted on Jul 11, 2010
5 Suggested Answers
  • 50 Answers
SOURCE: dryer makes loud squeaking noise when spinning
there are two possibilities for this question. 1) there is an idler roller that give the belt the correct tension . unplug dryer and remove idler roller see if it spins freely if not replace it @0 there are two drum rollers in back of machine thatdrum rides on remove drum it's self explanitory how to remove drum and very easy also. you can roll these wheels and check for free movement visually check them ,one or both should be worn out or the bearing in the wheel has failed before putting old or new wheels back sand the wheel shafts to get any gunk off them and that's about the only thing that can make a dryer squeek
Posted on Jan 25, 2009
SOURCE: Squeak when running the dryer
It's the roller axles and/or the motor shaft. Remove the front of the dryer and lubricate same.
Posted on May 27, 2009
heatman101
  • 43501 Answers
SOURCE: Squeaking Sound like the fan belt needs replacing.
heatman101
Posted on Apr 06, 2010
heatman101
  • 43501 Answers
SOURCE: When ever the dryer is
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
Posted on Aug 20, 2010
Squeaking Cabrio dryer when running
The squeaking is due to the drum glides or as some people call them slides, being worn or broken. Easy fix and very inexpensive part
Mar 25, 2014 | Whirlpool WGD8800YW Cabrio Platinum High...
Changing belt maytag legacy dryer sde515dayw model
Have someone else look at the machine, I'm not sure about the last guy. Do smaller loads to ease up on the machine. It will last a lot longer doing more, but smaller loads.
Nov 29, 2013 | Dryers
My GE Dryer Model # DBXR463ED2WW makes loud squealing sound when it runs loaded. Is this something I can fix?
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Nov 11, 2010 | GE DBXR463EDWW Electric Dryer
The dryer squeaks - noise is coming from left hand front of dryer. I've take the cover off, there is a plastic piece that if I press toward the front of the dryer stops the squeak. The heavier the...
The squeak is actually the rear bearing WE3X75.
98fbf6b.jpegOddly enough although this might be your part you should use your model number to order the part. Different production runs I guess. Theis dude mounts in the rear
66ec823.jpgright in the center of the heater. This bearing gets real thin and when almost gone starts the squeal. You must remove the drum to get to the backside and replace that dude. I have a pictorial and more HERE.
Oct 12, 2010 | GE DBXR463GB Gas Dryer
When ever the dryer is running it make a horrible squeaking sound until the load is done. How do i stop it from squeaking?
heatman101
Aug 20, 2010 | Dryers
My dryer squeaks upon starting to dry a load of clothes...everything else works fine except it squeaks the whole entire time. Any advice?
GE dryers have a straight rod in the back center of the drum that goes through the rear bulk head and that is what supports the drum in the rear, it is also what squeaks when it gets warn out , around that short rod that goes into rear bulk head from the drum is a black Teflon plastic sleeve called a barring replace it and that will fix the noise
Apr 05, 2010 | GE DVL223EBWW Electric Dryer
heatman101
Apr 05, 2010 | Hotpoint TDL14 Electric Dryer
May 27, 2009 | Hotpoint NBXR463EBWW Electric Dryer
Maytag dryer squeaks during cycle
if replacing the rollers didn't fix the squeak, you need to replace the teflon drum slides and drum gasket material. mine sqalled so much it would run you out of the room. now it's quiet.
Jan 19, 2009 | Whirlpool LER5636P Electric Dryer
GE DPSB613EDWW Electric Dryer Logo
221 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
